Question about Microsoft Windows 2000 Professional for PC
Windows 2000 pro can't safe mode exit
Stupidly went into safe mode to try and find solution to D:/not accessible error message and now stuck in safe mode, have tried to boot normally and all the other configurations in safe mode no joy. PC just boots into safe mode each time.
As msconfig not on win 2k downloaded version and installed on the pc and went through options ie boot ini tab and make sure safe mode not checked but still no joy. Any help would be much appreciated.
Thanks
Steve
  • 1 more comment
  • Steve07 Jul 19, 2008
    Thanks for replies as new to site hope I am replying correctly.
    Thanks Ginko, what exactly do you mean by a Windows installation from Windows as not aware of this option, having previously tried booting with windows cd in drive and no go and inserting windows cd in drive after booting up get error message D://not accessible even though drive properties and troubleshooting shows drive working correctly.
    Thanks RyCarr got sfc in command prompt screen and get 7 options tried 3 of the options scannow, scanonce and enable all in brackets and / as shown, out of brackets, lower and upper case just goes back to prompt
    Any help much appreciated from either of you
    Steve07
    Thanks Ginko, I have tried inserting windows cd after pc up and running but all I get is error message D://is not accessible, initially went into safe mode to see if I could find reason for error message and got stuck in safe mode.
    Thanks any help much appreciated to get out of safe mode and then how to get cd (D drive) working, sorry to be a pain
    steve07
  • Steve07 Jan 01, 2009
    Thanks to everyone who helped on this issue. It is now fixed and win 2000pro now reloaded with CD drive working fine.
    Not sure how to sign off and close this help???
Before you can boot from cd, u need to set the cmos boot choice so system attempts to boot from the cd , FIRST, then the hard drive,,, default is ,,floppy HD, then cd,,
rearrange to have cd choice first,,
once booted from the cd, delete , present partitions, then create a new one,, or better yet 2 so defraging the OS is faster.
you will be asked about partitions during win install,,,set asside 10g for the operating system
Posted on Dec 04, 2008
  • 64 Answers
What makes you say it's in safe mode? Does it tell you, or are you assuming it's in safe mode because of the resolution? Try adjusting the resolution...
Posted on Jul 19, 2008
  • Ryan Carrier Jul 19, 2008
    Don't reinstall yet! Whenever you suspect a corrupt system, open a command prompt and type sfc then click ok. (On an xp system, type sfc /scannow). This checks for wrong versions of system files or corrupted files. Rarely do you have to reinstall if you know what you're doing!
  • Microsoft Master
  • 19,396 Answers
The system is corrupted, that is the reason why it starts only in safe mode.
Easiest way to proceed is reinstalling Windows 2000 pro as an update installation.
To do this start a Windows installation from Windows (not from dos booting with disk inside).
Do not do new installation, do upgrade installation, it will preserve all your data, and most of your software and settings.
Do a backup of all your data first.
  • Ginko
    Ginko Jul 19, 2008
    I mean instead of booting with disk inside you put Windows install disk after Windows has started on your pc, and start disk under windows, not as boot.
My toshiba satellite pro 4300 series wont actually start... I give my password and then a message saying : your computer is now starting . or something like that arrives. But it juste stays their... and...
Try running chkdsk from Windows Safe mode. Switch on laptop, press F8 before windows logo comes. goto safe mode. Login. Press start>run. Type CMD. then type chkdsk c: /f /r. then type exit. and restart your laptop.
Oct 06, 2013 | Fujitsu Mobile MHS2040AT 40 GB Hard Drive
How to fix error code 2000-0142
Did you try booting your computer in Safe mode to check if you receive this error message?
1. Use F8 while restarting the computer.
2. Under Windows Advanced Boot Options select Safe mode and hit Enter.
Check if you receive this error message in Safe mode.
It seems like your drive might be corrupted. If your computer is still under warranty, I would suggest you to contact them to get a replacement. But before you contact them, let us see whether Check disk utility would make a way to boot windows succesfully or not.
If you've Windows Vista Operating System disc, then try running the check disk utility from Windows Recovery Environment.
1. Put the Windows Vista installation disc in the disc drive, and then start the computer.
2. Press a key when you are prompted.
3. Select a language, a time, a currency, a keyboard or an input method, and then click Next.
4. Click Repair your computer.
5. Click the operating system that you want to repair, and then click Next.
6. In the System Recovery Options dialog box, click Command Prompt.
7. Type the following command and press enter.
Chkdsk /r
Once your machine has finished repairing the hard drive, type EXIT and press ENTER to restart your laptop.
You can also try typing the following command if Check disk fails to fix the issue. At the same command prompt, type fixboot and press enter.
For your information: If you've a Dell Laptop, then according to Dell, the error code 2000-0142 is a Drive Self Test failed error code. Visit the link below:http://support.dell.com/support/topics/global.aspx/support/dsn/en/document?c=us&cs=19&dl=false&l=en&s=dhs&docid=14B3819735D6B40EE0401E0A55177ED2&doclang=en#HDD
hope 2 help
http://www.bostonrecycling.net/
Jun 18, 2012 | Dell Inspiron 1525 Laptop
How to get to safe modem?
Tip: If you are running Safe Mode because you cannot get into Windows, you may want to first try loading the last known good configuration.
To get into the Windows 2000 and XP Safe mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use yourarrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers, if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Windows 2000 or Windows XP Safe mode- If after several attempts you are unable to get into Windows 2000 or Windows XP Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen
Jan 14, 2012 | Compaq Armada M700 Notebook
Wont boot in safe mode
start your laptop before booting windows press f8 button continuously
ndows 2000 / XP users
bulb.gif If you are running Safe Mode because you cannot get into Windows, you may want to first try loading the last known good configuration.
To get into the Windows 2000 / XP Safe mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Trouble Getting into Windows 2000 or Windows XP Safe mode - If after several attempts you are unable to get into Windows 2000 or Windows XP Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice.
Once you're done in Safe mode if you want to get back into Normal Windows restart the computer like you normally would and let it boot normally. Click here to get additional information about getting out of Safe mode.
Microsoft Windows Vista and Windows 7 users
To get into the Windows Vista and Windows 7 Safe Mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Safe mode - If after several attempts you are unable to get into Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Sep 27, 2011 | Lenovo G460 Laptop Computer - 06779XU...
Quattro pro 9 is very slow in saving files over netwrok
I have a problem with accessing to my company data in tally.. when i select the company and it begins to load, it gives me an error message :
Exiting Tally
Internal error . contact tally solutions
Software Exception c0000005
(Memory access violation)
and i have no other options but hitting OK then it exits
Nov 20, 2009 | Corel WordPerfect Office 2000 Standard...
Toshiba laptop satellite L300 Booting Problem
try the recovery wizard,also try pulling the hard drive,and ram,and bios battery if you can get to it,looks like watch battery on motherboard.or green plastic pack with two wire plug on main board,take the panels off on the bottom,if your lucky you will see it,otherwise have to dissamble to get to it.if you find it unplug for a couple hours,with main battery out and ac unplugged,should reset the bios to factory default ,might help ,do you have xp or vista?if your bios battery is the watch battery style be very carefull removeing it the holder will break off the motherboard easily,,if none of that works post a reply and ill give you some more options
Sep 10, 2009 | Toshiba Satellite Pro L300 Notebook
Error code stuck key and now it switches itself off
Check if system is booting in bios. Disconnect external peripherials except keyboard and mouse.Restart the system in safe mode,Do msconfig,disable startup and non microsoft services.If issue persist ran a diagnostics on memory and harddrive. Try to start system using 1 memory module at a time if you have 2 memory modules.reseat memory module and check.
Aug 18, 2009 | Fujitsu Siemens AMILO Pro V1000 Notebook
I was hopeing somebody could help, this morning i went onto the laptop and then restarted the laptop, when i restarted the laptop the laptop kept on rebooting its self. i first comes up with compaq logo,...
Try to start in safe mode, then change the start up options so that the computer does not reboot on error. Then you can see what the BSOD (stop error) message is and troubleshoot from there.
May 05, 2009 | Compaq Armada E500 Notebook
I just installed xp pro and it keeps freezing
I would suggest that you run only one stick of Ram at a time to determine if they are the problem.. Also these CPU's had heat problems that damaged the cpu. This also causes freezing. I would consider resetting the CPU and the heat sink, and case fans are clean and working.
Dec 10, 2008 | Computers & Internet
Safe mode
Have you tried doing a system restore in safe mode? Click on Start-->Programs-->Accessories-->System Tools-->System Restore. Pick a date prior to you installing whatever screwed up your computer.
Jul 17, 2008 | Acer Aspire 5315 Notebook
Microsoft Windows 2000 Professional for PC Logo
98 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
