Help me to install WinXP in a Gateway Laptop that came with SATA HDD
On trying to install WinXP in my Gateway Laptop Model MA7 that came with 160GB SATA HDD, the message I get during Window Startup is HDD not found. I've gone through the BIOS setup and set all the parameters as described to install WINXP without success. Please assist me on what to do.
The machine installs Windows Vista without difficulty but I want to stick with XP as some of my peripherals has no Vista driver.
Thanks as I await your sollutions.
Regards,
Emma Chukwu (digitrust@yahoo.com)
  • mgsayed Aug 25, 2008
    i have a gateway laptopm MA7 but win xp did not find the sata HDD
  • oldchump Sep 28, 2008
    i am having same issue while installing win xp sp2 but with vista it is working fine .
You have probably already fixed this but maybe others can find this a little helpful. i had to downgrade a gateway ma7 for one of my customers who had lost their recovery cd with vista on it. Their HD had gone bad.
The reason the XP installer says "no HD" is because the the drivers required by the gateways Sata controller (hd controller) are not preloaded on the xp install disc. The only way around this is to download the windows xp compatible sata drivers from gateways website and then slipstream them into a custon windows xp install cd. its actually not as difficult as it sounds. just download the sata driver, a slipstreaming program called nlite.
1 download and install nlite
2 put in your xp install cd, and run nlite, when nlite asks, browse to the i386 folder (your installation files)
3 you will have lots of options to choose from, but for this purpose, choose "add drivers" and select the location of the gateway drivers (c:\cabs\something) i think.
4 finish and burn the cd. then use it to install windows xp.
this little guide isnt step by step, but with a little trial and error you should get by
-Nele, MCSE
Posted on Dec 04, 2008
My MA7 model gateway won't boot from CD or removable drive how do i go aboput it?
help.
mike
Posted on Nov 18, 2008
How to get software for downgrade from vista basic to xp sp2 oper
first you download a sata controller of your hdd because winxp sp2 will not support a sata controller after you finesh download the sata controller copy the installer of windows sp2 then compile it again to gother sata contraller. or just download a windows sp3 has updated inculded sata controller that is the easy process
Mar 04, 2010 | HP Pavilion dv6000z Notebook
Gateway notebook model MX8711 is freezing up - i get SMART msg that hard drive is bad and needs to be replaced asap - what hard is installed in this model?
Your laptop comes with a 100 gb SATA interface HDD running 5400 rpm. Any SATA interface hard drive will do. Pay a little more and get the speed up to 7200 rpm and you can use any capacity you can afford.
Oct 31, 2009 | Gateway MX8711 Notebook
How to install Windows XP onto a newly formatted laptop
put winxp cd in tray
at boot up press F12 - right-arroweto CD icon --> Enter
winxp should go into install
you'll probably need a version of winxp that can recognize Sata hdd. or hae sata drivers handy.
Oct 13, 2009 | Toshiba Portege M200 Notebook
Compaq CQ40-108TU unable to install XP OS
Prepare a Bootable XP Disc installer.
At first go to BIOS Setup to Boot First Priority the CD/DVD Rom Drive.
After that disabled SATA or RAID Configuration. The Bootable XP Disc Installer could not go on when you don't disable the SATA or RAID Connection.
Don't worry that you are thinking it would not detected the SATA HDD by Bootable Disc but it is. Then follow the instruction.
If i am helpful to you please rate me.
Thank you.
Yboyandrei
Aug 24, 2009 | Compaq Presario Notebook
Trying to install on winxp but not getting anything...help!
R u installing window xp on laptop ?
Since laptop is using SATA hdd, u need to change the bios setting in order to install window xp.
Mar 26, 2009 | Blitzz Technology (BWP612) 802.11b...
I can't install winxp in my l45-s7409 laptop.
go in to the bios setup and somewhere in there is sata native disable it.. or change to ATA in bios
Aug 13, 2008 | Computers & Internet
Install xp on acer extensa 4220 hard disk not detected
Acer Extensa supports two model of HDD installation 1) AHCI and 2) SATA.
Windows Vista get installs on both but for Windows XP you need to Enable SATA option.
For that go into Bios, Change option of Hard Disk from AHCI to SATA. After that you can install both XP as well as Vista.
Try it, and mail me update: ansari.yasser@gmail.com
i am using Windows XP on Acer Extensa-4220
Jun 21, 2008 | Computers & Internet
Cannot Detect Hard drive Winxp On Toshiba Satelite L200
Hi ,
u can not detect HDD during installing win-xp coz in u r laptop u have SATA hard drive.
to detct hdd in setup u want to make sata netive mode diseble in COMS setup
Plz check COMS thereis sata netive mode is available ....
if this information is useful for u please rate me......
Jun 14, 2008 | Toshiba Satellite Pro A200-EZ2204X...
SATA hdd is not recognized by winXP intallation
First u have to update ur bios and then USE HIREN BOOT CD to repair  HDD
Oct 11, 2007 | DFI KM400MLV KM400...
Philips freevents x52 laptop raid driver for F6
It's not easy to find info on this machine. I believe it has an Intel 945 chipset, and you can find the SATA driver here: http://www.intel.com/support/chipsets/sb/cs-015001.htm
Oct 06, 2007 | Computers & Internet
Computers & Internet Logo
2,918 people viewed this question
David Payne
David Payne
