Question about Kenmore 16602 / 16604 / 16609 Built-in Dishwasher
Kenmore dishwasher, model 665.170 344 01. "Clean" light keeps flashing and will not stop. Have tried everything in the manual and the light still will not stop flashing.
Kenmore dishwasher, Model # 665.170 344 01. "Clean" light will not stop blinking. Have tried resetting it, but no luck. My Kenmore dishwasher has less then 60 uses and the clean light is now flashing and I'm unable to get the unit to work. I've turned power off the breaker and tried everything I can think of to reset. Any ideas??
  • Kenmore Master
  • 19,396 Answers
Only reset you can do is unplugging power cord for 10 minutes.
The control panel it is probably faulty and in need for replacement.
Posted on Jul 19, 2008
  • Ginko
    Ginko Jul 19, 2008
    If the dishwasher is still under guaranty check the last pages of your user manual and call the customer service number provided to validate the guaranty.
2 Suggested Answers
  • 188 Answers
SOURCE: Kenmore dishwasher, model 665.170 344 01. "Clean" light keeps flashing and will not stop. Have tried everything in the manual and the light still will not stop flashing.
If the clean light flashes 7 times, pauses then repeats...
If the dishwasher doesn't sense a water temperature increase, it will stop working and lock the functions (clean light flashes 7 times, all buttons are non responsive).
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring). It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Posted on Feb 20, 2009
I have a kenmore elite dishwasher 577-9 17262402. The clean light is flashing. How do I stop it from flashing to start the dishwasher?
The blinking "clean light" is a common problem with some of the Kenmore and Whirlpool models dishwashers.
The problem is usually attributed to water supply temperatures being too low when filling.
Apparently, there are some issues with the temperature sensing circuits in some dishwashers that causes an error code to be generated if a certain water temperature is not achieved in a specified time interval (this time may differ between models).
There is a reset sequence that you can try to clear the fault.
Push the NORMAL WASH then HEATED DRY buttons in that sequence two to three times.
The unit will enter diagnostics mode, but can be stopped by pressing the CANCEL button.
This will clear any existing faults and should return the dishwasher to normal operation.
To keep the fault from returning, it is recommended that you run your hot water faucet in the kitchen until it runs hot BEFORE you start the dishwasher.
This will heat the water in the supply line for the dishwasher (most dishwashers are fed from the kitchen sink supply line).
The theory is that if you fill the dishwasher with hot water from the start of the wash cycle instead of the cool water that is normally in the lines (especially if you have a hot water tank located far away from the kitchen), this should satisfy the requirements of the temperature sensing circuits.
If the fault reappears, there should be a tech sheet located inside the lower panel under the door that explains what the fault is.
The flashing light will be a series of flashes, followed by a pause.
If you indeed have a component problem, it will depend on the number of flashing lights in the sequence.
Refer to the tech sheet to determine WHAT component is affected and how to troubleshoot.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 21, 2010 | Kenmore 24 in. 15252 / 15254 / 15259...
Clean light flashing
Sorry you are having trouble, I put together a quick check list and instructions on how to reset the control. Let me know if this works for you, if not I can dig a bit deeper to help.
http://www.fixya.com/support/r4628906-flashing_or_blinking_green_clean_light_7
Apr 25, 2010 | Kenmore 24 in. 16293 Built-in Dishwasher
The clean light in my Kenmore dishwasher keeps
It has to do with the water temperture, either the water entering the dishwasher is too cold and the heater can't get it up to temp, or the heater unit has problems... Push the Air dry ,then the sani wash buttons a few times and all the lights will light, it resets the computer .
Nov 02, 2009 | Kenmore 24 in. 15079 Built-in Dishwasher
The dishwasher won't start, the clean light flashes green 7 times
I have the same problem with ours Stock #17039 Type #575-0 Model # 665.17039401
Apr 14, 2009 | Kenmore 24 in. 16029 Built-in Dishwasher
Kenmore Elite Dishwasher clean light ind flashing and won't start
You will have to reset the console. To do this, close the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
Feb 17, 2009 | Kenmore 24 in. 15142 Built-in Dishwasher
Flashing clean light
try opening the door and closeing it to aknoldge you know they are clean and is there a lock symble under the green light
Feb 10, 2009 | Kenmore Dishwashers
-high temp wash
-heated dry
-high temp wash
-heated dry
Jul 18, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Keeps flashing clean Kenmore dishwasher 665.17019401 need a new owners manual
i was trying to install my kenmore elite 665 dishwasher but i cant find the plug do they come with one? or were do i hook it up?
Sep 22, 2007 | Dishwashers
Kenmore 16602 / 16604 / 16609 Built-in Dishwasher Logo
584 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
