Preamp not working
My Audio Buddy Preamp is hissing and crackling. One input is not working at all. Through a process of elimination I have worked out the cables etc are OK.
Please advise if it is repairable and if so, an estimate of cost would be great.
Thanks
  • 682 Answers
Befor we go inside we make cleaning with lubricant contact cleaner from radio shack and apply it over all control switches while you are moving it-apply also in all sockets and put your plugs in it(in-out-in-out).after all above if not pass you have to ask for help from qualified service center.
Posted on Jul 21, 2008
My Roland FP8 plays very quietly through its own speakers, through an external amp & speaker and through the earphones. There is a hissing/crackling/static sound too from the speakers. Anyone
A number if things can be wrong with it, from the audil preamp to the the audio amplifier. Even as simple as a bad volume control. Does the actual noise change patterns when you move the volume?
Jan 03, 2015 | Roland Music
I have a problem with hiss coming from the sound bar (ZBase 550 HSD) when using my digital cable box. It is not an issue with PS3 etc. I have the sound on the cable box turned to max, but I still hear a...
Hello ZVOX Owner,
The hiss you hear is generated by the analog audio output of the cable box. The best way to eliminate this hiss to use the digital output of the cable box. The preferred way to do this is to connect the digital audio output of both your cable box and your PS3 to the your TV (I presume your TV has two digital audio inputs.)
Your TV has a digital audio output. You should connect the digital audio output of your TV to the digital input of the ZVOX.
This should reduce or eliminate the hiss and provide convenient video source selection via the TV.
From Fred P. at www.zvoxaudio.com
fred@zvoxaudio.com
Jan 27, 2011 | ZVOX ZBase 550 HSD Lowprofile SoundBase...
My behringer europower EP2500 poweramp has a bad hiss on channel 2 What could this be?
There is a possible noise build up on your CH2 due to failure or weakness of the LCR network of the preamp circuit. It could also be a noise within any semiconducctor or the preamp IC. Unless you can do a signal test with the elimination of the input to the output amplifier, the fault will not be say to isolate. Hence if youarre familiar do the test by approching from the output amplifier's input, proceeding to the main input where the faulty section can be identified. Hope this helps. Good day
Jul 18, 2010 | Behringer EUROPOWER EP2500 Amplifier
I tune on my frontman 25r and when I input I dont get any sound other than hiss.I tried two different cords and guitars but nothing but his. what should I do?
It sounds like a failure in the preamp stages, but fortunately you can do a lot of troubleshooting externally.
Drive the "power amp input" jack with another source of audio that has some reasonable output... like a small CD player. If this works (no mind the level, just the quality, that will verify if the power amp is OK.
If the power amp is OK, the use the preamp out to another amplifier.
If it is OK, then the Power amp input jack switch MAY be bad, When nothing is plugged into these, the preamp is sent to the power amp by a switch on the power amp input jack.
If you do these tests, you can email me the results and I will give further tests to run.
Nov 19, 2009 | Music
MXL 990 doesn't work
Your other preamp does not have phantom power to supply power to the microphone. All condensor mics like this need phantom power. The Audio Buddy provides phantom power, which is why it was shipped with those condensor mics
Jan 16, 2009 | M-Audio MXL 990/991 Recording Mic Duo and...
M-audio buddy feedback from mlx 990 condenser mike
Hey I Have These Mics They Work Awesome. But Yes Feedback Is A Problem You Need To Move Away From The Speakers Way Away. Try Lowering Your Highs Or Invest In A Feedback Eliminator They Are Like 89 Bucks But Obviously That Would Almost Cost As Much As The Mic Set. Anyways Feedback Is Made When A Microphone Can Hear Itself Maybe Try Headphone?
Jan 05, 2009 | M-Audio MXL 990/991 Recording Mic Duo and...
Preamp noise
Hi KenO2
First thing to check is that the phantom power is not turned on. If you are using a condenser mic, then it should. If you are using dynamic mic, then it will crackle and makes weird noises in the manner you describe. Other than that it sounds like you have a failing op amp in your preamp. This sort of repair work is not expensive(with respect to the outcome). I would anticipate $40-60 to fix it. Trouble is you can replace it super cheap at the moment 45% off for $64.95plus $9.95 shipping from zzsounds
So I guess that it may not be worth repairing, and more a replacement item for that money. If you have a mate with electronics experience, you could just replace the opamps at home for $10 worth of parts.
If you think my advice helped you to work out what to do, a FixYa rating would be great. Cheers
regards
robotek
Jul 20, 2008 | Audio Players & Recorders
Preamp Noise
The rectifier is the only thing wrong with the amp. Typically a bad rectifier will pop fuses but that is not the only thing than can cause that. You could try pulling tubes to see if you could isolate the problem. Just be careful if you haven't even taken the tubes out before, those PCB sockets are kind of flimsy. pull one tube at a time and see in the crackling goes away
I receive a radio channel in one of the outputs of the preamp
I would use sheilded wire on the mic with the least amount of cable. You can relocate the pre amp with aluminum foil wrapped around the pre amp. also turn the gain on the mic down as to eliminate any interference from your strong radio station nearby. Randy
Mar 04, 2007 | M-Audio Audio Buddy Amplifier
49 people viewed this question
 Grubhead
Grubhead
