HOTPOINT WMA74 WASHER WILL NOT DRAIN WATER - Washing Machines
  • Anonymous May 15, 2009
    got error code E30
Washing does not drain, instead water comes gushing out of the detergent tray at the top.
Posted on Nov 11, 2008
    President:
  • 1,294 Answers
Plug off the mains. You have something clogging your exit pump; have to dismantle it to clean out.
Posted on Mar 08, 2009
  • prem mathew Mar 08, 2009
    Solution was for Hillym. As for HOSSS he could do well to examine his filter.
  • prem mathew Mar 09, 2009
    Hillym, there is definately something clogging your pump. Plug off the mains. You have to dismantle to examine.
Can i run my ultima wma74 off the cold feed only?
Hi Naomi from retired Englishman in SW France,
In a word- YES!
You will need to purchase, from a hardware (?) store, a 'Y' adapter. Upside down the single end (internal thread) screws into the cold water supply and the hot and cold washer pipes screw into the double end (external threads). The washer is fooled into thinking it has hot and cold! When it expects hot, it opens its hot valve but instead gets the cold water and has to heat it up. It will therefore take longer for the machine to do the washing. When it wants cold for rinses, it opens its cold valve and gets the same water! Simple ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck,
John C
Jul 07, 2011 | Hotpoint WMA74 Front Load Washer
Hotpoint wma74 washing machine fills with water then does nothing will not run drum or spin
hello it sound like the brushes on the motor could be the cause 2 plastic blocks sit either side of the motor these are made of carbon and wear down can cause the motor to stop working also the other causes could be interlock on the door and module control board hope it helps
regards
shaun
May 24, 2011 | Hotpoint WMA74 Front Load Washer
Pumping water through soap draw
check filter is not blocked accessing it via the rear access panel. Also check no soap build up in downpipe restricting water flow. Hope this helps
Oct 10, 2010 | Hotpoint WMA74 Front Load Washer
Hotpoint wma74 wont spin
It could be the motor's carbon brushes have worn out. Replace with the same type. Need to get at the motor, you simply unscrew and slide out. If they are hard to reach then you will have to take the drive belt off and remove the motor and then take them out. These brushes provided the electricity to the motor in order for it to spin.
Aug 09, 2010 | Hotpoint WMA74 Front Load Washer
Very little water on wash cycle
water level is determined by the pressure system, and no adjustment can be made.Ensure your programe is not selected to half load.
Feb 18, 2010 | Hotpoint WMA74 Front Load Washer
Hotpoint WMA74 does not pump out after programmed
No test available other than:
Remove pump - check motor will turn by rotating impellor. There is a slight resistance then moves freely, then slight resistance and freely again. This is correct for this machine. worth checking there is no hair, elastic band or other obstruction around the impellor fins and shaft whilst the pump is out.
There is no spin cycle so you have to use rinse & spin, which means if the pump is shot you need to empty the machine each time :(
Worth checking lower filter as stated and blowing down the drain hose whilst the pump is off to check for obstructions.
The resolution to my problem was a new pump - £20.
All working fine again now !
Jan 24, 2010 | Hotpoint WMA74 Front Load Washer
Wont drain
Remove the lower rear panel of washer.
Remove the large black hose connected to bottom of drum.
Remove and clean the filter inside the hose.
Remove the hose onto the pump,and check for obstruction here and in the pump.
Hope this helps.
Dec 11, 2009 | Hotpoint WMA74 Front Load Washer
We have a Hotpint WMA74 - water gusting out of powder/liquid compartment at top when spins - have changed drain pump - but still happens - can you help?
It sounds like you have a partial blockage somewhere..
Remove rear panel.
Remove large black hose onto drum.
Check and clean filter inside hose.
Remove drain hose, and check for restriction here as well.
Please rate my solution.
Thanks.
Nov 17, 2009 | Hotpoint WMA74 Front Load Washer
My wma74 Hotpoint WM door will not open
hi the error shows bcoz of ur door problem...replace the door lock and ur problem will be solved...
rate me
Jun 12, 2009 | Hotpoint WMA74 Front Load Washer
Where can I get a manual for Hotpoint-Ariston WMA74
In your browser bar type in the following:
hotpoint user manuals, then click on manuals user guides and click on user manual , find your model and download to your computer or print it off.
Plz leave feedback for this solution.
Dec 15, 2008 | Hotpoint WMA74 Front Load Washer
Washing Machines Logo
582 people viewed this question
Top Washing Machines Experts
