Question about Maytag Washing Machines
Maytag A212 clothes washer, leaking on fill up.
Slow leak near front of machine, can't get access to inside
Possibly Injector / Vacuum break unit has gone bad (mine started spilling water lately, 20 years old). Get a 216201 to replace in your vacuum break, or better (if the machine is older) replace everything from the water valve with a kit: SUB 206680 (INJECTOR HOSE KIT).
Quite easy to get to. Just open front panel (remove two screws at bottom, lift bottom of panel away from machine and swing out. Spring clips at top should release easily. Then remove two bolts that hold top cover down and lift top. Water injector/vacuum break will be at the rear left of the machine. Costs about $40 for the kit. Or $5 for the small rubber part (but I am replacing everything that is pressurized on my machine since it is 20yrs old). -- Kevin
Posted on Jul 07, 2009
Maytag heavy duty washing machine quiet series 100 leaks water from the top panel
Older maytags were equipped with an "air-gap" that can leak if the rubber sleeve part of it gets too stiff and cannot flex. It is along the left hand side of the machine fastened by a 5/16" screw between the machine cabinet and the upper panel... Maytag Injector Tube 12001677
If you remove the front panel and set the machine to fill, you should see water dripping off of the plastic frame the injector is sitting in.
If it is a newer maytag, check the fill spout for cracks or sediment build-up Maytag Water Supply Tube WP3360977
Jun 06, 2016 | Maytag Washing Machines
Maytag clothes washer model 2500 aae leaks along bottom edge
Sounds like a hose leak inside the machine. Possibly remover front bottom cover then check all hose connections.
Nov 14, 2013 | Maytag Washing Machines
Does not wash
The arm does not move as the program does not engage the WASH cycle and it seems that the program controller unit is a suspect. You can remove the connectors and connections to the controller after noting the details and reset, If the fault repeats then the controller is a suspect. Check motor free movement, check if motor hums, if so check and replace the motor capacitor.
Jan 15, 2013 | Maytag Motor Start Switch for A212 Top...
You should post this question in the washing machine section.
Aug 25, 2012 | Computers & Internet
Maytag atlantis washer got water leaking from
I have an Atlantis myself. There can be several problems. Did you check that the fill hoses in the back are not leaking? Are they tight? There are hoses inside the washer and a pump near the front. I replaced my pump last year and I,m getting ready to replace the thrust bearing assembly (spin issues). Does the washer leak with every load? make sure water is not splashing over the tub when filling. The front panel comes off if you can and leave off and watch to see where water is coming from.
Feb 17, 2010 | Maytag Atlantis MAV6000 Top Load Washer
I'm getting water coming out of the seam on the left side between the top of the washer and the side panel. Is this hard or expensive to repair?
If the washer leaks all the time, check these:
  • Water inlet valve: If water drips even when the washer is off,check the water inlet valve. It is located inside the washer at the back of the unit. The fill hoses are attached to it. Replace if deemed necessary.
  • Water fill hoses: Check the water hoses from the household plumbing. Tighten it or replace it as necessary..
  • Main tub seal: It is located between the transmission and the outer tub. To see the leak, fill the machine with water with small amount of detergent then open up the machine's main access panel.. The leak appears at the underside of the outer tub, at or near the center. The seal is difficult to replace and you probably should call a qualified appliance repair technician.
  • Pump: You can spot the leak when the tub is full of water if the pump leaks. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. Replace it as necessary if it leaks.
  • Outer tub: The outer tub can rust, split, or be punctured.You may have to replace the entire tub but its not economical repair to do. Consult a qualified technician for deatils.
If the washer leaks only during the fill cycle, check these:
  1. Air-gap device: It is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It is located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. It is usually made of translucent plastic. If one of the air-gap components deforms or cracks, you have to replace it.
  2. The tube: It is a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
  3. Inlet spout: It is a plastic spout found on most washers near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
Oct 24, 2009 | Maytag Washing Machines
Water leaks out of the automatic dispenser
Slow down the water flow from the tap( Turn the tap on by about 1 or 2 turns). I have the same problem. the dispenser system cann't handle the volume supplied by the house system.
Sep 30, 2008 | Maytag MAH8700A Front Load Washer
Maytag washer door boot
It leaksYour washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
During drain and spin only
All the time
During fill only
Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
All the time
Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Apr 02, 2008 | Maytag MAH8700A Front Load Washer
Leaking Washer Machine
The right front corner is possibly a low spot where the water is runnung to. Two possible points of the leak are the main door boot could have a tear in it or the drain pump could have a hole. It is possible to look inside of your machine while it is running. First I must warn you to take care and not touch anything inside while there is power to your machine. First open the door and you will see 2 screws on the left and 2 screws on the right sides. one pair of screwws will mount the hinges and the other set goes through a small triangular bit of metal. remove the screws and leave the door in place. The sides of the front panel between the door and edge of the machine will rotate outward slightly and the whole front panel will pull forward. at about 45 degrees the panel can be lifted off of the lower supports and placed out of the way. You will now be able to run the machine and observe exactly where the leak is coming from. Again all of the electrical connections you see are live when the machine is plugged in so do not reach inside of your machine.
Mar 13, 2007 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
810 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
