Reply to solution.
Thank you, however it seems it is a common problem amongst the type of TV I have I'll show 2 videos of the problem.
http://youtube.com/watch?v=mgPlw-q-V9c
http://youtube.com/watch?v=3KDa6xijs08
These happened without the use of a freeview box.
  • 476 Answers
Thanks for the update of info,
I have never come across this before,
I certainly won't forget it either,
Posted on Jul 19, 2008
My microwave is not working at all. It is showing a code that says E-5 or S-5, I can't tell. What is this?
Sorry to hear your having problems! Are you able to reach the plug, if so try unplugging it and plugging back in! This may reset your microwave? If not, here are a couple of website links you might try...
www.applianceaid.com/procedures.html
www.espares.coo.uk/advice/microwaves/a/2 This one shows Videos!
Or you can do a web- search typing in: Samsung Microwave 1.8 Cu Ft Codes
If you would like me to do the searches for you, I'll be happy too, just reply back.
Kind Regards!
Martie
Sep 15, 2011 | Samsung 1.8 Cu. Ft. Over-the-Range...
Looks like it is out of convergence but the center or the picture looks fine I thought maybe pincushion or horizontal width problem
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video or dead set) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. In some cases the TV will also not show any video. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can get the correct parts, step by step photo instruction guides, and support from www.TvRepairKits.com or click here
Apr 15, 2011 | Toshiba 51H83 51" Rear Projection...
Tv showing two pictures. it is blurry and mostly blue, red in colour
ll projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
  • Screen looks 3D
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 13, 2011 | Toshiba 42H81 42" Rear Projection...
I have an external DVD player. When I plug it in the back of my RCA 20" TV/DVD combo, model BD20TF10 through rca cables there is only sound and no video. When I plug it with an S-video cable I get...
Ok, this seems to be a common problem amongst us techno-phobic couch potatos ( just kidding), sounds like tv input is not selected on right channel input. make sure pins on s-video are not bent or missing, if they are, you need a new s-video cable, try connection through the red/white/yellow cables, make sure that you have correct input selected on tv set ( example: S-video, component1 , aux 1,HDMI1, and so on.) put dvd in player and keep going till you get the right one. in ,my experience, the R/W/Y cable is component1 and of course, s-video, is well, s-video, kinda self explanatory...
Oct 17, 2010 | RCA BD20TF10 20 in. TV/DVD Combo
My Mitsubishi VS-60621 seems to have a convergence problem
Projection TV2_bing.gif sets have several common problems listed below.
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - TV2_bing.gif makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 05, 2010 | Mitsubishi VS-60621 60" Rear Projection...
What's the insid of the TV look like?
Basically, what you have is a convergence problem, very,very common amongst rear projection TVs. Here is a link to a website where the guy shows step by step including pictures on how to fix it yourself. If not, the repair costs anywhere from $250-400. Best of luck.
Greg
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
May 31, 2009 | Philips 46PP9302 46" Rear Projection...
Notebook connection to tv
S-Video - This is probably the most common method out there currently because an S-Video cable is cheap as heck and just about every TV under the sun has a S-Video port. You’ll have to make sure you laptop is equipped with this port. Remember, there are two types of S-Video cables: 4-pin and 7-pin. Most laptops and PC’s are equipped with a 7-pin port, so if your TV only has a 4-pin S-Video port, then this method will not work.
Dec 26, 2008 | HP Pavilion dv6000z Notebook
VCR shows "PLAY" on machine but doesn't show on TV
If even the sound aside from the video is not reproduced on the TV, then your description "connect" indicates that the TV is not set to receive the audio/video signals from the VCR. Initially, pls try:
  • set the TV to Channel 3 (or 4); or
  • set the TV to A/V, Video 1 or Aux 1.
Additionally, you need to confirm how the VCR is hooked to the TV unit, bu a single coaxial cable or 3 cables with RCA connectors (yellow, red & white).
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.Good luck and kind regards. Thank you for using FixYa.
Nov 02, 2008 | GE VG4054 VCR
Camera is locked up
I have found what seems to be a common thread amongst most "lock-up" or "turn camera off" problems. It seems that although we are told that we can use common alkaline batteries, once we do it is only a short matter of time before the camera begins to break down. I have found amongst my friends with the same camera who have stuck to the oxyride batteries that they are not having problems with their cameras. My suggestion, stick to the oxyride batteries. Overall they last longer anyhow, you just have to pay a little more upfront.
Hope this helps.
Oct 15, 2007 | Panasonic Lumix DMC-LZ5 Digital Camera
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
Electro Med Services...
