My beko wma1715s drum doesnt spin in any cycle , it fulls up with water then doesnt do anything, all the lights are still on and it drains, what can the problem be.
  • 187 Answers
SOURCE: Will drain but wont spin
Try these
  1. Test the lid switch
  2. Test the timer control
  3. Test the centrifugal switch
  4. Test the water level switch
  5. Inspect the motor coupler
  6. Inspect the drive belt (belt drive only)
  7. Inspect under the washer for soot (clutch)
  8. Test the motor
  9. Inspect the pulley
  10. Test the transmission
pls rate my suggestion......
Posted on Jul 23, 2009
  • 41 Answers
SOURCE: Washing machine won't rinse, drain or spin
Posted on Jan 09, 2010
  • 129 Answers
SOURCE: i had asked what to do if the agitator doesnt move
Posted on Jan 31, 2010
SOURCE: i have a beko eco care wma1613s washing machine.
sounds like the drain pump blocked or something is stuck in it stopping it from working, i took mine out, cleaned it and it works fine now
Posted on Aug 13, 2010
  • 1474 Answers
SOURCE: Beko eco care WMA1715S not working properly, it is
Sounds like could be motor/ or motor brushes....Check belt 1st
Posted on Jun 14, 2011
Have Beko WME7247W Washing Machine problem. On full wash the mc loads water then stops. Timer does not progress. Water does not heat. Drum does not turn. On Spin and Drain cycle pump works but spin does...
I had a similar sort of problem, and finally called a Beko engineer out. The machine was pushed too far back and had either blocked the water pipe, or waste pipe.... can't remember which, but simply pulling the machine out by an inch cured the problem!
Mar 09, 2014 | Beko WME7247W Washing Machine
My washing machine fills up but the drum is not spinning
Hi calex if your beko wma10w washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Also check all waste pipes are clear and inspect the pump I have included this video below.
At our website I am doing self diagnostic videos on these beko's as we speak so all tutorials will be in this link below
How to replace Beko Washing Machine Motor Carbon Brushes
you might find this test video helpful but only do it if you have checked the motor
Jan 18, 2013 | Beko Washing Machines
Machine will not go into spin cycle and or drain
Mine was not draining the water out, so popped off the panel at front and checked the filter on the bottom right side, make sure you've plenty of towels down as it will let all of the water out of the drum! Unscrew the cover and check what's inside, I found several coins, matted hair and a plastic clothes tag.
Tried to spin the towels I used and my machine was back to full working order again. It's worth a try before you spend any money on parts!!
May 01, 2012 | Beko Washing Machines
My beko washing machine smells of burning
i need a motor circuit to test the motor of a defy automaid it does not spin fast
Nov 24, 2009 | Washing Machines
Washing cycles
if you put machine on a delicates or wool wash, it will stop still full of water giving you the choice to only drain or drain and spin
Sep 10, 2008 | Zanussi ZWF1440 Front Load Washer
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Beko wma 1715s
The Child lock is in the on mode lol.....
Press and hold the two buttons quick wash and anti crease or
pre wash and extra rinse for 4-5 seconds ...Note the pre wash blinking light will go off and your machine will be ready to use again. the pre-wash blinking light indicates that the child lock has been activated......
Jan 05, 2008 | LG WM1814CW Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
