Question about Canon PIXMA MP160 All-In-One InkJet Printer
Ink lights will not go out tried everything to no avail
    Sergeant:
    Champion:
  • 214 Answers
Check the ink cartridges and try changing if required
Posted on Jul 19, 2008
I have an Epson Stylus Photo R 290 printer, connected to a continuous ink cartridge. It has two flashing red lights at the front and does not work. It is hardly more than 12 months old, and the ink ...
Sounds like a "waste ink full" error. You should get some explanation message on screen as well. Have the printer serviced. Or try to google for "epson r290 waste ink reset". Not sure if there is anything available, but worth a try.
good luck with it
LC1000
www.inkbank.com.au
Dec 02, 2010 | Epson Office Equipment & Supplies
Acts like it is printing but does not apply ink has new cartridge and goes though the motions of printing but does not seem to be getting the ink spit signal to the cartridge.
I would try another cartridge especially if it is a refilled one. I don't think there is one "ink spit" signal, rather several so one would not stop it. In any case, probably not the printer but the cartridge that is failing. The refilled cartridges somehow bypass the ink available signal from the cartridge and the printer thinks everything is ok, sending firing signals to an empty cartridge. That's why I try another or try this one in another printer, if possible. If it is something wrong in the printer, a new printer is cheaper than the repair would be.
Jul 19, 2010 | HP DeskJet 810c InkJet Printer
Ink cartridge light is blinking without need. and won't print
try to unplug the power cord let it set for about 5 to 10 min then plug it back in and turn the printer on should work fine then
Jul 23, 2009 | HP DeskJet 932c InkJet Printer
My printer has been working fine and suddenly the green light is on for a few seconds then it goes to yellow flashing, I have tried switching off, rebooting and even re installing all to no avail can any...
Had the same problem with mine. Printer couldn't even detect the printhead. I removed the ink tanksraised the grey lever and lifted the printhead out. After cleaning the copper contacts with a kleenex and contact spray (penetrating oil), I refitted everything. My i990 now works as new.
Jul 08, 2009 | Canon I990 InkJet Photo Printer
Epson 2400 paper red light and ink red light
It sounds like your printer has reached what is often called the "service required" stage...
To solve this you need to handle two things.
1. Get the printer protection counter (or waste-ink as it's sometimes called) reset.
2. Replace the waste ink pads OR redirect your waste ink flow to an external tank
It's important to note that Epson will encourage you to do a waste pad replacement through one of their service centers, but if you're out of warranty this will cost a significant amount of money (approx: $100 - 200)
To solve these as a DIY you can do the following:
1. Resetting the counter...
Get a resetter, either the SSC utility (google: epson SSC utility) or the IPR utility that Epson have now made available via their website here
The latter is only available to North American printer owners so the SSC is a safer bet.
2. Redirecting waste ink to an external container.
This is something I'd heartily recommend instead of trying to change the waste pads yourself... It's simple enough to do and a little googling using keywords "Epson R2400 waste ink tank" should get you all the info you need.
There are simple kits available that offer everything you need or you can easily go for a DIY with bits you have to hand.
Hope that helps...
Mar 07, 2009 | Epson Stylus Photo R2400 InkJet Printer
Epson Stylus C62 Error Red light wont go off
Hi victorarcas
If both lights are flashing, it means the Waste Ink Pads in your printer are saturated with ink and the waste ink ("protection") counter has exceeded its limit. The Waste Ink Pads should be replaced (see later). You can overcome this problem temporarily by using the SSC utility - download from
http://www.ssclg.com/epsone.shtml
and reset the Protection Counter. This will stop the lights flashing and restore normal operation.
However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer. A copy of the service manual is available from a number of sellers - just Google "Epson C62 Service Manual". You will often find them for sale very cheaply on E-Bay.
If you decide to have a go at replacing the ink pads yourself, report back and I will provide further help.
Please rate this solution if it has helped you
Dec 22, 2008 | Epson Stylus C62 InkJet Printer
Power light and red light keep flashing alternatively
If both lights are flashing alternately, it means the Waste Ink Pads in your printer are saturated with ink and the waste ink ("protection") counter has exceeded its limit. The Waste Ink Pads should be replaced as soon as possible. You can overcome this problem temporarily by using the SSC utilit to reset the Protection Counter. This will stop the lights flashing and restore normal operation.
Nov 03, 2008 | Epson Stylus 680 InkJet Color Printer
Ink light wont shut off
You will have to change the cartridges in the store that you have bought them, cause at least one of them is with problem in the internal circuit.
Mar 25, 2008 | HP DeskJet 5550 InkJet Printer
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
20 people viewed this question
old marine
old marine
