Heating & Cooling Logo
Posted on Jul 19, 2008
Gas Boiler will supply /fire up to supply Central heating When Room thermastat turned up and switched to Heating and Hot water. When on Hot water Only will not fire up even though thermostat on hot water tank is set correctly. Is this a faulty Thermosta on the tank ?
Anonymous
Level 1:
  • Contributor 41 Answers
  • Posted on Jul 19, 2008
Anonymous
Contributor
Level 1:
Answers
41
Questions
0
Helped
8849
Points
48
Most likly or a shorted wire unhook the wire from the boiler see if it stops then if it's still is on it's in the boiler if off try unhooking it at the t-stat on the heater this should narrow it down for you dan
  • Anonymous Jul 19, 2008
    could be. unhook the water heater wire at the boiler if it stops then try the same at the t-stat on the heater if it still runs with it unhooked at the boiler its internat dan
I have a logic combi24 boiler installed June 2016. As the weather is getting warmer I have switched my dial from central heating and hot water to just hot water. The water is not heating up.
Does the boiler fire up when the hot water tap is turned ,calling for hot water,if it does check flame has ignited ,if not then contact a p,umber as pcb may have blown.
My central heating turns off when i turn the hot water tap on. when i turn it off the central heating doesn't come back back on until i turn the power off and on.
Combi-boiler-turn hot water tap on/off and the heating stops for ...
singletrackworld.com/.../combi-boiler-turn-hot-water-tap-onoff-and-the-...
Combi-boiler-turn hot water tap on/off and the heating stops for 20secs ... hot watertakes priority over central heating so when you run the hot tap, heating is ... Yeah onmy worcester combi there is a diverter valve - it feeds either the heating or ...
My central heating works but I have no hot water - 24'7 ...
https://www.247homerescue.co.uk/my-central-heating-works-but-i-have-...
Diverter valves switch heat between the hot water and the central heating. When youturn your hot tap on, the diverter valve temporarily shuts off the water supply ...
Does your boiler keep switching itself off? Here's why ...
www.dhs-uk.com/does-your-boiler-keep-switching-itself-off-heres-why/
Jul 7, 2015 - ... Bathroom Suites, - Showers, - Wet Rooms, - Taps and Accessories, Information and ... Low water pressure can cause your boiler to turn itself off. ... boiler is not turning off, you aren't getting the amount of hot water you require. ... If there is air in your central heating system, then your boiler may shut down.
1helpful
Boiler won't ignite for hot water unless heating is on.
If this is in a RV the propane monitoring valve may require more gas flow to turn on than the water heater requires. A central heating system requires substantial gas flow so when the monitoring valve opens to fire the central heating, there is enough gas flow to also fire the water heater.
1helpful
Water to hot for gas boiler boiler gos off
It could be dyslexia, but I think you want to know what may be wrong with your boiler in this case!
This is a VERY old design. The diaphragm is on the water section, this operates a switch to turn ON the pump, and a further device causes the diverter valve to divert boiler water from CH duty to HW duty.
From your description it appears that the boiler is shutting down on internal boiler water temperature (too high), your 'briefly too hot' HW symptom may be caused either by the boiler side of the secondary heat exchanger being blocked/caked in sludge, OR the DHW side of it being scaled. Either way a new or replacement (descaled) secondary heat exchanger MAY inprove things. It's not easy on these old clunk-pots, and EVERY disturbed seal will subsequently leak, so get a good supply of o-rings and fibre seals before you start ("you" being the competant fitter you employ)
2helpful
2answers
Alpha 240e boiler wont fire up for hot water, will for heating
most likely the diverter valve.. when hot tap turned on the movement of the water through the valve operates a diaphragm which pushes a pin/button//switch to tell the boiler to fire up
2answers
No central heating back boiler
back boiler run from a gas fire? check the instructions to operate the gas heat to the back boiler not just the fire
I presume that this a fully pumped system - air lock doubtful There maybe on/off valves on the pipes to and from the back boiler [situate close to cylinder] make sure they are on - anticlockwise turn
or there could be a blockage in the outlet from header tank usually in the loft. or If there is no water in it maybe the mains cold feed it is off.
Note if no water in it DO NOT USE the back boiler
Central heating system boiling
more information required but if the boiler supplies the domestic hot water cylinder then the stat on the cylinder may be bringing on the boiler also the boiler stat may be up too high try turning it down.
Top Heating & Cooling Experts
Paul Carew
john h
