Trace the upper Radiator hose from the radiator back to the engine. The location where that attaches to the motor is actually a cap assembly being held in place with 2 to 3 bolts. Remove that and remove any remaining seal and the Thermostat. Insert the new thermostat and place the new seal in place and replace the Assembly tightening the bolts down. Reconnect the hose and fill the radiator then test run the engine and check for leaks. If nothing leaks your done. Should take about 30 minutes.
Fig. Thermostat and housing-typical To install:
