Question about Nintendo Wii Console
Internet connection I have bought a usb ethanet adapter and connected the wii to my network. I have gone to connection 3 and tried to connect to the internet, but when it does the connectivity test I get an error 51422 and it cannot establish a connection. The adapter shows a 100 connection speed. I have loaded the ip address manually but it still does not connect. Any helpt would be appreciated.
  • 1 more comment
  • duncan_d Jul 20, 2008
    I'm plugging from usb adapter straight to the router. I know the connection works as when I plug the laptop to it, I get internet connection
  • sojampit1 Jan 16, 2009
    hi, i am using sonny ericson p800 ,it always reply with 519 location.Having gone through locations ,i cannot find my location, nigeria.
    Thanks,
    soji ibikunle
  • Simon Crouch
    Simon Crouch May 11, 2010
    Hi duncan_d,
    What are you plugging the other end of the usb ethanet adapter into? A router or a PC?
    Problem Solver:
  • 18 Answers
Hi duncan_d,
There's one thing to check, if you can, try and access the internet with the wii and then on your laptop access the routers set-up page and just check the wii has an active session, it might also be a good idea to assign the wii a static IP address.
Assuming this is still not working, turn the Wii completly off (at the wall), leave for 10 seconds and turn back on. The Wii has a version of a linux operating system running on it, by rebooting it reloads a lot of modules, it might have been that the module that controls the usb or the network had stalled.
Beyond that, it would be a case of calling ninetendo. I know there are a lot of issues with the Wii's networking.
Posted on Jul 20, 2008
How do u get internet on your wii
Here are step by step instructions on how to connect your Nintendo Wii to the internet. Please note you will need access to a wireless internet connection, or must have a wireless router in order to connect your Wii to the internet. The Wii only connects via wireless signal!
http://www.nintendo.com/consumer/systems/wii/en_na/getOnline/index.jsp
Sep 04, 2011 | Nintendo Wii Console
Error code 51420 on my wii console. I am trying to establish a connection to the internet. I have a router which is working properly because i can get on the internet now. I have ran my ethernet cable...
Error Code: 51420 The Wii console is not able to connect to your wired router or modem.
  1. If your connection worked previously, check to see if there is a Wii System Update that you have not aquired. To get the latest Wii System Update:
    1. From the Wii's main menu, select the Wii icon along the bottom left of the screen.
    2. Select "Wii Settings".
    3. Click the left arrow to get to Wii System Settings 3
    4. Choose "Wii System Update"
    5. Choose "Yes" to connect to the internet and perform a Wii system update.
  2. Make sure that you are using the Wii LAN Adapter made by Nintendo. LAN adapters not made by Nintendo likely will not work with the Wii console.
  3. Check to make sure you are not running the Wii LAN Adapter from a USB hub (a device that connects multiple USB products through a single device), as this will likely not work. Connect the USB Connector directly to the modem or router.
  4. Ensure that the Wii LAN Adapter setup is correct, and that the Wii LAN Adapter was connected with the console turned off.
  5. Check to see if the ethernet cable you are using is not working properly, by connecting another ethernet cable from your router/modem to the Wii LAN Adapter. If the connection works using a different cable, then the problem was with the first cable.
  6. If possible, try another Wii LAN Adapter. If you are unable to try another Wii LAN Adapter, or are still receiving this error code, please call 1-800-255-3700 for assistance.
Jun 22, 2011 | Nintendo Wii Console
My wire internet is not connecting to my wii what can i do so i can get the internet to work on my wii judy
  2. Make sure that you are using the Wii LAN Adapter made by Nintendo (click here for a picture and connection steps). LAN adapters not made by Nintendo likely will not work with the Wii console.
  4. Ensure that the Wii LAN Adapter setup is correct, and that the Wii LAN Adapter was connected with the console turned off. For step by step connection instructions, please click here.
Jun 04, 2011 | Nintendo Wii Console
Where is the place you can put the internet connector in to ? is it on the back of the console or is it on the top i cant find it please help me
The wii does not come with an ethernet port (or place to connect to wired internet) built in. It's primary internet connection is through wifi or wireless internet. A USB adapter can be bought (like these) Those plug into the back of the console in the usb port.
Jun 01, 2011 | Nintendo Wii Console
Trying to connect with a wired connection that works because i know i use it for my xbox but it says something like code error 51420
not every USB to Ethernet adapter works for the Wii. Here's what I've found from Nintendo's site. You may need to connect with your Wi-Fi and update it first.
Error Code: 51420
Apr 03, 2011 | Nintendo Wii Console
Bought a pre owned wii and im trying to hook it to the internet but it says error 52020
What to do will depend on how you are connecting your Wii console. Please use the info below that describes how you are connecting.
Connecting directly to a modem:
1. Power off the Wii. Connect the official Nintendo Wii LAN adapter to the Wii, and insert a working ethernet cable into the official Nintendo Wii LAN Adapter.
2. Unplug all devices from your modem. Most modems are unable to support more than one device at a time.
3. Power cycle your modem. To do this, unplug the power from your modem and let it rest for 20 seconds. Plug the power back in. Connect the Ethernet cable from your Wii console to the Ethernet port on your modem.
4. If the connection test fails, try a Manual Setup with the Wii console, using your network's IP address, Default Gateway, Subnet Mask, and DNS information. To access these settings:
1. On your PC, click "Start" and then "Run."
2. Type "CMD" into the field that appears to open a new window.
3. Type "IPCONFIG/ALL" and press "Enter" to display a list of internet settings, including the settings listed above. Input these exactly as they're listed into the "Manual Setup" of the Wii console's internet connection.
5. If you are still unable to connect and you are using broadband Internet, then your ISP likely uses PPPoE to establish a connection to their network. The Wii is not compatible with PPPoE.
Mar 15, 2011 | Nintendo Wii Console
I am trying to hook my wii to the internet and it is saying unable to connect error code 51420 and i need free advice or help.
For any help click here
Jan 04, 2011 | Nintendo Video Game Consoles & Games
System will not connect to internet error code shows 51421
This is a rare problem ............ i faced similar kind of problem
i solved my problem with the help this repair guide you can also try this out i hope this will help you a lot .......
all the best
Click Here
Aug 23, 2010 | Nintendo Wii Console
Unable to connect to internet
Jul 06, 2010 | Nintendo Wii Console
Error code 51420
Fiend your solution direct from nintendo. Here is your solution....
http://www.nintendo.com/wiiconsole/prob676ijt65/solution
oishuk13
Dec 26, 2009 | Nintendo Wii Console
Nintendo Wii Console Logo
121 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
phil
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
