Question about Philips 43PP9202 43" Rear Projection Television
Convergance Problem Troubleshooting
I'm having convergence problems. I pulled out the board that has the converg. IC's and I'm getting some new IC's soon, but I have read in other threads that the resistors may also be a problem. I see a bunch of big, probably 1 watt, resistors around the area. Is there anyone with a schematic so I can test these resistors. I guess I could de-solder the end of each resistor, but that would take a while. Service manual or schematic would be of great use.
43PP929017 Phillips tv
  • Philips Master
  • 8,617 Answers
Check resistors 3149 through 3160 they are 6.8 ohm 1watt 5% metal film resistors
Posted on Jul 19, 2008
Service code
Its almost always a convergance inverter that has burned out. The IC chips as they are called aren't too cheap, Even the repair shop would suggest a new tv as a cheaper route in the long run. To make your set reliable again the convergance board needs to be rebuilt with all new chips, and pico fuses.
Oct 08, 2012 | Zenith R49W36 49" Rear Projection HDTV
Convergence problem
Usually what happens is that the convergence IC goes bad or the fuse going to the convergence ic goes bad. Pico fuses they are called sometimes open up. You may want to open it up and pull the board out and check the solder connections on the convergence IC. Sometimes these get fractured or cold soldered and aren't making connection to the PC board.
Let me know if you feel comfortable with pulling TV chassis out or pulling the board that has the convergence IC on it out. Then you can resolder convergence IC OR replace it.First thing i would do is check to make sure there is between 22vdc and 25vdc on the fuse or the convergence IC. Let me know if this helps out any.... Sincerely HDTV GURU JAY
Mar 17, 2011 | Sony KP-57WS510 57" Rear Projection HDTV
CLASS HD Convergance ploblem
You need to replace STK ics which are convergence ICs in your tv
You can get from the link below
Click this link to get convergence IC
It will cost you $20-30 to buy these IC .
Jan 30, 2009 | JVC AV-48WP74 48" Rear Projection...
Hutachi 43inch rear projection 5 yrs old
Hitachi Convergence
Check out the Convergence Gallery. If you see the colored outlines or color shading as in the Gallery, you have a convergence problem.
The repair for a Hitachi requires the replacement of the defective IC or ICs and any damaged or smoked resistors. Some models don't have a separate convergence board and the board is not usually available for the ones that do have a separate convergence board. Usually there is little alignment required after the repair. If you play with all the adjustments before the fix, hours may be spent re-aligning.
If you change the original ICs with substitute "new and improved" parts that are talked about in the blogs, you will probably create problems. Use the original ICs and resistors.
Don't monkey with it.
This is a delicate and difficult repair. If not done by someone with some electronic repair experience, the TV will likely end up as junk or cost considerably more for a tech to fix the damage done.
If you live in Calgary, call me. If elsewhere, find a competent tech.
easyab
Jul 30, 2008 | Samsung HCN4226W 42" Rear Projection...
Convergance chip
Thats the regulator chip for the convergence circuits thats the one youre most likely needing, as your chassis doesnt have convergence ICs. You can get that IC at the following link and they will provide free installation instructions and free on line tech support just in case you need assistance. Here is the link.
http://servicemanuals.vstore.ca/
Apr 23, 2008 | GE 46GW947 46" Rear Projection Television
Repeated chip failure
are the resisters ok?
i might suggest sending the board into ptscorp.com
Feb 04, 2008 | Zenith Z60Z83R 60" Rear Projection...
Dark picture and greener than normal
hmmm curious why you would adjust convergance to adjust a dark picture?press menu button on remote and scroll down
are you have convergance problems?
convergance amp ic are know to go bad with this set.
Dec 17, 2007 | Toshiba 53H71 53 in. Rear Projection...
KP46V15 Convergence problem
You must have checked fusible resistor?
check convergance control panel and check voltage supply to this board.If voltage are o.k than you have to change convergance control ic which is smd ic and its on the control board.
Gopal
Dec 10, 2007 | Sony KP-46V35 TV
Tv is dead
Hi, Yes! the convergance board can stop the unit from coming On. No need to change the board, just change the ICs. This is what it looks like,you will have to remove the board from the unit take note of the wires before removing them, -794a500.jpg
Nov 14, 2007 | Samsung HCN4226W 42" Rear Projection...
Philips 43PP9202 43" Rear Projection Television Logo
56 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
