Question about HP Officejet 5610 All-In-One InkJet Printer
REGISTRY REQUIRED for HP 5610 all-in-one.
I'm on step 15 of the instructions, where i've inserted the correct CD, for the HP 5610 all-in-one printer/scanner/ etc. machine. An error message comes up saying that a registry(s) is required. Lots of add'l info, however, so far, can you help ? My computer is a HP Pavilion dv6000 laptop.
    Sergeant:
    Champion:
  • 214 Answers
It seems you are not connected to internet. if you haven't click on exit and select register later or don't remind me again
Posted on Jul 19, 2008
HP5600 print cartridge- error- message
http://cluetechnologies.com/index.php?topic=688.0
Insert the correct CD
Windows Users:
a Insert the gray HP All-in-
One Macintosh CD.
b Continue to the next page.
a Insert the green HP All-in-One
Windows CD.
b Follow the onscreen
instructions to install the
software.
c On the Connection Type
screen, make sure to select
directly to this computer .
Note : If the startup screen does not appear after you
insert the CD, double-click My Computer , doubleclick
the CD-ROM icon, and then double-click
setup.exe .
Jul 01, 2010 | HP Officejet 5610 All-In-One InkJet...
Can not scan
When this happen it is usually the USB cable. When this happen it is usually a problem with the USB cable. If
communication on USB cable is bad, as a result you can print but not
scan.Having also messed up a bit with the drivers ("HP digital
monitoring icon anymore"), you may also need to reinstall the driver.
My suggestion on how to proceed is the following.
Buy a better usb cable, the shilded ones cost a couple of dollars more but guarantee better communication.
Unplug printer from usb.
Unplug computer and printer from power for two minutes.
Plug back computer and printer to power, DO NOT plug in USB cable yet, leave printer NOT connected to pc.
Reinstall
drivers and software, keep printer disconnected until connection is
explicitely required by printer software installation process, or after
installing.
Connect printer when required.
Check that there is no
electric device (power adapters, extension etc.) very near to printer
USB cable, they can cause electromagnetic disturbance.
Try scanning. If it does not work at thhis point is either a problem with windows (new windows install required) or a faulty scanner.
Jul 29, 2008 | HP Officejet 5610 All-In-One InkJet...
My cd reader in my hp pavilion dv6000 is not reading properly. when i put in a cd i see the little green light blinking and i hear the cd spinning but thats all it does.
sorry to tell you but your Cd drive is bad it is fairly cheap and easy to install usually two screws and give the drive a little yank and it should pop out you can purchase the CD drive online try ebay good luck but make sure first im not sure if maybe you think that something is supposed to happen every time you insert a cd it does not insert your CD go to my computer and try to access the drive if you can browse the files then your drive is ok sounds like you need to enable Autoplay a feture that enables something to happen when you insert your cd but you probaly know all that ...
Nov 03, 2009 | HP Pavilion dv6000z Notebook
It says o HP product detected
If you have the CD then insert in and do a right explore, then look for a folder named UTIL and under that u will find CCC and under ccc u will fine something called unintsalll2.bat just run that file
then restart the computer and then insert the CD and follow the instruction to get it fixes
Oct 16, 2009 | HP Officejet 5610 All-In-One InkJet...
Lost instruction manual for hp 5610 copier. Where
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.hp.com/printer/prob676ijt65/solution
aber12
Aug 31, 2009 | HP Officejet 5610 All-In-One InkJet...
Using win-xp how to manualy uninstall program and correct the registry
Your image mentions an HP device. If you are trying to remove Hp Drivers, you MAY want to insert the CD that came with the printer and choose the Uninstall option. If there is no such option, then consider following these steps:
http://www.out-of-warranty.com/three-ways-to-uninstall-and-reinstall-hp
Jun 30, 2009 | HP LaserJet 3050 All-In-One Printer
Acer aspire 5610 dvdram wont recognize any cd/dvds i put in it
To resolve this problem, remove the affected filter drivers. To do this, follow these steps:
1. Click StartStart button, type regedit in the Start Search box, and then click regedit in the Programs list.
User Account Control permission If you are prompted for an administrator password or confirmation, type your password, or click Continue.
2. Locate, and then click the following registry subkey:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-
08002BE10318}
Caution There can be many instances of the registry subkey that is mentioned in step 2. You must make sure that you are in the appropriate registry subkey before modifying the UpperFilters and the LowerFilters values. To verify that you are in the appropriate registry subkey, make sure that the Default data value is DVD/CD-ROM and the Class data value is CDROM.
3. In the right pane, right-click UpperFilters, and then click Delete.
4. Click Yes to confirm the removal of the UpperFilters registry entry.
5. In the right pane, right-click LowerFilters, and then click Delete.
6. Click Yes to confirm the removal of the LowerFilters registry entry.
7. Exit Registry Editor, and then restart the computer
Mar 17, 2009 | Acer Aspire 5610 Notebook
C4400 printer will not install, error 1935 fatal error alert.
Hi Swreardon,
How are you doing?
The issue which you have posted will generally occur if there is a WinTools Easy Installer program on your computer or even it occurs due to corrupted registry.
I can provide you the complete solution but for your clear understanding of the solution and to have a clear view of the solution so that you can easily perform the troubleshooting let me provide you with the weblink which ahs clear instructions:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00292756&cc=us&lc=en&dlc=en
Before using above weblink make sure you perform the steps below :
Step 1: Insert the HP printer software CD in the CD drive and folllow the steps:
If operating system is XP, Start>>run>> type" X:/util/ccc/uninstall_L3.exe and click OK. (where X is the Cd drive ) and follow the onscreen instructions.
If the operating system is Vista: open run window and type: " X:/util/ccc/uninstall_L3.exe" and click OK. (where X is the Cd drive ) and follow the onscreen instructions.
Here are the multiple steps to open run window in vista:
1. Press Windows Key + R to open the Run command window.
1. Open the Start Menu.
2. Click All Programs.
3. Click Accessories.
4. Run shortcut is located here by default.
Step 2: restart the computer and follow the steps given in the weblink above:
Step 3: once everything is completed download nad install the software by clicking on the weblink below:
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&dlc=en&cc=us&product=3655574 (For XP)
and use this link for Vista: http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=mp-57266-3&lc=en&dlc=en&cc=us&os=2093&product=3655574
Do not use the CD.
I am sure the issue will be resolved.
Best of luck.
Oct 25, 2008 | HP Office Equipment & Supplies
My cd rom will not play acd it as encountered a problem
You can Try these Steps :-
Normal 0 false false false MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Method 1: Remove the Adaptec CD-Burning Plug-in in Media Player version 7.x
Follow the steps below to remove the Adaptec CD-Burning Plug-in from Media Player version 7.x. Windows Media Player version 8 that came pre-installed in Windows XP does not display this issue.
Click Start , Settings , and then Control Panel .
Double-click Add/Remove Programs .
If installed, Windows Media Player 7.x will be presented in the list.
Click the Change/Remove button.
The Windows Media Component Setup window should be displayed. The radio button next to Remove Windows Media Player components should be selected. Click Next .
Place a check in the box next to Adaptec CD-Burning Plug-in . Click Next .
The Adaptec CD-Burning Plug-in will be removed from the computer. Click Restart to complete the operation.
Method 2: Removing the Upper and Lower Filter registry keys
The second method for resolving this issue is to remove the registry keys associated with the loading of CD recording drivers. Follow the steps below precisely to resolve the issue. Exporting the registry is imperative before making any changes to the registry. If mistakes are made during the editing process, the registry can normally be repaired with the exported registry.
Step 1: Remove upper and lower filters
The steps below describe how to remove the drivers associated with the drives disappearing. After removing the filter driver keys, the CD recording software will be have to be re-installed.
With a copy of the registry exported, click the plus signs [+] in front of the follow keys in the order they are listed: HKEY_LOCAL_MACHINE , SYSTEM , and then ControlSet . In some cases, multiple ControlSets may be listed similar to the following:
HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001
HKEY_LOCAL_MACHINE\SYSTEM\ControlSet002
or
Click the plus sign [+] in front of either CurrentControlSet or the lowest numbered ControlSet. For example, in the second list above, ControlSet001 would be the correct listing.
Click the plus sign [+] in front of Control.
Click the plus sign [+] in front of Class.
Locate the following key and highlight it in the left window of the Registry Editor (The numbers can be very similar, be careful select the correct key. Another method to find the correct key is to highlight Class, then cut and paste the key below into a Find window accessed from Edit and Find in the Registry Editor.)
{4D36E965-E325-11CE-BFC1-08002BE10318}
With the key highlighted, the right pane will have multiple keys listed including LowerFilters and UpperFilters. Highlight LowerFilters and press the Delete (Del) on the keyboard. A confirmation dialog box will be displayed asking if the value should be deleted. Click Yes to delete the value.
Repeat the process for the UpperFilters by highlighting UpperFilters, pressing the Delete (Del) key on the keyboard and again confirming the value should be deleted by clicking Yes.
Exit the Registry Editor
Restart the computer. The optical drives should then be recognized and available for use.
NOTE:- If the computer still does not recognize the drives, go back into the registry and repeat the above steps for editing the registry for each of the ControlSets listed on the customer’s system.
Step2: Reinstall the HP DVD / CD-Writer software
Deleting the LowerFilters and UpperFilters will prevent the previously installed recording software from operating successfully. The software that came with the HP CD-Writer or DVD Writer will need to be re-installed to function correctly. Follow the instructions included with your CD-Writer to re-install the software.
Oct 07, 2008 | Computers & Internet
Printer not installing correctly
Yes, and install software with printer diconnected fro pc untill new software instal instructs to connect
Also ensure you have not just print drivers but scanning software they are different things that both need to be installed to enable scanning
Oct 27, 2007 | Office Equipment & Supplies
HP Officejet 5610 All-In-One InkJet Printer Logo
42 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
