I have 2 gb Kingston memory card I use in both a Nikon Coolpix and a Panasonic Lumix camera. The card as many pictures on it, yet when I put it in my HP Photosmart printer to upload these pictures it says there are no files on it and the drive doesn't show up when I go to "Explore" and look for the drive to show up. Any suggestions???I have 2 gb Kingston memory card I use in both a Nikon Coolpix and a Panasonic Lumix camera. The card as many pictures on it, yet when I put it in my HP Photosmart printer to upload these pictures it says there are no files on it and the drive doesn't show up when I go to "Explore" and look for the drive to show up. Any suggestions???
You can't post conmments that contain an email address.
Sounds like the card reader or the memory card is faulty. would suggest testing the card reader with another card if you have one.
if its the memory card, a data recovery program may work for retrieving the information..
TRANSFERRING PHOTOS TO COMPUTER If your photos are stored on the memory card, then removethe memory card from the camera and insert it into an USB memory card reader.Connect this USB memory card reader and memory card into the USB port of yourworking computer. Your computer will see this as an USB Mass Storage Device oran external storage device; you can then open the folder on the memory card andcopy the photos to your computer.Memory card reader is a handy device and is inexpensive. Youcan copy photos from other cameras and you can also download photos off yourmemory card to someone else's computer without the need of installing anyprograms.
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
i have had that issue have you tried a different card, if the problem persist there something wrong with the insert dirty or damaged they normal give you a blank one that ant real too keep in there too keep it clean.
The internal memory is small. Your camera will continue to write to it until you erase the pics from it. Here's how...Remove the memory card. Download any pics you want to save from the internal memory. Go into the menu and find "format"...follow the on-screen instructions to erase the internal memory. Insert your card. It should work properly now. Promise yourself to never use the internal memory again.
Write Protection: There is a tab on the memory card so you will you need to remove it from the camera and change the position of this tab to "unlock" it.
Try to open the files with a computer. Then try formatting it. For that 1. Click Start->Run 2. Type CMD in RUN 3. Then the DOS prompt will appear.then give the command for formatting......ie, c:/>format H: /fs:fat32 *where c:/> is 'C' prompt H: is Memory Card drive letter FAT32 is file system
If you transfer the photos to your computer from the camera, you should be able to save to another memory card. I can't say whether or not the photos on the new memory card will show up on your camera since there may be certain requirements to display on camera screen.
Plug your camera into the computer USB or insert old memory card. A box should pop up giving you the option to view files. Copy and Paste (or Drag) selected photos to a specified folder on your computer (Like My Pictures in My Documents). Insert new memory card. Copy and Paste (or Drag) selected photos to the drive for your memory card.
