Question about Ricoh Aficio 450 Copier
Rico afficio 450
I purchased rico afficio 450 surplus but the copy of the machine is too very light can somebody help me how to make it darker... i olridy try to make it darker in the darker option.... it make dark but not so good... i try to enter the 107 program initialize the developer.initialize the ID sensor,set the the toner rate 30g/s... is der other ways to make it copy like as good as original......pllllllllllllllllzzzzzzzzzzzzzzzzzzzzzzzz....
  • 7 more comments
  • thraser
    thraser Jul 20, 2008
    mrbonz can u send me a default settings of service mode so dat i can check my service mode setting.... tenkz in advance... default settings of Afficio 450
  • thraser
    tenk mrbonz is their other way i can set it default automatically or i nid to manually check it one by one... tenkz a lotz mrbonz ....hope ul help me in my problemz.....i use toner afficio 350 but im not sure for my developer if itz original or replacement refill...bcuz the copy of my machine is too very light...
  • thraser
    mrbonz wat will i do my affico 450 wen i return the toner cartridge the machine copy so very dirty maybe it cause overtoner... is their way i can fix this...plz help tenkz in advance
  • thraser
    thraser Jul 21, 2008
    yeah tenkz... this is the problem when we put the toner back it causes overtoner now the toner is all over the drum now but the copy is stil lighter... what shall i do to fix this ....????
  • thraser
    yeah now wat im gonna do cuz the copy of my machine is dirty now and the txt is too light... they said overtoner....bcuz the toner is all over the drum ...??
  • thraser
    toink.... mrbonz can u help me cuz my machine is totally mess..i canot us my machine... the whole paper is dirty and the copy is too light...pppppppppppplllllllllllllllllllllllllzzzzzzzzzzz give me an idea how to fix this... tenkz a lot 4 sharing ur knowledge ...
  • thraser
    thraser Aug 05, 2008
    elow mrbonz is der a way i can check how old is my afficio machine... wat year it was made??
  • thraser
    tenkz but the tag onli indicate the model of machine,code,wer it made.. and serial no...is der oder way may i know wat year the machine made cuz im planing to by agen a new surplus machine im tired of my old machine i bought frm a frnd?
  • thraser
    thraser Aug 19, 2008
    mr bonz how can i align the camera lense of my afficio 450 bcoz i cleane it up when i return it bak it print but no copy at all just white bondpaper came out....the big problem is that i dont know wer to align the camera lense and the lense after the camera..plzzzzzz help me
  • 42 Answers
Dev. initialize should only be done when replacing dev.otherwise it will not add the correct amount of toner to the dev.Replace developer and run sim.2-801 in service mode.
Posted on Jul 19, 2008
  • 4 more comments
  • Hadley Hudson Jul 20, 2008
    Sp mode 5-990 (SMC Data Lists).This will print out all the settings with the default.Hope that helps!
    First,I forgot to have you check something.When you get a new toner it comes with a black cap.Remove cap and under cap you will see a plug under where you took off the cap.If old bottle is missing the plug it is stuck in toner hopper blocking the toner from going in!If so,remove plug and stick it back on top of toner bottle, then reinstall toner,run 40 blank copies to see if darker.Now,if not stick a folded piece of paper in door interlock(hole inside front lelf)run 20 copies and see if toner bottle turns.This is key because if it does not turn it's not adding toner.By the way,messy toner hopper is normal. Let me know!
  • Hadley Hudson Jul 21, 2008
    yeah tenkz-meaning plug was the problem?
    Ok. Pull toner hopper all the way out of the copier.There is a small black plastic piece on the steel slide of the left side of the hopper,pop it off to pull hopper all the way out.Run 40 to 50 copies without hopper and check drum.This will pull toner out of the developer and de-tone the machine.Stop there and let me know.
  • Hadley Hudson Aug 05, 2008
    Inside the right door on the metal frame is a tag with the make,model and year.I beleive it came out in 1998.
  • Hadley Hudson Aug 06, 2008
    Sorry, that's the only place I know of to look and it should be there.My service manual says the machine was introduced in 1998.
Parts and consumable of afficio 450
http://www.ricoh.com.ph/support/contact.html
Sep 07, 2009 | Ricoh Aficio 450 Copier
Afficio450 replace new developer unit wat procedure to be follow?
No, the 450 is just one of those machines that seem to have PCQ no matter what you do. Given light copies, I'd replace the drum for sure and make sure your ID sensor isn't covered with toner. Dust covered optics will also cause light copies on this model.
Jul 25, 2009 | Office Equipment & Supplies
Afficio 450 olridy change developer but the copy is stil faded
There are two service codes that you need to run 2801 and 2805 after you put the developer in the machine.
Press the yellow button on the copier. press 107 on the keyboard. Press and hold the clear button. Then run the service codes.
You have to run the codes first after changing the developer. You might have to replace the developer again to get the correct mixture.
Jan 26, 2009 | Ricoh Aficio 450 Copier
Afficio 450 copy faded in some area...
If the image is good in parts, but light in others it is most often toner build up on the laser exposure glass which can be easily -but also VERY CAREFULLYremoved. If you lift the green handle for the toner bottle, you should see a narrow piece of glass protruding just underneath. You can grasp it with you fingers and slide it out for cleaning. Sometimes these have been removed (or broken) so they are not there. If the machine is also a printer, you should see much improvement (if this was the cause). If regular copying is still light in areas, then you may want to remove the copier glass - 2 screws on left scale, and 3 screws on rear scale (POWER OFF ON MACHINE), remove glass and clean with glass cleaner, then slide scanner to the left and clean the mirrors.
Hope this helps.
Jan 17, 2009 | Ricoh Aficio 450 Copier
The copy of afficio 450 become lighter
You may want to consider putting developer into the unit. What is the copy count on the machine?
Jan 15, 2009 | Ricoh Aficio 450 Copier
Afficio 450e gray copy or lighter copy
Look into replacing the developer in your copier. It has to be replaced every 125,000 cycles.
Jan 14, 2009 | Office Equipment & Supplies
Afficio 450 seeting
Auto setting. If you are getting light copies, you might need the developer replaced as well.
Aug 21, 2008 | Office Equipment & Supplies
Afficio 450
Goto to copytechnet.com. Someone can help you locate the error codes you are looking for. That one is supported by copier technicians.
Aug 05, 2008 | Ricoh Aficio 450 Copier
Developer....
When developer goes bad you use more toner for one thing, but the main sign is a gray background in your copy. The print should be black but appears to be gray. The ricoh 350/450 was always noted to leak toner and developer as it runs. Check your machine and see if you see any small piles of toner, which also has developer in it, in the machine. Ther are small seals made of felt that need to be replaced if you have this problem. These seals rub against the drum sides....Good luck.
Jul 20, 2008 | Ricoh Aficio 450 Copier
Fuser..?? afficio 450
The fuser probably will not help. I think you probably will need a PCU, and a service call.
Ricoh Aficio 450 Copier Logo
261 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Bernard D'Souza
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
