Question about Praktica Cameras
PRAKTICA LTL3 EPX13 WHAT VOLTAGE BATTERY CAN I CONVERT TO TEST IF CAMERA WORKS?
    President:
  • 1,114 Answers
Hi you will find all the information you need on the link underlined in blue below:
LTL3 EPX13
Please update the question & let us know if the information given was useful to you - Good Luck!
Posted on Jul 19, 2008
Are the batteries in praktica dc42 rechargeable
If you have used re-chargeable batteries in the past, yes, otherwise no. If you consult the manual, you will find the correct type of batteries to use.
May 04, 2017 | Praktica Cameras
Praktica 1600a
NO!!!!!
The flash's trigger voltage is much too high and will quickly fry the camera.
If you really want to use it, you need something like http://www.bhphotovideo.com/c/product/245292-REG/Wein_W990560_Safe_Sync_Hot_Shoe_to.html
to isolate the two units.
Jan 27, 2014 | Nikon Photography
The battery cover as bowed i need to keep my finger pressed on the cover to take pictures if i dont keep my finger pressed on the battery cover the camera swiches off
it seems the battery box are a little loose for the battery, you can add some thing(such as small piece ) between the battery and the box to let the battery and camera connect well. Don't block the joint between battery and box is OK
Apr 25, 2011 | Praktica Cameras
Praktica dcz 8lm camera: when turned on the light comes on for a second then goes straight back off again. won't take pictures or allow you to view pictures on pc
Your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced, or the camera may have a problem that requires professional repair.
Nov 13, 2009 | Praktica DCZ Digital Camera
Praktica slimpix battery doesn't charge,usb connections ok,green light comes on on camera,but goes out as soon as i disconnected usb lead.
That is correct. The camera does not recharge the batteries. If you are using rechargeable batteries then you also need a compatible battery charger for the batteries you are using.
Jun 26, 2009 | Praktica SlimPix Digital Camera
I NEED SOFTWARE FOR PRAKTICA MICROPIX CAMERA CAN YOU HELP
Check here:
http://www.praktica.de/index.php?id=173&L=1
Jul 11, 2008 | Praktica MicroPix Digital Camera
Using battery charger overseas
it's alway suggested that you simply use plug adaptors to change shape of plugs for overseas-do not reduce voltage since most all chargers including yours support 220 or 110
Jun 07, 2008 | Cameras
Cameras Logo
144 people viewed this question
Top Praktica Cameras Experts
Are you a Praktica Camera Expert? Answer questions, earn points and help others
