I have no sound from my computer and and cannot find how and where to connect my leads in the back on the motherboard
    Genius:
  • 2,785 Answers
Your green jack will go to green port.
Plz reinstall the drivers for the sound from the mother board cd
Posted on Jul 19, 2008
No video - push power button sounds that it boots up but no video
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your (motherboard to your hard drive) make sure they have secure dust free connections and are not faulty
if its a 40 pin flat ribbon type it will be the first to fail
make sure all leads that are attached to your drives dvd\cd and floppy have secure connections and are not faulty
even something as small as a faulty electrical fan and its lead can cause you problems
computers need all power and data to continue through every working device and to have an end so any faulty leads will end up with a computer error
Check your RAM.
The RAM is located in the middle of the motherboard.
There are tabs that you can push to release the RAM.
Remove it and put it back in place until the tabs pop out.
Loose RAM can cause your computer not to start properly where you want to see a video signal.
Remove the memory modules from their slots.
Take the opportunity to clean the slots on the motherboards and the memory module connectors.
Use compressed air to blow dust away and clean contacts with a soft cloth.
Do not use a metallic vacuum cleaner if it touches any component it may create a short and cause damage to the motherboard or other components.
Do not use solvent that may attract dust and never poke things like cotton buds in to slots, lightly rub alcohol (Methylated Spirits) on a cloth not to hard let the alcohol do the work on the copper gold or silver tabs and r
Allow the pins to dry.
They will air dry in a matter of minutes.
If reseating the memory did not resolve the issue try swapping the location of the memory. Make sure your graphics card is securely seated with no dust built up or in the socket
if you remove your graphics check the socket to make sure its dust free
Restart your computer then reinstall it this should activate found new hardware wizard
Check the vga lead for secure dust free connection or try another vga lead.
Mar 25, 2014 | HP Pavilion m7760n PC Desktop
The picture is either distorted, fuzzy, or goes off, and on. The sound also goes off, and on.
Which operating system ?
Check your RAM.
Do not use solvent that may attract dust and never poke things like cotton buds in to slots, lightly rub an alcohol (Methylated Spirits) on a cloth not to hard let the alcohol do the work on the copper gold or silver tabs and r
Click start control panel administration tools computer management device manager scroll to display adapters + to expand you might see a yellow question mark ? or exclamation mark ! or a red Xright click select reinstall drivers
If your computer came with a motherboard disc the drivers could be on it
if you dont have a motherboard disk you will need to download the drivers
Dec 29, 2013 | Computers & Internet
Dell Precision 5500 desktop will not turn on.
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules
The leads from your MOTHERBOARD TO YOUR HARD DRIVE make sure they have secure dust free connections and are not faulty. Any bad or faulty power or data lead or connection can cause a computer not boot up.
Motherboard and a Hard Drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail.
Make sure all leads that are attached to your drives dvd\cd floppy have secure dust free connections and are not faulty or just replace them they could be faulty a computer needs Power and Data to travel through every working device and to continue its cycle and have an end so any faulty leads will end up with a computer error even something as small as a faulty power lead or fan lead can cause you problems computers need all of the data and electrical current to travel through every working device and to have an end to be able work properly Could be a problem with the Hard Drive or the Hard drives PCB http://www.onepcbsolution.com/ Make sure ram modules and cmos batteries have dust free secure seatings and cmos battery has charge some motherboards cmos batteries are soldered in Check you CPU make sure its securely seated and has thermal grease http://www.hardwaresecrets.com/article/Thermal-Compound-Roundup-February-2012/1490 Hope this helps.
Jan 03, 2013 | Computers & Internet
Green light on back on not flashing no power to anything
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
the leads from your MOTHERBOARD TO YOUR HARD DRIVE make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be
faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
even something as small as a faulty power lead can cause you problems
computers need power and data travel through every working device and to have an end to be able work properly
make sure ram modules and cmos batteries have dust free secure seatings and cmos battery has charge some motherboards cmos batteries are soldered in
motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail
check all power and data leads make sure they have secure dust free connections
cd/dvd floppy drives need to have current go through make sure these drives are working
check you CPU make sure its securely seated and has thermal grease
hope this helps
Jul 15, 2012 | HP Pavilion Computers & Internet
GT5670 Will Not Start...
test all leads that attach to your hard drive including electrical extensions SATA
the leads from your (motherboard to your hard drive) make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty
even something as small as an electrical extension lead or a faulty fan lead can cause you problems computer needs all of the data and power to travel through every working device and to have an end for a computer to be able work properly
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive check all electrical extensions make sure they are securely seated even the cd/dvd drives need to have current go through make sure these devices are working
check the CPU central processing unit make sure it has thermal paste and dust free secure seating
also check your computer ram modules and cmos battery make sure it has charge and they are dust free and securely seated some motherboards cmos batteries are soldered in
also check the keyboard and mouse batteries or ps2 or usb leads and connections if applicable
hope it helps
Jul 02, 2012 | Gateway GT5670 Desktop PC
The computer turns on but the monitor stays black. The fans are spinning constantly. It does not sound like it is booting up just the fan noise.
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error hope this helps
don
Feb 21, 2011 | Dell XPS One All-in-One TV Desktop with...
Wont start up and beeps
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
dont forget to vote
hope this helps
Feb 02, 2011 | HP Compaq Presario SR1303wm PC Desktop
I can't switch on my computer. There is no beep sound, all fans are turning on. mother board light on. hard disk as well. but no signal is sent to the screen. this happen because i change the processor...
Test the leads that attach to your hard drive from the motherboard or replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
Dec 18, 2010 | Computers & Internet
WANT TO KNOW WHERE TO PUT MY AUDIO LEADS BACK IN THERE PINS ON THE MOTHERBOARD
Mic In to pin 1; Gnd to pins 2 and 3; R Out to pin 5; Ret R to pin 6; L Out to pin 9, and Ret L to pin 10. Remove the jumpers on pins on the motherboard before placing thses wires.
If it is an internal speaker connection
SPK1: Internal speaker header Pin Signal Name
1 SPKR
2 NC
3 Ground
4 +5V
Hope this helps
May 09, 2009 | Computers & Internet
Problem getting computer to turn on
Try removing the power lead from the back of pc for atleast 15 minutes and re-connect. It may be a power supply unit fault that is showing connection but not powering the motherboard. Open up the side of pc and check the main leads that come from the power supply unit to the motherboard connection are'nt dissloged in any way, or unplug the motherboard connector and place in again this might re-set it.
Dec 18, 2006 | HP Pavilion a622n (PC108A) PC Desktop
Computers & Internet Logo
19 people viewed this question
Brian Sullivan
Brian Sullivan
joecoolvette
joecoolvette
