Question about Olympus VN-3100PC Digital Voice Recorder
Audacity .... I click on export wav and it still turns it into a 32 bit .wav document. The whole point is that I need a 16 bit. Cheers, Ben
  • 16 Answers
Use Sound recorder that is included on Windows XP it gives the easiest conversion option for .WAV files.
Converting the File Properties
1. Left click Start, Programs, Accessories, Entertainment, Sound Recorder. If you
intend to do this procedure often it is recommended to drag the Sound Recorder shortcut
icon onto your Desktop for convenience.
2. In the Sound Recorder box click on File> Open
3. In the Look In field locate and select your file. Click Open.
4. The Sound Recorder box is back. Click File> Save As.
5. In the Save As box click Change…
There are all the options listed that you can change and the bit rate is one of the options.
Posted on Aug 01, 2008
How to get songs in mp3
Search online for the free AUDACITY software.
Download it.
Install it.
Run it.
Import your music (it will be a 'WAV' file.
Click File.
Click Export as MP3.
Pick a name for the file.
Pick a folder to hold the new file.
Click OK.
Dec 24, 2010 | Computers & Internet
How do I change a 32 Bit to a 16 Bit?
Not only does the wav have to be 16 bit, it has to be PCM, 11.025
or 22.050 kHz, 16 Bit, Mono. I think it would be easiest just to play the audio from your sound recorder right into the microphone of your computer, since the Dragon software is especially made for listening on the microphone, Or hook up the audio out from the sound recorder to the Line-In jack of your computer using a male to male phono cable.
Jul 18, 2008 | Olympus VN-3100PC Digital Voice Recorder
From iTunes, I have converted the m4a track to WAV and then copied that over to my Tascam DP-02CF via the USB connection. When I go to import the track it says "Import file not found". What am I doing...
Your wave file is probably in stereo and you need to change it to mono. I use the free Audacity program to do this.
Once you have uploaded your wave file into audacity on the left side click on the down arrow which will bring up several options, click on the 'split stereo track' option. Then delete one of the tracks. You can then export the file as a wav file, you might want to rename with mono in your name so you don't write it over your previous stereo file. You can then import the file into your DP-02
Feb 14, 2010 | Tascam Dp-02cf Digital 8-track Recorder
16 bit 44.1khz monaural wav format files
I'll assume first that you have wav files on your PC that you'd like to import into your 2488 to use as percussion tracks.
You'll have to convert those files on the PC first into mono wav files. The 2488 can handle 16 or 24 bit so the bitrate shouldn't really be a problem. (It will also automatically truncate a larger bitrate down, but you should really dither the files rather than let them truncate... another topic).
You can use Audacity (free) to convert stereo wav files to mono wav (audacity will also dither for you).
Once your files are converted and saved on the PC, on the 2488 open the USB connection from the DISK menu. (This assumes you already have a usb cable connected between your PC and your 2488.) You will see a device appear on your filelist called HD_2488 or something like that with a drive letter. Copy your mono wav files into the WAV directory on the 2488 USB device.
Then on the 2488 press 'exit' to close the USB and from the WAV IN/OUT menu choose 'USB import'. You should see the WAV files listed. If those files are not mono waves you won't even see them listed. Select the file(s) and press enter to import. You'll be prompted to choose which track to import them to.
That's pretty much it.
bd.
Feb 20, 2009 | Tascam 2488 Portastudio Multitrack...
Load imported songs on tascam dp02 cf
Make sure you have the song loaded first. In this case it sounds like you are importing into a new song, so make sure that you have a new song created and loaded prior to importing.
Then go to the menu by pressing the 'MENU' sutton and from there select 'WAVE' and then 'IMPORT TRACK'. You'll see the list of wav files on the fat partition of the CF media displayed. Select the wav file with your beat track on it (use the DATA DIAL or up/down arrow buttons to highlight the right wav file) and press the 'YES/ENTER' button. You'll be prompted for the track to import into. Select Track01 and press the 'Yes/Enter' button again and the WAV file will be read and inported into track 1.
Please note that the wav file should be a 44.1 kHz, 16-bit and a mono wav before trying to import it. If the beat track was created as a stereo wav you'll have to go into a wav editor like Audacity and resave the file as a mono wav file first. Also for a wav with a bit rate higher than 16-bit, the DP-02 is going to truncate the bits rather than dither and this might effect quality adversly so you might want to make sure that the file is properly saved as 16-bit prior to attempting an import to avoid this.
Hope this helps.
bd.
Jan 10, 2009 | Tascam 2488 Portastudio Multitrack...
Need to cnveert wav voice recordings to mp3 om sansa view
Have you tried Audacity? It's free opensource sound editing software. Search Google for it or try downloading it at audacity dot sourceforge dot net. (You do have to install an mp3 encoder! but those are also free, and the Audacity site tells how to do this), Then you just import your wav file, and export it as an mp3
Dec 15, 2008 | SanDisk Sansa e250 MP3 Player
Dragon software
Forget about soundwave, I don't know if it saves 16 bit Wav or mp3.use Wavelab it is easier just open the files and do save as and chose format 16 bit. You can do the same with soundforge.
Whatever software you use , you use just (File button on top left)command open and save as or export, and when saving you set 16 bit wav. It is not to difficult.
Some of this software has many feature use solo basic file open save as or export
32 bit into a 16 bit recording???
Try NCH Software's Switch freeware program. You can tell it to convert from one bit format to another even with WAV files (it will call them PCM, but Dragon recognizes them as WAV files). It is also the best batch WAV to MP3 converter I have found. I always download from the company's own site as other sites can attach viruses.
How to convert audio in notes to wav?
This was a fun project. Here's how I did it. You'll need to download a freeware audio editor named Audacity. I did this on a Mac, but it's cross-platform, and I'm assuming the menus are the same for Windows. http://audacity.sourceforge.net/ Then. (1) Copy .pwi (Note) file to PC (2) Open Audacity (3) Get the Note audio into Audacity by: Project menu Import as raw data (4) Select all of the audio by clicking below its file name at left of the graphic of the file (5) Click on dropdown menu (arrow next to file name) Set Rate to 11025 Hz (6) Convert to WAV by: File menu Export as wav
Sep 14, 2005 | HP iPAQ RX3115 Pocket PC
Olympus VN-3100PC Digital Voice Recorder Logo
69 people viewed this question
Top Olympus Audio Players & Recorders Experts
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
