Plugged in, J drive showing on computer but no means of accessing files to the hard drive? How do I do that please?
  • 981 Answers
In Windows? Try volume manager (admin. tools or via rightclicking on the drive, which you should totally have tried first.) If there are already files on it but they don't show, perhaps that computer doesn't know how to access the filesystem used initially, and you need to get the appropriate filesystem (or a compatible likeness) installed on the machine at hand.
Often USB hard drives come preformatted to FAT32, but that filesystem can't handle files over 2GB, so you almost certainly need to install NTFS or something better instead.
Posted on Jul 19, 2008
My Hitatchi 250GB External Harddrive is not working at all when plugged in to any computer I own/use It makes soft beeping sounds for several minutes and then becomes silent The lights are on, showing
take the hard drive to a computer repair shop but from your description , it may be dead
if it is a disc type hard drive , then continually moving it around is not good for the delicate workings
if it is dead , replace it with a solid state hard drive which has no moving parts and is a lot more robust
May 05, 2017 | Hitachi SimpleDrive Mini 250GB USB 20...
I have a 250GB CrossFire Hard Drive. I tried 2 new power supplies and neither one of them is giving me enough "juice" to power the HD up. The light barely flickers and it is not coming up...
Remove the hard drive and put it into an enclosure. Plug it into another computer as a slave. Then you can copy your files on it.
If it shows up in 'my computer' as a drive letter(like E: drive) but you can't access it, you can recover data from hard drive with data recovery program. Asoftech data recovery is a professional data recovery program that can recover data after deeply scanning your hard drive to look for lost data due to drives crash, physical damage, system sabotage, virus attack etc.
Sep 06, 2011 | SmartDisk 250GB SMARTDISK CROSSFIRE EXT...
I dropped and dragged some sizable folders from a desktop onto the Maxtor external drive. When I plug the drive into a different computer, I only see the files that I put on the drive a year ago on the...
Several things could be happening.
1. the hard drive direct drive motor is giving out.
2. the hard drive is full.
3. the hard drive needs to be optimized ( that is defragmented) using the Windows defragment utility. If the drive is large it will take some time to complete.
Jul 22, 2011 | Maxtor Hard Drive
Sir when I plug in my pen drive and try to access it, the comouter shows a message "access is denied".Please give me the solution to fix the problem
Delete the autorun.inf file on the drive.You may have to set your computer to show hidden files and system files to see that file.
Mar 01, 2011 | Computers & Internet
I plugged my external hard drive into my usb port where it downloaded the driver perfectly and it said everything was working properly. Then i went to my computer and the hard drive does not show up for me...
above the control panel there is a computer word
click on that and it shows the external hard drive double click on the hard drive icon and that will open up all of the files and folders on the hard drive
Jan 05, 2018 | Maxtor OneTouch USB (A01B120) 120 GB Hard...
External Hard Drive not Accessible after Windows Vista Update
Assuming that the external hdd is physically working fine, everything is pointing to a damaged boot sector.
You can get back most (if not all) your data stored in your external drive with the help of an application called: Pc Inspector File recovery.
Its a freeware.
Here is the link:
Simply install it on your C:\ drive, and follow the prompts.
Please let us know the outcome.
Don't forget to rate this answer if it helps
Dec 12, 2009 | Maxtor Hard Drive
Icon doesn't show up in my computer section so I am unable click on and access my files, however the computer a compaq presario laptop does recognize the hard drive, I just can't access anything its...
This wild mean the file system of the hard drive is set as something other than NTFS or FAT/FAT32. Mac and Linux would be able to read it just fine but due to the limitations of Windows, it wouldn't recognize the file system.
Google the program ext2read. It will enable reading of another file system in Windows.
Oct 11, 2017 | LaCie External USB 2.0 500GB 7200 RPM 500...
External imation hard drive showing an empty folder !
You can run a data recovery app on the drive and attempt to pull offany data still accessible. I recommend the GetDataBack Data Recoveryapps from . Get the one for the file system on your thumb drive and give it a try. These apps have recovered data from "dead" drives for me more times than I can count.
Aug 24, 2009 | Western Digital My Book Essential Edition...
External hard drive does not display icon in My Computer
try other usb port, or other computer and see whether the hdd is detected. If still not, try to go to device manager ( ), and then assign a drive letter to the hdd. After that, try to access it from Computer, if not able to access it, format it (use quick format) and then use this data recovery program to recover your files.
Mar 03, 2009 | Verbatim 160GB USB FireLite: The "drive...
Computers & Internet Logo
41 people viewed this question
David Payne
David Payne
