Question about Zanussi ZWD1470W Front Load Washer / Dryer
ZANUSSI ZJD12191 WASHER/DRYER
E10 IS DISPLAYED AND MACHINE WILL NOT DRY
  • davve Jul 19, 2008
    i should have stated that the machine starts to dry then stops!
    Problem Solver:
  • 3 Answers
Washer dryers often have cold water valves with 3 separate solenoids. One for the main wash and rinses (which is clearly ok) and one for the condition rinse (to take the fabric conditioner down) which is probably ok too, and the 3rd one is for the dryer. It's possible this 3rd solenoid has failed.
Washer dryers need on a steady trickle of cold water running into the condenser chamber to convert the steam into water, which then gets pumped down the drain.
Posted on Jul 19, 2008
Tumble dry problem
Error 10 is a low water pressure alarm.Check that the drain tube is clear and in the drain pipe correctly.Does it take a long time to fill.There could be a problematic pressure switch or hose to this switch,or faulty Inlet valve or even a faulty Circuit Board.
Jul 14, 2010 | Zanussi WJS1265W Front Load Washer/Dryer
ZANUSSI FJR1454 W WASHING MACHINE E10 ERROR . IT TAKES NEARLY THREE HOURS TO DO A QUICK WASH. IT BLEEPS AT LEAST 4 OR 5 TIMES THROUGHOUT A WASH CYCLE AND THE CYCLE COUNTER DOESNT SEEM TO COUNT DOWN...
e10 means that there is a problem with the water supply.
a condenser dryer needs cold water to operate properly. the e10 code will appear if:
1. the water is turned off
2.the water pressure is too low.
3.the solenoid valve is open circuit
4.there is a problem with the pressure switch (least likely)
Cold valve is at the end of blue inlet pipe remove lid and you will see it.
f E10 is only appearing when trying to dry, the problem almost certainly is the condenser valve solenoid open circuit. The green solenoid on the inlet valve. Should read about 4000 ohms.
My money would be on the solenoid coil being open circuit. The coil can be canabalised from most valves although you may have to modify the connections. For simpler repairs - contact Zanussi and get the entire triple inlet water valve to swap out.
http://www.zanussi-electrolux.co.uk/files/unitedkingdom_english/0-999/zanussi%20error%20codes.swf
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Oct 10, 2009 | Washing Machines
My washer/dryer starts to dry and then stops after a short while with an error message - E10 (I think its a 10)
I am not familiar with the Zanussi, but it sures sounds to me like maybe there is a problem with the high limit thermostat. It may be mounted on the side of the dryer. You can check it out with an ohm meter and you should get no resistance. If there is resistance, then the thermostat is bad and must be replaced. It is sensing high temps and is shutting down the machine. This is only a guess on my part, without looking at it. Sure hope it helps you. Good luck.
Jul 16, 2009 | Zanussi ZWD12270 Front Load Washer / Dryer
E10 code on a zanussi jet system washer
Is it a washer-dryer? E10 relates to a fault with the inlet valve.....usually the valve itself going open circuit.
Feb 26, 2009 | Zanussi WJS1265W Front Load Washer/Dryer
Wash Machine WA950SCJ won't fill up
Jan 20, 2009 | Washing Machines
DRYER NOT WORKING
E10 means theres no water going into the machine.Your machine has a triple water valve the 1 that feeds the dryer has proberly failed. Comes as a comp unit.
Dec 02, 2008 | Zanussi FJS1225W Front Load Washer
Zwd1471s washer dryer
E20 code on Zanussi washer dryer ZWD1471
washing machine working but dryer is not .
Any advice please
Mar 24, 2008 | Zanussi ZWD1470W Front Load Washer / Dryer
E10 error code
I had this problem, the washer/dryer stopped working while in the drying cycle and displayed e10 message. It was caused by a faulty three-way inlet valve. The solenoid controlling flow to dryer condenser proved to be open circuit. Pulled washer out from under counter top, unplugged, removed top cover, tested solenoid circuits with ohm meter and found one solenoid was faulty. The filter going into the unit was clear. Replaced whole three way component with one ordered on Internet and all now works fine. Noticed that during drying cycle, water to condenser is constantly being switched on and off, explaining why the green condenser solenoid is the one that wears out first.
Mar 03, 2007 | Zanussi WJS1265W Front Load Washer/Dryer
Manual
have got the washer/dryer, and no instructions on how to use , please help get my cloths clean and dry. thanks
Jan 24, 2007 | Zanussi ZJD1219 Front Load Washer / Dryer
Zanussi ZWD1470W Front Load Washer / Dryer Logo
481 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
