Question about Acer Computers & Internet
HAVE BEEN TRYING TO UPGRADE AN ACER 5630 TO 2GB RAM THE MACHINE WONT ACCEPT THE TWO CARDS TOGETHER. BUT BOTH WORK OK INDIVIDUALLY AND IN EITHER SLOT. THE TWO ORIGINAL 512K CARDS WORK FINE. ANY IDEAS
  • rodmars Jul 19, 2008
    Hi thanks for the info,
    I have already investigated a lot of this, boards are matched so should not be a problem there. I have acessed BIOS but no setup for the memory here. Jumpers may be the thing on the Motherboard but finding info on the Motherboard seems to be very scarce.
    Next thing is contact ACER unless you have more thoughts on the subject?
    Cheers anyway
  • 981 Answers
STOP WITH THE ALLCAPS>
THIS IS NOT A TELEGRAPH>
THIS IS NOT GENERIC TO ALL DESKTOPS>
IT IS JUST your memory which is somehow mismatched or tweaked in the BIOS! If they are physically different other than in the serial number printed on them, it's best to return them to the seller asking for a matched pair (please.) First though, note that the laptop can take 4GB max...may as well go with that...and especially if they are firmly in the lookalike category, you might try going into BIOS memory settings and setting things up for the new memory. Often enough setting a different voltage is appropriate, as is marking down the old settings and backing them off to automatic before optimizing for your particular make.
Oh yeah. Sometimes there are motherboard switches or such that need to be switched when you change memory too...sorry, I didn't manage to look into that; but if it's not staring you in the face when you put the memory in with good lighting, the BIOS should be enough.
Posted on Jul 19, 2008
  • Steve Nordquist
    Steve Nordquist Jul 20, 2008
    Barely; ;looks like the BIOS memory recognition compiled wrong somehow, perhttp://wiki.kainhofer.com/kubuntuonacera... so: Is your BIOS version up to 3.5.0 ? Or other controlpanels per:
    http://www.acerpanam.com/synapse/forms/A... ?
    Kind of hard to find on the Acer site, isn't it? Here it is on some ozzie software agglomerator:http://drivers.softpedia.com/get/BIOS/Ot...
My pc was working fine with 128 + 256 ram. few days ago it didnt boot.it was restarting automatically. then i removed 256 ram and it booted normally.means pc works normally with 128 ram but not with 256...
i guess u have 2 different RAM cards in the RAM slots....
the main issue is both dont work together...the primary reason is compatibility....or one of the RAM cards have worn out...
u must use exactly similar kind of RAMs in both slots....
i suggest u use one 512 MB if your motherboard supports....
RAM technology has advanced so mush that you wont get RAMs for old PCs (motherboards)....so u decide...
pls revert back...and kindly leave a feedback and rating for this solution...it will help me move to Guru" here from Expert at Fixya....
regards...
Sep 29, 2010 | Gigabyte GA-8I845GV Motherboard
Hiya I have just fitted a 2gb upgrade to a aspire 1362 wlc but it will only recognise one bank of memory - I have tried them individually and they both work - just both won't work together - is there...
Questions?
Are both of them 1 GB?
Do they both work individually in each slot?
This laptop will only work with 2 1GB memory sticks.
If the memory works in each slot, the slots are physically ok.
If each stick works in each slot, the memory is ok too.
If one of these tests fail, you have found the culprit.
Check these things and then check the bios. I don't think there is a limiter in the BIOS.
Apr 21, 2010 | Acer Aspire 1362LC Notebook
Acer Extensa 5620Z will not work with more than 2GB RAM??
parrotheadpc is incorrect in stating "you can only have a total of 2048 mb installed".
the 5620Z accepts 2 x 2 GB SODIMM RAM, the machine boots and shows the full 4 GB in the BIOS.
the full 4 GB works with the Ubuntu x64 installer.
Windows XP x32 goes BSOD on startup.
Windows 7 x64 install from DVD fails with same BSOD error.
conclusion: this is a Windows-Extensa 5620Z incompatibility that would require a fix by ACER at the BIOS level.
question: there may be specific memory modules 2 x 2 GB which do work--anyone have it work with Windows?
Oct 02, 2009 | Acer Extensa 5620 Notebook PC
Upgrading ram
You can only run 2gig max IE: 2- 1gig or 1-2gig you cant run 2-2gig the bios will not accept it
Mar 13, 2009 | Toshiba Satellite P205-S6337 Notebook
RAM Upgrade
I think Acer notebooks will only accept in most cases two of the same , size, i removed my memory sticks and bought two x 1GB sticks instead and it's fine
Sep 10, 2008 | Acer Aspire 5315 Notebook
Ram problem
Kamel,
First of all you should know howmuch maxim RAM your board will support and which type of DIMM's it accepts. You can see on your motherboard manufacturer's site.
  1. Try each on in all slots one by one to verify all slots are well. if not try to clean and check again.
  2. If its ok then put both together and check out, if not then try to change the place and clean the contact point as well.
Thanks
Iqbal
Apr 09, 2008 | Computers & Internet
HOW TO ADD GRAPHIC CARD TO LAPTOP
it is not usually possible to upgrade the graphics card on a laptop. as the graphics chips are on the motherboard. and they do not usually have a graphics card slot.
some (quite recent) laptops have a graphics express slot which does allow for them to be upgraded.
most often you find that laptop graphics chips share mem with the main RAM (allocated) this is controlled in the BIOS(Setup) and it may be possible to increase the allocation of memory there,
but I'm sorry to say for most laptops there is no upgrade (flexibility is traded for portability)
the 5002WLMI does not appear to have a grpahics express slot, however you may be able to increase the mem allocation in the BIOS (as it does use allocateable shared memory)
Oct 19, 2007 | Acer AOpen MX 400-A (32 MB) Graphic Card
Computers & Internet Logo
43 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
