Question about Samsung CLP 300 Laser Printer
Not printing straight
When the page has printed it has not printed straight. there is a 4mm difference from the top of the page compared to the bottom
    Sergeant:
    Champion:
  • 214 Answers
Check the alignment
Posted on Jul 19, 2008
How do I align the HP Laserjet 1020 to print straight? Its printing crooked every time. No two sheets are in the same position
Most likely to be a page feed problem, look online to clean page feeder rubber rollers.
Try here for the pdf manual which covers problem with jams and skewing
http://www.hp.com/ctg/Manual/c00264334.pdf
Mar 05, 2015 | HP LaserJet 1020 Printer
HP 1012 paper coming out creased. ?something stuck to drum or roller
If it is a clicking sound it's most likely a gear that is bad. Haven't worked on this model, but typically it is one of the gears that works in tandem with the fuser that goes bad. These can be purchased on hp's site. Remove the fuser and inspect all the gears. There usually is a small plastic clip you have to remove to get at the gears. Inspect the teeth on the gears (they should be smooth) If it's not one of the fuser gears it could be one of the gears on the main gear assembly. This is considerably harder to access.
Jul 16, 2012 | HP 1012 Laser Jet Series Q2461A
Printer only prints top and bottom lines on page
All web based documents, especially bank statements, require a COLOUR cartridge, so if your cartridge is empty, it will print blank pages. Although the font may look black... it is normally NOT. Altentaively you may also need to instruct your printer to print "background images".
Jul 08, 2012 | HP Deskjet D1000 J110a Printer Catalog...
Pro901 prints off-centre/ misaligned
Make sure that you're choosing the correct paper type and size. Also, check the margins when printing.
Jun 06, 2012 | Lexmark Pro901 All-In-One Inkjet Printer
Printing Large Top Margin
check the header and top margin in your application. (word, Note pad, etc..)
default top margin for Microsoft word is 1".
also check the orientation of the printer output.
Nov 24, 2008 | Samsung CLP-500 Laser Printer
The problem was the back casing was slightly loose on the back of the printer, Once I corrected this, then everything was okay.
Cheers
Aug 04, 2008 | HP PSC 1210 All-In-One InkJet Printer
Neff H5642
Your question is unclear, but you should probably have more door overlap on the front face than 4mm top and bottom. This will be ok if the door fits into a flush frame when closed.:::Spiceweasel.au
Mar 26, 2008 | Neff H5642 Convection / Microwave Oven
Font size
You can change the dfont size from the menu, but that setting afects the entire page of print. You different size fonts are controled from the codes sent to the printer from the software. Recreate the document, or create a document with a sample of that small print and see if the printer prints it.
Dec 04, 2007 | OKI MicroLine 420 Matrix Printer
Samsung CLP 300 Laser Printer Logo
225 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
