Question about Yamaha DSP-A1000 5-Channel Amplifier
Flashing LED on the volume
Hi all
Have a DSP A100o and it is continuously flashing the LED on the volume
is this a problem?
Regards
Harpo
  • harpo240 Jul 24, 2008
    holme
    I solved my promblem. if the LED is flashing on the volume Knob you have most probably hit the mute button (left of the volume down button. The mute on the DSP A1000 only drops the volume by 20 dB BTW the manual doesn't mention the flashing led
    Hope this helps
    Regards
    Harpo
I have problem with amp yamaha dsp-a1000 the led the volume it like blinks everytime is good the transistor the output is good, i dont no whats happening can u help me please
Posted on Jul 22, 2008
Powerlite 77c keeps shutting down
Hi Dave,
have you inspected the led indicators after shutting down .
it must flashing and indicating pattern.normally epson have 3 LED indicators.
please come with blinking pattern or google it.
i think it is bulb problem,
regards,
nuwan
Jan 13, 2014 | Epson PowerLite 77c Projector
Problem with volume motor
https://www.hifiengine.com/manual_library/yamaha/dsp-a1.shtml?_e_pi_=7%2CPAGE_ID10%2C1711428461
Oct 03, 2017 | Yamaha Audio Players & Recorders
Samsung TFT 19 LCD no flashing red LED continues on replaced all caps
did you check the output dc voltage of the power supply if present. if ok, then doesn't turn on the problem is with in the main board.
Oct 10, 2012 | Computers & Internet
I recently bought Philips DSP 2500 Home Theater. But in my LED TV the audio out is used only thro' optical able. But in Philip DSP 2500 Home no option for connecting optical cable. so kindly advice if...
There is a website that provides an Opticle Audio to Digital SPIF converter. I have listed it in the link for you below. The item also apears to be quite inexspensive, so it would be worth looking into.
Optical to SPDIF
I would be interested in knowing how well this works for you.
Aug 30, 2011 | Televison & Video
I have a Bosch dishwasher model # shx4ap05uc/06 and I want to silence the alarm for when it is done. It goes off every 10 minutes until you open the door
Yes, you can switch the cycle completion signal off (or raise/lower the volume)
1. Switch the dishwasher off using the ON/OFF button
2. Open the door
3. Switch the dishwasher on again. (One of the wash cycle LEDs will flash.)
4. Hold the > button in. Continue holding it and press and release the Start/Reset button once, then release the > button.
"Clean" and one other LED should now be flashing. This indicates that the dishwasher is in the options/settings mode. If they are not flashing, start over at step 1.
5. Press > repeatedly, until the LEDs for "Clean", "Sanitized" and "Rinse Agent" are all flashing.
6. Press repeatedly until none of the LEDs are flashing.
The number of flashing LEDs indicate the volume setting . . .
0 = Silent
1 = Volume level 1
2 = Volume level 2
3 = Volume level 3
7. Press the Start/Reset button once to save the setting and exit the options mode
8. Close the door
9. Switch the dishwasher off.
Hope this helps. Please let me know if you need further assistance.
Regards,
BElectric
May 27, 2011 | Bosch Dishwashers
Carlsbro dsp marlin amp is buzzing loud constantly even without anything plugged in, can anyone help?
If it's buzzing even when the volume is down, there must be a problem in the power supply.
Then you have to look if there's a diode or capacitor not correct.
Kind regards,
Gerard
Feb 07, 2010 | Audio Players & Recorders
Reprograming my tv remote
Hi chevry,
universal remotes vary with respect to button options. For a Sanyo TV you can try these codes. (This is manual mode).
0098, 0066, 0091, 0023, 0017, 0027, 0080.
Press the TV button on the remote. Than press & hold the set button until the LED stays on. Enter the four-digit code. When the remote control recognizes the correct code the LED will turn off. If the code is not correct the LED will flash several times & stay lit. Enter the next code. (You'll have less than 25 seconds to try another code) or the remote will exit the programming mode.
How to use the auto search. (One code at a time). This will take some time.
Turn on the TV. Press & hold the set button until the LED comes on, point the remote at the TV & press the volume + once (This moves the remote through 1 code at a time. Continue to press the volume + (Do not do this very fast or you'll miss the correct code), until the TV turns off or changes channel. Than press the set button again & the LED will go off. The remote should now be programmed for the TV. Test TV by turning the on/off button on remote. Check volume up & down.
Good Luck!
Mike
Jul 04, 2008 | Televison & Video
Flashing volume control
THE MUTING CIRCUIT IS ON AND IT CANNOT BE DEACTIVATED BY UNPLUGGING UNIT...YOU MUST HAVE THE REMOTE TO DEACTIVATE.
Sep 10, 2006 | Yamaha DSP-A1000 5-Channel Amplifier
Yamaha DSP-A1000 5-Channel Amplifier Logo
214 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
