Motherboards
Problem for Motherboards
Generic problem for all Motherboards
Connecting motherboard ?
By lopebay on Jul 19, 2008
I took a plan of the motherboard out of the manual . But connecting it is a different story. For instance: Do I have IDE disk 3/4 or 1/2 ? How about Serial ATA 1 o3 2 ? Where do I have to connect USB E/G and or USB F/H ?
So, I cleaned my computer (inside) and disconnected some cable and now 2 USB ports (front panel) do not work any more. I also don't know wether this a software or hardware problem. Before I reinstall my whole operating system I want to make sure that hardware is not the problem and the connections to the motherboard are made properly.
Comments:
Jul 20, 2008
- Dear DARKLORD1,
thanks a lot for a great answer. It solved my problems just like that. Again, many thanks.
Jul 21, 2008
- I don't know why, but the "Appreciation buttons" don't work !!!!
Same Problem
Jan 05, 2009
-   how to connect a sata cable to asrock k7s14gx mother board -   realicecube2
Solution #1
posted on Jul 19, 2008
Somewhat Helpful)
DARKLORD1
Rank: Guru
Rating: 86%, 716 votes
Hi,,
ok lets see if i can help you out here
basically IDE 1+2 Is primary and 3+4 is secondary, it doesnt matter where you donnect your harddrive to it will still work ,, the standered is to use 1 and 2
as for the frount usb aint working is cause they are not connected or the wires are mixed up.. basically you can connect the wires to any usb section of the mainboard as long as you connect it propperly.
each wire is labeled and the bord is labelled as well. for example connect ground to ground, v++ to v++, +5 to +5 and -5 to *5 there is a diagram on the manual showing the connection ports location and pin id's it also labebled on the main board.
Comments:
Jul 21, 2008
- Thats ok sir, you can try it again when ever you have the time.. I'm happy thats its working if you need any more help you can always find me here..
Jul 22, 2008
- hey any luck with the appreciation button
Was this helpful?
Yes
No
Popular Solutions for Motherboards
Questions and Unsolved Problems for Motherboards
Answer
compaq presario mother board, what should I replace it with
Answer
I have an Asus P5KC and after loading Windows 7 I had a boot failure and now all I get is window... (More)
Answer
recently my computer doesn't read dvds.earlier no problem. it reads & writes cds.works well... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Motherboards Experts
Top Computer & Laptop Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
