Question about ASUS WIRELESS ROUTER |WL-520G - RT (WL520G)
Can't use internet wirelessly through router
When I try to disconnect my laptop from the router the internet doesnt work. I can't even use the internet through the router while my laptop is connected, atm I am connected through my dsl modem
    Scholar:
  • 94 Answers
You need to connect the line cable in your dsl modem the the router and go through the set-up procedure on the router.
I.E. put all your ISP settings into the router.
Regards
Philip
Posted on Jul 31, 2008
Testimonial: "Info was very helpful"
My laptop and my iphone indicate that my wireless-g broadband router is putting out a wireless signal; but neither accessory works on the network, even though the bars are entirely full on the devices.
The bars on your laptop or iPhone means that you are connected to the router! Not necessarily to internet. Your internet depends on ISP Internet service provider and modem which connected to your router. To check if you have active internet connection connect your laptop directly to modem provided by your ISP with ethernet cable and try to open a internet browser IE or Safari or Chrome or Firefox and open a webpage! If you are able to connect internet by this mean you have internet connection active. Now disconnect your lap top from modem and connect modem to your Linksys router using WAN port of LINKSYS! Its good to power off and power on (power cycle) once on modem and router to make it work!
good luck!
Sep 14, 2011 | Linksys Wireless-G Broadband Router
Wireless connection keeps disconnecting. I have tried two different locations, but I get an ip address and then it disconnects
Try to turn off & power back on the router for 60secs. If this doesnt work, reset the router using the reset button at the back of it. If it still doesnt work, youll have to contact your Internet provider, & tell them that you have an Intermittent Connection Problem.
Apr 06, 2011 | Toshiba Satellite L645DS4040 Laptop
I want to add a newly purchased computer on to our Linksys router to connect to the Internet via Comcast. My computer says the cable isn't connected even though all the lights show up on the Linsys. ...
you have 2 options to connect to the router on the computer.. either wired or wireless-- if you are connecting wirelessly then just ignore "cable isnt connected" --you can change the icons so it doesnt show in CONTROL PANEL>NETWORK CONNECTIONS
If your trying to get on the internet with a wireless connection.and running WINDOWS,(many problems with LINUX) .and have a wireless router all set up and configured to broadcast the signal (not hidden) ....
try resetting the router (disconnect the power to it for a few minutes) next --be sure the wifi switch is enabled on the netbook---TRY IT NOW--if still problems---go to CONTROL PANEL>NETWORK CONNECTIONS--right click oin your wifi card and choose properties--highlight INTERNET PROTOCOL and choose properties and be sure "OPTAIN IP ADDRESS AUTOMATICALLY" is checked--Does the laptop "SEE" the router?
You will need your SSID to logon to the router(internet)
follow this is a link to a troubleshooting flow-chart-Do check it out
http://www.daileyint.com/hmdpc/laptop/wireless.gif
If you continue to have problem..indicate at what point in the flowchart it is getting stuck
If this was helpful, please indicate so, if not -comment back so we can dig further to resolve this
Jan 01, 2011 | Linksys EtherFast Cable/DSL Router
I have a belkin N wireless Modem - router and i try to connect to the internet but i doesnt, all the lights are blue exepct the internet one, that flashes orange...and when i troubleshoot it says that the...
Hi Friend,
Before checking these.please disconnect the Modem from router.Connect the Modem directly to your computer or laptop and check whether you are able to access the internet. If not please check with you Internet Service Provider.
Regards,
Aysaam
Sep 05, 2010 | Belkin N Wireless Modem-Router F5D8633au4A
Hi Friend,
Regards,
Aysaam
Internet Connection Problem on One Computer
By any chance, are you trying to use something other than Windows to manage the wireless adapter? If you are, remove it.
Now, Click on Start, right click on Network highlight properties, and click on manage network connections on the Tasks menu.
Your two options will be the icons for your LAN and Wireless Network. Is it enabled and without red or yellow marks? It could be disable, it could be not connected and you can't view wireless networks because the switch is off, or it may just nut see your unsecure network (unlikely).
If the above is clear, right click on the wireless and highlight Properties and left click so it brings up the Networking tab. Highlight IPv4 and click on Properties. Make sure the Obtain dots are ticked. That should work, since you are running unsecured.
If it already is, check the red X or if it isn't click OK and close down the box.
Now, back to where your Wireless card is showing, right click it and you have Disable, Connect/Disconnect, Status, Diagnose etc.
If you're still Disconnected but not Disabled, click on Connect/Disconnect. Does it show your wireless network?
By this time, it should. If it doesn't post back. The other possibility is that you take your computer to a wireless internet cafe, McDonalds, Panera Bread, or motel with WiFi and test it there.
Carl
Jun 21, 2009 | Linksys Wireless-G Broadband Router
D-link dir-625 still cant acces wirelessly
If your laptop has a wireless capability you should be able to connect to the wireless network of your router, just view the available wireless network select the wireless name of your router and connected to it if it already say connected try to disconnect the ethernet cable from your laptop and access the internet wirelessly..........
Nov 01, 2008 | D-Link DIR-625 (790069292637) Wireless...
Cant go wireless
I think the problem is not your laptop configuration. Can you check the setup configuration of the router it's maybe the wireless function is disable. Or try to reset the router to his default configuration. Press the reset bottom of the router for 15 second then try to connect your wireless connection if still not working setup again the router configuration.
thanks
Apr 15, 2008 | Belkin (F5D5231-4) Router
Laptop keeps disconnecting then connecting every so often.
Has the computer ever stayed on long enough to connect to the internet?
Is there a wired computer working when attached to the router?
If not, if possible please try to connect the laptop wired to the router as a test and tell me if it works.
I am trying to determine if your router works with the internet before considering the wireless connection simplying the initial problem. Once the router works wired is time to try the wireless. Once the wireless works unsecured you may want to change the router and wireless adapter to secure the wireless network. So this can be a three step process.
Jan 03, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
My wireless router wont work
Run a cat5 cable from the laptop to a cat5 port on the router, open internet explorer in the address window type http://192.168.1.1 or what ever the IP address of the router once you have accessed the router create your PPPOE internet connection, enter your Internet Service Provider's username and password. Once you have done this, disconnect the cat5 cable and connect wirelessly to the router from the laptop. If all this fails press and hold the reset button on the back of the router for 10-15 seconds this will reset the router to factory defaults. connect to the wireless router and create the PPPOE connection. BPCS
Dec 29, 2007 | D-Link DI-634M Wireless Router (DI634M)
Computers & Internet Logo
206 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
