Commonly Reported HVAC Problems:
[Copyright © 1996-2011. Hannabery HVAC. All rights reserved.]That would be the little red button on the box at the oil burner itself. If your oil burner stops running the first thing you should check is the reset button. If you press it and the burner fires up then that was the problem. If the button should trip again then there is a definite problem and you should schedule a service call immediately. Do not keep resetting the button and ignoring the problem.
Now, what is this button and why does it trip?
It is a safety device. It shuts the burner down when it thinks there is a problem. It is on the primary control and is hooked-up to a cad cell. A light sensor. (The same thing that turns outside lights on at dusk.)
On a call for heat, with the burner running, the cad cell senses the light of the flame. If it stops sensing the light of the flame, it causes the red button to trip, shutting down the burner before any significant damage is done.
Next question. Why would the sensor stop sensing light while the burner is running?
Many reasons. Almost all of which require a service call.
Below is a list of possible causes and things to check. Items in blue usually require a service call. Items in red however can be addressed, even fixed by the homeowner.
- Faulty or dirty cad cell
- Faulty primary control
- Bad or weak ignition transformer
- Bad burner motor
- Bad fuel pump
- Blocked oil filter, strainer or nozzle
- Delayed oil valve not opening (some units)
- Cracked electrodes
- Improperly set electrodes
- Air in fuel line
- Burner running with a very high smoke
- Burner sooted-up
- Loose electrical connections
- Damaged flexible coupling
- Water in oil tank
- Out of oil - Have your tank filled
- Chimney blocked - Have it cleaned
- Closed oil valve - Open valve
- Air, Pump not primed - Prime pump - may need to call for service
Oil filter refills
Oil filter canister
Smart Filters
The bottom causes in red are common problems and can be addressed by the homeowner. Try to check for these conditions first before calling for service.
Hope this helps, remember - these are just rough guidelines and not all possible situations are covered.
I found this article on the Web So I can't take credit for it..... But it is a very good place to start for your problem It is what I would start checking if you called me for service .......Good Luck
That's really scary that when you go to turn it off flames come out of the combustion chamber. My oil burner is also having problems, but it's only just not actually burning oil. There are no flames at my house, which I am now grateful for. Still, both of our problems sound serious so we should probably both find an oil burner repair person to get to check ours.http://www.shearmanoil.com
