Question about Seagate HDD 40GB 7200RPM ATA100 2MB (ST340014AP) Hard Drive
Hdd detection Sir My name Karim and Ihvae an computer Now its i am face an problem that my hdd is not booting my hard drive is automaticlly hit up and hang the machine and more importent data in this hdd so what i amdo in this metter plz give suggistion as soon as possible and plz send repaly on this Id Panwar_smith@yahoo.co.in
  • Panwar_smith Jul 19, 2008
    plz send me answer as soon as and cant charge any cost of service
    Problem Solver:
  • 18 Answers
Well if it is a problem with your hard drive you pretty much only have 2 choices from here. you can take it to a computer repair shop and (hopefully) have them pull the info off for you (most likely onto another hard drive), or you can get a second hard drive, load an operating system onto it, and then set up your current drive as a slave drive and (hopefully) access it to pull your information off. Unfortunately unless you have a GOOD friend who does computer repairs it's going to cost you money.
Posted on Jul 19, 2008
My hp desktop says internal hard disk not found how do i reset my drive
First reset the CMOS. Check your motherboard specs for how to do this or remove the small round silver battery from the motherboard; wait 30 seconds and reinstall it. (It is a good idea to replace with a new battery.) This will reset the CMOS. Then reboot to see if HDD is detected. If not, go into the BIOS setup (repeatedly hit F10 at HP logo screen) and check to see if your hard drive is listed. You may have to set it to "on". If it is listed in BIOS, but not detected another drive (a bad one) could prevent it from being detected. If you have any removable or external drives attached to your computer, disconnect them. Reboot your computer to see if your HDD is detected. If not, open your case and disconnect the data cable from all drives except your primary hard drive. This includes the floppy, optical, zip, backup, or secondary hard drive(s). If your HDD is detected, reconnect each drives data cable one at a time rebooting between each. If after reconnecting a drive and rebooting, your HDD is not detected the last drive is a bad drive and preventing your HDD detection. I have found that sometimes a bad drive that is connected will let the HDD be detected then on later boots the HDD will not be detected. Also it is possible that your BIOS is corrupted. Let's hope not. Another possibility is a bad motherboard. I hope this helps you.
Aug 11, 2012 | HP Computers & Internet
Laptop won't boot from hard disk drive or from cd either. please help.
u should have also mentioned which laptop u talking about ... any ways hit the delete key the moment u hit the power button and than chk out if the hdd is been detected in the bios or not if the hdd and also the disk drive is detected ... than there would be an option wbhich would say boot priority make sure the first priority is hdd and second is disk drive remove the floppy disk from the priiority menu and than start the system if u still have an issue than u have to open the laptop to chk the connection to the hdd as well as disk drive
Jan 27, 2011 | Computers & Internet
Boot device
your hard disk has upto 3 years warranty from the day of purchase
May 26, 2010 | Samsung 250GB HD250HJ SATA II 300 7200rpm...
Good day i have tried to install Win XP on my acer aspire laptop after formatting the HDD on another machine but i cant, the acer did not recognise the HDD. what do i do
Do you have an Xp disk? This is the only way I know of to install Windows Xp without encountering any problems.
You will need the disk; also you need to make sure that the boot options see that you want it to boot from your cd drive. When you start your computer up, get to this screen by hitting the key to enter setup options shortly after hitting the power button. It's where you change your BIOS and other stuff.
This is where you can make sure it recognizes your new HDD and change your boot option to #1-boot from cd drive.
Reply to this if you need more info.
Hope this helps.
Dec 15, 2009 | Acer Aspire 3000 Notebook
Cant detect my western digital hard drive help! philippnes!
Shut down the computer.Disconnect the ide cable from hdd .Just connect using primary hdd and boot the computer. Shut down the computer. Connect the secondary hdd both IDE and power cable. Restart the system and go to bios . Check if the both hdd are detected in bios. If detected boot to desktop. If not detected reset bios settings to default.Restart computer and check. IF still not detected shutdown computer.Disconnected secondary hdd and primary hdd,connected secondary hdd to primary ide connecter and check in bios. If still not detected try connecting secondard hdd on different computer and check.
Aug 17, 2009 | Computers & Internet
Ihave purchased a SeagateFreeagent 500 gb USB external HDD.It was working very well till I tried to create partitions by using Paragan Disk Management software. In the middle of formatting the partition...
After plugging ur HDD, verify the device is detected or not in Device manager and Try Partitioning Again GUI mode (means in XP).. or follow the steps..
1- Go to Computer Management, Click Disk Management
2 - You will find you External HDD in the Right side
3 - Just Right Click the Drive, if it asks Initialize HDD, just Initialize and Create Partition as u like.
Have Fun
- Rajkumar
Mar 28, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Dear Sir, my problem is as follows when i switch on my PC it says boot disk failure. so i checked the BIOS. I saw there is no Hard disk name in the list though i have attached the HDD perfectly. I have...
hi,
there are many chances of HDD boot sector gone dam.
do some work to know whats wrong--
boot your computer using another HDD and make your old HDD as a slave disk; if the old HDD is serched as a slave thats mean your HDD is fine.
for any question ask me.
Thanks for your question
Jan 03, 2009 | Samsung SpinPoint P80 SP0802N 80 GB Hard...
HDD NOT RESPONDING
Open the tower and try reseating the cables.... and remove any usb devices(pen drive or flash drive) and try booting the computer... if not we'll try with few other things...
Jul 30, 2008 | Toshiba MK8025GAS 80 GB Hard Drive
Hard Disk Drive Not Detected
Does your hard drive get detected in the BIOS? If yes then you can recover data by plugging that hard drive as secondary and running a recovery application like Recover My Files.
Dec 23, 2007 | Seagate (ST3160827AS) 160 GB Hard Drive
Seagate HDD 40GB 7200RPM ATA100 2MB (ST340014AP) Hard Drive Logo
73 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
