Question about Nokia 3120 Cellular Phone
Nokia 3120 restarts automatically.
Namaskar! ihave a nokia 3120. ihave set goto as personal shortcut key but now on pressing goto it restarts morever ihave lost my gallery folders icant store tones and wallpapers. calendar is also not working when i tried to create new folders in gallrery it automtic restarts.somebody please help me. ihave tried the code *#7780# all the settings resets but goto remains as shortcut key. codes like *#7370# do not work on it.
  • Anonymous Mar 24, 2014
    keyboard not working, names shortcut not working
    Problem Solver:
  • 7 Answers
Reformat will work
Posted on Aug 21, 2008
Password reset code
In order to reset the security phone codes of a Nokia 3120 Classic, you must do the following:1.Press the phone's 'menu' key.2.Select 'settings', and then 'security settings'.3.Select 'Access Codes', and then enter the requested security code for your Nokia 3120 Classic. The default code is '12345'.4.Select 'Change Security Code', then enter the desired code.5. Press the phone's 'exit' key. GOOD LUCK LET ME KNOW IF IT WORKS
Dec 29, 2013 | Nokia 3120 Classic Cell Phone
Tip
Nokia 5800 Tips
5800 Tips and Tricks
1. To bring out the Shortcuts on your Screen/Desktop-> Settings/Personal/Home Screen/Home Screen Theme and select Shortcut bar, you can then select which shortcut to display if goto "Shortcuts". This will also bring out the "Track" playing being displayed when you open the Music Player.
2. Tap the Clock to bring out the Clock menu and make your alarm, alarm repeat is now built-in.
3. Tap the "General" or Date (the set Profile besides the clock) and the Profile selection menu pops out, almost similar to pressing the "Power" button in all S60, but here the Remove memory is not shown, but "Calendar" shortcut is included and the other profiles as well.
4. If you are on the Numeric Keypad, pressing the [#] key alternately will toggle the General and Silent Profiles, same as before, which means long press on zero [0] will bring out bookmarks for the Web.
5. Tapping on the displayed To do or Calendar entry will bring you immediately to that particular item.
6. Tapping the Active Icon on the Top Left (near the battery indicator) will give you shortcuts for any of the active icons.
7. Long press on the Green Call Button will still activate the Voice Command Prompt
8. Long press on the center button is similar to the Long press on the "Menu" key (the yin-yang key on most S60) which will bring out the menu for all the active applications.
9. Go to Applications/File Manager and setup "Backup" for automated backup schedule of your phone data.
10. How to update your Nokia 5800 firmware using your phone.
Presss *#0000# to display phone factory information and firmware
Now press options and select check for updates
The newest update is sent to your phone from nokia
Download and install updates.
This is done using GPRS or WIFI Connectivity.
General Tips
1. Use Dialer and press # for about 2 seconds will switch the profile between Silent and General; press and hold 0 will open the web browser; press and hold 1 will open the voice mailbox
2. There is a shortcut key for Music, Gallery, Share, Video, Web shortcut at the top right corner just below the front camera
3. Press and hold the Green caller button when standby mode will activate the voice command. You could call the name from the contact or application name.
4. Organize your sms by grouping them like outlook by Messaging -> Option -> Setting -> Text message -> Other -> Show messages in groups -> Yes
5. Notification light will blink if there is unread sms/missed call. It could be turned off at Settings -> Notification light -> Off
6. If the touch input is not accurate, you could calibrate your screen at Touch Input-> Touch Screen Calibration -> ( Tap around the 4 dots at the corner)
7. Turning control functions:
a. Rotate your screen horizontal or vertical
b. Silence your phone for incoming call by rotate your phone with screen facing down.
c. Snooze the alarm by rotating phone screen facing down
8. Theme effect will give 3D and transition effect if on but will slow down your tube considerably. Settings -> Personal -> Themes -> General -> Themes effects -> On/Off
9. Shortcut to exit application : Press and hold the middle white button then press and hold the program that you wish to quit, an open/exit option will pop out (useful for those haven’t install handy taskman yet)
10. When using handwriting input, slide from left to right is Spacebar, right to left is Backspace
11. Organize your menu by Menu -> option -> organize. You could drag and drop the location of the application you wish to relocate.
on May 12, 2010 | Cell Phones
Tip
Nokia 5800 XpressMusic Smartphone Tips and Tricks 1. To bring out the...
Press*#0000# to display phone factory information and firmware
General Tips
Battery saving Tips
1. Always turn off wireless scanning, Blue-tooth when not in use
2. For those not using 3G, choose your network mode to “GSM” instead of “Dual mode” which will consume more battery. Settings -> Connectivity -> Network mode -> GSM
3. Less Display Light
a. Setting -> Phone -> Display -> light sensor (move the slider to the left)
b. Setting -> Phone -> Display -> Light Time-Out (lesser time to save battery but annoying if too short while you are playing games)
4. Always terminate the application properly that is not using by using Option ->Exit. It might be running background and consuming battery which you don’t know.
Memory Saving Tips
1. Restart your phone if the memory less than 30MB, you could either soft reset (User a dialer and dial 5 * * then call) or hard reset by pressing the power button
2. Use Handy Taskman to close all application regularly or kill application that is not in use.
Camera & Picture tips
1. Some noise could be reduced if set the ISO sensitivity to low instead of auto.
2. When viewing pictures, you could use your stylus to view for previous (slide left) or next (slide right) picture like iphone feature.
Video
For converting video that is high quality to play at 5800, should use the mp4 format as below (All is 16:9 widescreen):
a) Xvid @ 678kbps resolution 480×272
b) Xvid @794kpbs resolution 640×352
c) H.264 @ 512kbps resolution 400×224
d) H.264 @ 550kbps resolution 400×224 (Recommended)
Music tips
1. If you can’t find your songs after transferring from your pc to memory card, go to music player -> Option -> Refresh library
Application Tips
1. Always install your phone theme on the memory cards. This is because if some theme does not work (Christmas tree) then you need to flash your phone.
2. Uninstall your application in proper way. Use Menu -> Setting -> Application mgr. -> Installed apps -> Choose application then option n uninstall
5800 Hard Reset(credit goes to ArunGupta)
WANNA HARD RESET YOUR NOKIA 5800 XM?
JUST PUT *#7370# AND THEN PUT LOCK CODE(I.E 12345) BACK UP YOUR PHONE MEMORY BEFORE DOING THIS
NEW LOCK CODE METHOD FOR NOKIA 5800XM
PRESS GREEN KEY + RED KEY + CAMERA KEY WHILE BOOTING YOUR 5800 JUST PRESS IT UNTIL YOUR DEVICE RESTARTS
This method is for nokia 5800 XM
on Mar 05, 2010 | Cell Phones
Nokia 3120 Classi Supportive File Noting to Display
Pada program jika dipilih muncul tulisan "Supportive file. Nothing to display."
Untuk nokia 3120 classic, bisa dicoba alternative ini:
-> Pastikan progam yang hendak dipakai sudah diklik "options" atau bisa diatur dulu "application access"! (Supaya program dapat muncul)
-> a. Pilih "menu-settings-display-active standby-active standby mode (on)
lalu pada posisi standby pada shortcut bar pilih "options-select shortcuts-application list-silahkan pilih programya (ditandai)
pilihannya:
done-done-(save change? Dan pilih "yes"
Lalu pada posisi standbay pada shortcut bar, dipilih program2 yang sudah dipilih
b. Cara yang ke 2 bisa memanfaatkan tombol shortcuts:
"Menu-settings-display-my shortcuts-left selection key atau right selection key atau navigation key-application list-pilih programnya
Pada posisi standby, silahkan dipilih pilihan tombol shorcut yang sudah diatur
*Semoga bermanfaat
Jan 28, 2012 | Nokia 3120 Classic Cell Phone
Unable to reset nokia 3120 classic to factory reset It asks for creating new code accepts no code
Dear murari_verma
Type default code as 12345. I think this will solve it. Otherwise you have to change the software for that you should go to a service shop.
Mar 03, 2011 | Nokia 3120 Cellular Phone
Go to options became restart ?
you may format the set by code *#7780#
Mar 08, 2009 | Nokia 3120 Cellular Phone
How to set different ring to different callers
Go to contacts.
Find the person you want a unique tone for.
Press MENU.
Goto CARD.
Choose RINGING TONE and browse for required tone.
Shortcut is to use Ctrl-R from the required open contact.
Jan 29, 2009 | Nokia 9300 Smartphone
Gud evening sir im ravi my mobil model no is nokia 3110 c i have one problam my musiplayer is not opening how will solve that prolam
1.Format your memory card
2.Make shortcut on your mobile so u can access very fast to your media player
2.1. In SETTINGS/DISPLAY/ACTIVE STANDBY/ACTIVE STANDBY MODE (TURN ON)/PERSONALIZE VIEW (MAKE IT THAT SHORTCUT BAR IS THE ONLY ONE THERE)
2.2. In SETTINGS/MY SHORTSUTS/NAVIGATION KEY make it so that standby key is 2nd
2.3. Get back to main screen and press DOWN key, options, select, select media player, and save, in organise shortcuts make it 1st and save your progress
3.Upload up to 5 songs
4. Update your media player, mobile will restart him self! BUT!!!...
5. In order to stop restarting u have 3 sec to start updating music library again
6. If u done all at step 2, u need to press fast one time down, central button, left blue line, down, central, up, and central (Need to be pressed in 3 seconds)
7. If u success in this 6th step u hawe solwed problem!
8. Next step is to upload next 5 songs and repeat steps 4-6
(9.) If you cant press so fast buttons to restart uploading I suggest to create a folder named "Amp3" so he can be first when u access to your memoru card so you could
erase him fast to stop restarting, instead formating whole card (In SETTINGS/MY SHORTSUTS/LEFT SELECTION KEY(Make it Gallery, so you can access fast to memory card to delete folder "Amp3"))
(10.)Buttons to erase "Amp3 folder" - While in main screen press : Left blue line, center, left blue line, down, center, center (Need to be pressed in 3 seconds)
(11.)You hawe stopped restarting and kept pics, and images on memory card
Dec 04, 2008 | Nokia 3110 Cellular Phone
NOKIA 3110 CLASSIC RESTART PROBLEM
hi i am imran in kota (borkheda) my mobile Nokia 3110 c is 7 time problem in restart it is very serious and ptt problem. pleas help me. ok
May 17, 2008 | Nokia 3110 Cellular Phone
My 3120 mobile is automatically switiching on and switching off
nokia 3120 auto of is the mobile software problem change sofware enjoy if when u go to GOTO then auto off that is also software problem
Feb 11, 2008 | Nokia 3120 Cellular Phone
Nokia 3120 Cellular Phone Logo
547 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
