54 in big screen phillips hi def tv picture has green shadow all around it.
  • 8,617 Answers
Does it look like a glowing halo, and makes the set impossible to adjust it out? Please respond to this same post I may be able to help, as it sounds like a coolant problem, very common in phillips TVs
Posted on Jul 19, 2008
I have a Phillips 60" rear projection TV. recently
Tv have a problems known as a convergence problems,it is dead.The tv convergence board it is dead,that why ur tv picture are R,G,B colors lines mis alignments,have colors shadows picture or 3D picture lood alike?The tv convergence board require changes 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence picture problems.The shop will cost u like $300-350 for parts and labors.
Jun 01, 2011 | Philips Televison & Video
I have a Phillips projection tv. The picture looks curved and is crooked along the bottom of the screen. Red and green shadows appear around objects. Can you tell me what I need to do?
It sound as if you have convergeance errors.
To adjust the convergeance, follow the service manual's instructions as if you don't, the controls are interactive and it will be difficult to complete a reasonable adjustment.
Hope this helps.
Nov 19, 2010 | Philips 55PP9363 55" Rear Projection...
Green light flashing and no picture on our tv
2004-Model H 347 - 10839 Phillips big screen HDTV. The picture went 3-D.
Dec 25, 2009 | Akai PT46DL10 46" HDTV-Ready Television
Philips 55P8288A tv has a dull color and a red hue.
This sounds Like the the coolant for your piture tube has become cloudy and needs replacement (usually blue or green tube - thats why the image seems ovrely red).It's a big job (labour wise) since completee dissassembly is required ($200-300). It can be done youreself - check out TVrepairkits.com to get the coolant and instructions.
You can confirm that this is the problem by dissassembling the unit to the point where you can view the face of the CRT's (red green and blue) directly.
Nov 28, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
I have red and green shadow on top and bottom of the screen.
Ur Convergence board is dead or deffective with the IC chip.
Aug 17, 2009 | Akai PTH5498 54" Rear Projection...
BOW PICTURE AND HUE GREENS REDS AND BLUES LIKE SHADOWS
the tv had intermittant solder connections already but h\they appeared when the tv was moved to hook up the digi-box. The solution could be as simple as resoldering the power convergence amps.
Aug 06, 2009 | Televison & Video
54" Projection TV
Your green gun in our tv is misagligned/out of focus. Your tv uses red, green and blue guns that layer in different shades and mix to create the different colors. Your green is a little off so the colors aren't mixing right which explains the green haze and the shadows. A tv repair man can fix this problem pretty easily and it isnt expenisve.
Aug 28, 2008 | Akai PT4298HD Rear Projection Television
Mitsubish hd 1080I wt 46809
Check settings first to make sure no one changed anything out of the ordinary. Are the shadows that of a color or darkened shadow? It could be out of convergence, which can be corrected in the menu - or it could be low quality video cables to. Also, if there is no green, does a white color show up when you're in a menu mode (Red+Blue+Green = White Image)? If so, then the green picture tube is working and it's just a color adjustment, otherwise you may have to invest in a new green picture tube.
Apr 22, 2008 | Televison & Video
TV projects a pink/green shadow
Logically proceed one source at a time = disconnect all,
then hook-up one at a time or hook-up seperately.FYI, the
RF coax , composite and s-video inputs all share the same
circuitry, whereas component is a whole seperate video
processing circuit, with another difference between 480P and
1080 I . Sounds like you have a 1080 I problem, which might
be a little sister board..............................T.
Let me know..............Thanks.
Oct 07, 2007 | Akai PT5598HD 55" Rear Projection...
Hd ready?
On any High Def TV, the reciever you need for this set, which does not have a HD receiver in it, is half the equation. Most HD channels have some HD content mixed with SD content on the same channel. SD content on HD signal from cable or satellite tends to be slightly blocky due to the native signal resolution and the resolution of HD (1080i/p or 720i/p).
Apr 30, 2007 | Akai PTH5498 54" Rear Projection...
Televison & Video Logo
108 people viewed this question
Top Televison & Video Experts
