Question about NetGear DG834G Router
Slow Problem is that after unplugging power cable and replug it download perfect but slow down after a few downloads, then have to unplug and replug again to get it going
    Problem Solver:
  • 11 Answers
How many kbps router u have if u have then problem the compny give u a boud on the slow speed when u reset your router its take a ip thats ip has a slow speed if its fix then u have change it on DHCP if DHCP is off ur router on fix ip & thats ip is slow taht y u have got a slow speed u have to do this reset your router & reconfiger it your problem will solvs
Posted on Jul 19, 2008
No picture on TV
Not sure if you saw Tom's Guide
at Sharp lcd tv power button flashing
(1) 4tinyhearts said:
I unplugged the TV and held the buttons down and it continued to flash. I continued to hold down the two buttons and replugged it in again and it worked. TV back up and working.
(2) lastditcheffort said:
Unplugged it. After looking for a new tv online I decided to try getting it to work. So, plugged it back in and held down the power button, a red light came on, held down the power button again and an orange light came on, held down power button again and green light came on and tv powered on. This was simply a case of trial and success!
(3) Nateinportland said :
unplug, hold power button, plug in. If that doesn't work, unplug all the HDMI cables, unplug the power, hold power button, plug back in.
Jun 04, 2016 | Sharp Aquos Televison & Video
The lights are flashing and won't stop. I tried to unplug and replug same results ...what should I do?
As far as I know, the flashing lights are an indicator that the slow cooker is on, but awaiting instructions. You need to put in a time and then a temperature and then it will stop.
I personally find the power button very disconcerting and keep having to stop myself pressing it once I've programmed the slow cooker, and accidentally switching the thing off.
Nov 05, 2012 | Rival 38601 Smart Pot 6-Quart
TV turns itself off??
Take a second look in the power supply where the power cord goes for bad caps----a few examples:
Good one on the left and puffed up one on the right
Extreme example of ones the arrows point to and notice all the perfectly flat tops on others
May 28, 2012 | Televison & Video
I have the same problem with my computer not shutting down, it just stays on, even all night saying it is shutting down (blue screen). I have a laptop HP Pavilion Entertainment Notebook PC w/XP. It is also...
This sounds like a hard drive error. You should deliver it to a professional, or test it by yourself it that is possible. If you have some kind of warranty for your computer, you should deliver it were you bought it.
Nov 14, 2011 | HP Computers & Internet
HP 8500 Shuts down after a few hours
Hi David,
Try the firmware update for your printer released by HP. Click on the link below and select the Operating system from the list.
Click on + on Firmware Update. Download and Install.
Download Firmware Update
Regards,Suhail
Nov 12, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
Hello, I have a Lexmark x5470 and can not scan at all. When put it on scan, it does say it is downloading and after awhile it says can't retrieve. Clem
If scanning was working perfectly before, it could be a minor communication issue. Unplug your printer from your computer. Unplug and replug your printer into the power source to reset itself. When your printer turns on completely, reconnect it to your computer. Then try scanning again.
Feb 17, 2011 | Lexmark P4350 All-In-One InkJet Printer
How do I get my Cannon scanner to run with Vista.
You can download the drivers from here (click here) and here (click here). Download and install both the drivers, it should work perfectly.
I hope you know how to download from Rapidshare.com. Open the link, wait for few seconds and click "Slow Download" (if you have a repidshare premium accounts that better), wait for few seconds (you see a countdown timer once you click the "Slow Download") Once the timer resets, click the "Download Now" button or in most cases, download will begin automatically.
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Oct 02, 2010 | Canon CanoScan LiDE 30 Flatbed Scanner
My 42HDS69 Hitachi has a recurring problem of not turning on. I unplug from outlet for awhile and sometimes it will turn after I plug in outlet, Other times it takes a few hours for TV to turn back on. ...
MY TV KEPT GETTING WORSE EACH DAY ALSO. BUY A CAN OF SPRAY AIR WITH THE EXTENSION SPRAY TUBE. WHEN YOU GET THE TV RUNNING SPRAY THROUGH THE HOLES IN THE BACK RIGHT ONTO THE FAN BLADES OF BOTH FANS. THE DUST WILL FLY OFF THE BLADES. A VACUMM HOSE WILL HELP PULL OUT THE DUST. ALSO SRAY THE POWER SUPPLY BOARD FOR DUST. I APPEARS THE FANS SLOW DOWN WITH DIRT ON THEM AND THE EXTRA HEAT BUILD UP JUST AFTER THE TV IS SHUT DOWN IS CAUSING THE POWER SUPPLY TO BE IN A SHUT DOWN MODE WHEN POWERED UP THE NEXT TIME. BEEN TWO WEEKS NOW AND WORKS PERFECTLY NOW AGAIN.
Dec 17, 2009 | Hitachi 42HDS69 42 in. Plasma Television
Old hub
The hub won't hurt your downloads from the internet. If it is a "hub" and not a "switch", it can affect transfer speeds between your pcs, but the impact probably won't be noticeable on a home network with only two pcs. You do not need to unplug the power to the hub when plugging/unplugging ethernet cables.
Feb 17, 2008 | Computers & Internet
Slow internet
If you have 3mb, you have cable internet right? If so, the cable company cuts your speed off if you download too much over a certain period of time. My cable company confirmed this. I can download all I want from midnight til noon, but after that... They will cut your speed off if you download more than a certain amount. You can call them to find out what the amount is.
Feb 04, 2008 | Edimax BR-6104K Router (br6104k)
NetGear DG834G Router Logo
411 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
