Question about Philips Magnavox 9P6034C 60" Rear Projection Television
Magnavox 51" Rear Project Red Streaks
I bought a used Magnavox 51" Rear Projector. There is a red streak down the center of the screen and in the corners. I have already lined up the red on the convergence but it hasn't helped.
What are IC's? Is it worth it to fix? What would average repair cost be?
Posted on Aug 01, 2008
  • Philips Master
  • 3,459 Answers
Sounds like the convergence IC's went south.
Posted on Jul 31, 2008
I have a KP-51ws520 that a friend gave up on and bought a new LCD TV. About a year ago, after a power outage in our neighborhood, this tv now has noticeable streaks across the screen at all times. Is...
It depends on what the problem actually is; are the streaks colors like red or blue outlines around lettering etc?
The more you tell me the better I can help. I will post a photo or two of what convergence problems look like.
This set is also prone to another problem, on a blank video input look at the screen: you should only see Video 1 (etc) and if you see faint curved lines (red, green or blue) and or the back ground is also wrong color you have the second problem.
let me know which it is.. If this information helped you rate this solution as very helpful as I do this here for free.
SD TECH
Aug 20, 2010 | Sony KP-51WS520 51" Rear Projection...
I have Panasonic PT-LC75U bought in 2003, with 740hrs on my 2nd bulb. I have red vertical streaks that appear on the image after warm up, and get worse (more streaks) the longer the projector is on. I...
Steve, your issue is not the bulb...
Sounds like you have a problem with either a ribbon cable from your main board to red LCD panel, or a main board failure.
Aug 15, 2010 | Panasonic PT LC75U Multimedia Projector
Lot of red streaks across screen.Try to adjust convergance, blue aligned perfect but the red didn't
possible fuse. if the red is curved or bent, if the red is straight try covering tv with blanket so the sensors get a good reading. again if the red is bent, and fuses are good..... bad convergence ic's.... local service center
Nov 24, 2009 | Hitachi 43FDX01B TV
Red and blue streaks across the screen top and bottom
The Convergence Amp IC's are bad. You should call a good TV Tech for this repair.
Jul 11, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Red streaks across my screen of my tv
is it like a double image kind of thing?i dont know what 'red streaks' are....
Oct 10, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Red streaks
need to have the STK IC's replaced to correct convergence problem
Mar 05, 2008 | JVC AV-27230 27" TV
Phillips mo.51pp9303h/17
TV made a popping noise and now it wont turn on or anything??
Feb 25, 2008 | Philips 51PP9100D 51 in. Television
Red streaks
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 06, 2007 | Hitachi 53UWX10B 53" Rear Projection...
51 magnavox projection tv-color mixing wrong
The are controls on the inside of the tv above the circuit boards for focus and to turn up intensity of the projector lamps (red, green, and blu). If you turn it up too far all three projector lamps kick off. If this happens, power off the set and turn down the lamp that you turned up. Power it back on and slowly turn the projector lamp up until the picture looks OK. You have to take off the panel on back of set to get to the controls.
Nov 19, 2007 | Philips Magnavox 51MP392H Rear Projection...
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
83 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
