Question about JVC Cybercam GR-DX75 Mini DV Digital Camcorder
Lense cap problem
I go through the process of turning on my jvc and take off the lens cap in order to start filming, but am unable to, because the camera thinks the lens cap is still on?
  • 34 Answers
Replace CCD Image sensor ( ccd base assy).
Posted on Sep 05, 2008
I too had this problem and as I had taken out an extended warranty I called the store I had purchased the camcorder from. I was told that this model JVC had a problem with the lens cap.They sent it off to JVC who fixed it without question
Posted on Aug 22, 2008
Ys lense cap i it is not
Do you mean no lens cap attached but it shows remove lens cap? If so, most likely your CCD needs replacement. Consult your nearest JVC Service Center
Mar 07, 2010 | JVC GR-D244US Camcorder
Can you please tel me what my vivitor camra lens fits what camras etc it is a vivitor 200mmm 1:3.5 auto telephoto no 28516468 62mm do you know the price these lenses go for many thanks
The lens itself is virtually worthless, possibly £10 at best and even then it needs to be flawless, in perfect working order and to have both front and rear protective caps. Collectors are really only interested in near mint examples of manufacturer's own brand lenses. Most lens buyers are now after lenses which work with digital SLR's and older lenses designed for 35mm film are often less than ideal or completely useless. Modern lenses are usually zoom models and fixed focal length primes like yours are less versatile.
Regarding the mounting, the serial number is no help. Look around the mounting for clues, it might have any of the following:-
N = Nikon
Ca, C, or MD = Canon
CY = Contax Yashica
O or OL = Olympus
M = Minolta
P, PK or P = Pentax
M42 = 42mm screw fit used on old SLR's, also Zenith and Practika
X = Fujica, this is rare so may be worth a little more but there are also very few Fujica owners anyway so may not sell at all.
If there are no clues that you can make sense of then take the camera along to a camera shop, preferably one which sells used 35mm film SLR's and they should be able to identify it for you.
I hope this has helped you, if so please rate my answer.
Feb 21, 2010 | Cameras
If i take a lense of my camera do i expose all of the film in it.
NO.
The film is behind the shutter. Film is only exposed when the shutter is released, and it only affects the film directly behind the shutter. So remove your lens, swap it for another lens, but do not leave the front of the camera open. Keep a lens or a body cap on it always.
Oct 08, 2009 | Photography
It says lens cap when lens cap is removed
KEEP UR HAND CLOSE TO THE LENSES, FACE DETECTION IS ACTIVATED OR U RA MAKING PICTURES OR VIDEOS IN THE NIGHT. TRY WHERE THERE IS LIGHT
Aug 09, 2009 | JVC Everio GZ-MG20 Camcorder
JVC COMPACT VHS CAMCORDER MODEL NO. GR-SXM250U
I cant find a solution but causes may be :
1. Did you remove the LENSE CAP ?
2. PRobably there is a small switch that tells the camera that LENSE CAP is on or something dunno
About that recording problem
1. LCD Broken?
2. Other technical issues ...
Im not proffesional or anything :P Wish you luck with better people at this D: .
Feb 20, 2009 | JVC COMPACT VHS-C CAMCORDER
Dropped camcorder
When you dropped the camera you ended up jamming the iris closed. There may be additional damage within the lens assembly. In order to repair the stuck iris, the optical lens assembly needs to be partially disassembled. This is not a project for the novice. This should be taken to a JVC authorized service center for a repair estimate. The estimate will cost about $50 or so.
Dan
Apr 03, 2008 | JVC Everio GZ-MG57 HDD Camcorder
Lense Cap Error
This problem is caused by a stuck aperture assembly. The problem has occured on multiple models made by JVC (GR-DF430u, GR-DF450U and GR-DF470U). You have to have some degree of technical aptitude in order to disassemble the unit and access the part causing the problem. The tiny motor that opens the aperture flaps is not able to overcome the sticky oil/grease that JVC unwisely used on this part. Therefore the flaps stay closed, and the camera sees no light when you remove the lens cap. This makes the camera think you haven't removed the lens cap, causing the "lens cap" error.
If you feel like you have the skill and you are careful, you can disassemble the unit and clean the part yourself. It takes longer to take the unit apart and put back together than it does to clean the sticky oil off the part.
If you contact me, I can send you a diagram of where the part is located that you need to access. This is not recommended for amateurs, as you can damage the unit and cause other problems if you aren't somewhat skilled in disassembly of electronics.
Mar 03, 2008 | JVC GR-DF450 Mini DV Digital Camcorder
Lens cap problem
This is A known fault with the ccd sensor and if you have your receipt you are entitled to a free repair,
I had the same problem and got mine fixed for free.
Feb 17, 2008 | JVC Cybercam GR-DX75 Mini DV Digital...
700x digital zoom mini dv - focus problems
Hi, its your ccd sensor. JVC are doing a free repair until June 2008. Visit their website for contact number and more information.
Dec 31, 2007 | JVC Everio GZ-MG37 Camcorder
Lens Cap Problem
I saw something about this on another support board. I think it was on pechorin.com. I can't be sure but it sounded like this is a known issue for JVC and they were extending their service and doing post warrenty fixes.... Might want to check this site and/or contact JVC. Good luck
Apr 09, 2007 | JVC GR-DX97 Mini DV Digital Camcorder
JVC Cybercam GR-DX75 Mini DV Digital Camcorder Logo
154 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
