Question about HP Computers & Internet
Iam instaling a new dvdrw in replace of the orgenal one . But however when it says to connect the jumper to the master exct but their is no wire for that option . so what do i do ? my pc is an ed895aa-aba ssn is cnh53500t4
    Problem Solver:
  • 32 Answers
First find out the jumper placed on and if it placed as slave remove and insret as master
Posted on Jul 19, 2008
I installed the new cd/dvd driver, but the compter won't install it.
If this is the only drive on your PC you have to make sure that you have set up the jumper to master. the jumper is located in the back of the drive. you must also install the driver for the drive to work properly.
Feb 28, 2011 | Sony Optiarc AD-7260S - DVDRW (R DL) /...
MY COMPUTER KEEP SHOW NEW HARDWARE NOT FOUND
you may have not properly set the jumpers on your new installed hard drive.
usually a computer will have 2 eide drive controllers where you would connect a ribbon cable. a ribbon cable has a middle connector and end connector and obviously another end connector that connects to the motherboard)
now you can connect upto to devices to that ribbon cable. most computers will have one device connected to the end connector (the hard drive) and no devices connected to the middle connector or sometimes they may have 2 device on the same cable: the hard drive on the end and a cd/dvd drive on the middle. others computers may have one ribbon cable for each device as computers usually come with 2 drive controllers (so you can connect 2 cables which means a total of upto 4 eide devices)
now, when you connect devices on 1 ribbon cable, the end device is the master device, the one the middle is the slave. to make a device a master or a slave you need to set a jumper. the jumper is usually located in between the ribbon cable connector and the power connector, the legend to know where the jumper goes to make it a slave or a master is usually on the label of the hard drive. you may need to check that label and with some pliers make the proper setting for that jumper.
on a new hd usually the jumper setting will be in master. so if you connected the hard drive on a ribbon cable that already has a master at the end it may not be detected. try to connect that master device on another ribbon cable that has no other devices connected and connect it on the end connector (not the middle one). if you have no other option but to connect it in the middle already having a master device at the end, set the jumper to on the slave position.
while you are at it. make sure you have your power connector and data (ribbon) cable properly seated.
if the caviar hd your are trying to install is an old hd and you know that you have the proper hd configuration and the cables properly seated, it is possible that no detection means hd failure.
Apr 04, 2010 | Western Digital Caviar WD1600 (1600YD) 160...
I just put this drive in a new computer and now it won't read it opens i put a disc in and then close and it does nothing. i have changed the cable, change the power. and now i think i might need the...
Hi, well I think your DVDRW is OK & you don't need any driver. The detail that you are missing is the "jumper" found on your DVDRW. Normally you have 2 connections on your IDE cable. The upper one being "master" & the second middle one "slave". You should set the jumper according to the place on the cable where it is connected. You will find CSM written on your DVDRW. 'C' means cable select, 'S' means Slave & 'M' means Master.
You should refer to it when setting the jumper. If you have 2 drives on that cable & they are both set as 'slave' or both 'master', therefore only one would be detected & displayed in my computer.
Your problem would surely be solved... & have a nice time.
Please send us your vote & feedback to help us help you.
Feb 17, 2010 | NexxTech DRW-6S160P DVD±RW Dual Layer...
Compaq presario sr1800nx won't turn on
Check the jumper settings on the DVDRW. Depending on IDE location, you need to set the jumpers accordingly. If you have the main system hard drive on the same IDE channel as the DVDRW, set the jumpers on the DVDRW to slave, if that don't work, set them to Cable Select. I'm assuming it's an IDE drive and not SATA.
Dec 30, 2009 | Compaq Presario SR1800NX Desktop PC
How do i install a used hard drive into an eMachines T2341? The hard drive still has information on it. do i set it as master, slave, or cable select? hard drive is an IBM 10.1 gb
There are two possible solutions depending on how your desktop is setup.
#1 install the 2nd hard drive and put jumper to CABLE SELECT. When you start the computer it should now appear in the bios as a SLAVE or 2nd hard drive. If not go to #2 below
#2 Turn system off again and change jumper on 2nd hard drive to SLAVE.
Now when your computer restarts it will appear in your bios correctly as the 2nd drive/SLAVE.
Do not make it "MASTER" or you will be trying to boot up to this drive and it may not work as you planned.
FYI: "Cable Select" means the hard drive determines which one is Master and which one is Slave by where it is on the data cable.
Good Luck
Dec 30, 2009 | Computers & Internet
I am replacing my hard drive (Gateway GT5694) since the original crashed. I didn't realize the replacement would have a jumper to install and therefor didn't look at the original close enough to see if it...
The new hard drive should be set to master drive, if not just make sure the jumper is in the master slot. A small diagram should be on the hard drive. Then make sure you connect the hard drive to the end ribbon cable connector.
Nov 24, 2009 | Gateway GT5694 Desktop Computer
I have just put a new dvdrw in as my old one stopped working i also have a dvd drive when i put new one in the dvd drive one was not showing up in my computer the new one did but just froze
This is certainly a jumper issue... You must have one set as Master and one set as Slave unless you have both set as Cable Select... If you have tested this and nothing works then the drives are probably not compatible with each other, but I am almost certain this is a jumper issue since it is freezing.
Dec 18, 2008 | Computers & Internet
Samsung SH-S182 DVD±RW Dual
If the drive is "Master" (the first drive in cable line installed) then the jumper goes to "MA", if it is a "SLAVE" connected drive then the jumper goes to "SL".
May 06, 2008 | Samsung SH-S182 DVD±RW Dual Layer Burner
Jumper
Does the cord going to your CD-RW hasve asnothe plug further down the line most computers can connect 2 cd type drives!!!
Jan 02, 2008 | Pioneer (dvr-a06u) DVD±RW Burner
Computers & Internet Logo
16 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
