Question about SanDisk Sansa m240 MP3 Player
Deleting music from mp3 player
I want to delete all the music fom my sandsk sansa mp3 player.. how do i do that?
SOURCE: deleting music from mp3 player
do u have Tronic firmware for mp3/wma/fm/rec ?
Posted on Aug 12, 2008
How do I remove a song or songs from my Sansa SanDisk mp3 player model m240?
There are 2 ways to delete music files. You can delete them from the player directly or
using the computer.
To delete music files directly from the Sansa player, follow these steps:
1. In playback mode, press Submenu button.
2. Select the Delete Song item.
To delete music files using the computer, follow these steps:
1. Connect your Sansa to the computer.
2. Select Open device to view files using Windows Explorer on initial connection.
3. Locate the folder where your music files are stored.
4. Highlight and delete the music files or folder.
I hope this helps.
Thanks.
gylacz
Sep 01, 2011 | SanDisk Audio Players & Recorders
Sansa clip+ 4 GB mp3 player. How do you delete
Select the song/book (you want to delete) to play, press down button (Music Options), and press all the way down until you meet delete song/book, press delete song, select yes.
Good luck
Jan 21, 2010 | SanDisk Sansa Clip MP3 Player
IM TRYING TO DELETE MUSIC FROM MY MP3 PLAYER
Windows Media Player is the program you will be using to delete files off your Sansa. To delete files from your mp3 player using Windows Media Player 10:
http://www.microsoft.com/windows/windowsmedia/knowledgecenter/mediaadvice/0085.mspx#EDF
To delete files from your mp3 player using Windows Media Player 11:
My Directions:
1. Connect your mp3 player to the computer
2. Open Windows Media Player
3. Click on the icon of your Mp3 player on the left-hand side of the Library
4. Click on the Songs, Tracks, or other Music Folder
5. Find a song or songs that you want to delete
6. Left-click the song once to highlight it
7. Press the “Delete” button on your computer’s keyboard
if (!window.netshel_ord) { netshel_ord=Math.random()*1E16;} if (!window.netshel_tile) { netshel_tile=1; } document.write(''); netshel_tile++; window.google_render_ad();
Mar 23, 2009 | SanDisk Sansa e260 MP3 Player
PROBLEMS DELETING MUSIC FROM MP3 PLAYER
Go to my computer scroll to sansa or your MP3 player and open the music folder and open each sub folder and delete Songs manually then delete the folders them selfs then format a couple of times hope this works
I am wanting to delete music
Go to my computer scroll to sansa and open the music folder and open each sub folder and delete manually then delete the folders themselfs then format a couple of times hope this works
I can't delete music from my Sansa e260
You can remove content on the Sansa itself by highlighting the song you want to delete, then down click and select "Delete" while the song is highlighted.
Also, there is a setting within the software on the PC that you can change to prevent the Sansa from automaticaly syncing if you don't want it to do that.
Jan 10, 2009 | SanDisk Sansa m240 MP3 Player
Aug 12, 2008 | SanDisk Sansa m230 MP3 Player
How do i delete music off my sansa mp3 player?
Source: http://www.ehow.com/how_2023687_delete-files-sansa.html
Step 1Connect the USB cable to your Sansa MP3 player, then hook the other end to a free USB port on your computer. Step 2Give the computer time to recognize the Sansa MP3 player. Once it has, double-click on the MP3 player’s icon to view the music files stored to memory. Step 3Scroll through the list of audio files until you find the ones that you wish to delete from the Sansa MP3 player. Step 4Click on single items or click and lasso multiple files. Step 5Right-click on the highlighted files to pull down an action list and from there select Delete. The computer will ask if you really want to throw the file away. Select OK. Step 6Exit from the window, then disconnect the USB cable from the Sansa MP3 player. The player will automatically turn off. The memory will update the first time you turn the player on after deleting songs. Tips & Warnings
  • Optionally, you can left-click on a file and drag the file icon to the Recycle Bin. Either way, you can delete music that you don’t want from your Sansa MP3 player.
  • Unlike other documents and files, once the music file hits the Recycle Bin, it’s gone. Make sure that you are deleting the correct file.
For more help: http://www.supportrix.com/
Jul 30, 2008 | Audio Players & Recorders
Deleting songs from Sandisk
i don't no how to delete music off my sansa mp3 player with windows media player
Feb 13, 2008 | SanDisk Sansa e250 MP3 Player
Deleting music off of my sansa E250r!!HLP ME
If you originally used rhapsody (or began in Rhapsody mode) , you have to use rhapsody to remove the songs. If that doesn't work, you can manually open the music folder by enabling "hidden folders" under "tools" -> "folder options..." -> click the "view" tab -> scroll and check "show hidden files and folders". Then go to My Computer -> Sansa e250 -> "system" -> "music" -> then delete the songs. I don't know the effects of using this method, so use it at your own risk.
Btw, Real Player should do fine as well.
Dec 22, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa m240 MP3 Player Logo
14 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Jazz Boyce
Jazz Boyce
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
