Question about HP PSC 1410 All-In-One InkJet Printer
Problem with HP PSC 1415 printer on inserting refilled ink cartridge
Error light flashing and "E" indicated in panel - no responses to buttons other than "on/off".
I have tried reseating cartridge and cleaning it.
Do I need to switch off ink level gauge or do something so that printer recognises the refilled original HP cartridge?
Hope you can help, many thanks in advance.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 95 Answers
I have just had my cartridges refilled and now have reinserted them in printer but it keeps saying remove and check colour cartridge (which i have done lots and lots of times), help please
Ink cartridge contains Ink tank, electrical circuit & print nozzles.
Adding ink to ink tank is called refilling, if any fault in circuit/nozzles will indicates the cartridge error.. Before refilling check cartridge health condition.
In your case its sure that cartridge faulty, go for new one..
Nov 10, 2012 | HP PSC 2355 All-In-One InkJet Printer
Why do I continue to get the E error message and blinking light on cartridges
The 'Ink Alert' or 'Low on Ink' message displays on the computer or on the product control panel.If the cartridge has been refilled or re manufactured, 'Low on Ink' or 'Ink Alert' or error messages appears on display panel.Replace with the new genuine cartridge which is showing error on display..
Nov 24, 2011 | HP PSC 1315 All-In-One InkJet Printer
How to install ink cartidge? hp psc 750
1. Allow your injet printer to run entirely out of ink. Unless the quality of your images is suffering, there is no problem with letting your ink run low.
2. Open the printer door. It should fold from the top down toward the tray. When it is open, it should expose the inner workings of the printer.
3. Press the change cartridge button. It is at the top of the printer next to the power button.
4. Pull on the green top of the inkjet ink cartridge and remove it up and out of its holder. Do this gently so the printer is not damaged in the process.
5. Recycle the empty inkjet cartridge or have it refilled at an ink refilling center.
6. Carefully remove the tape from the refilled or new inkjet ink cartridge and insert the cartridge in the same orientation as the one you removed.
7. Push on the green top until the cartridge snaps into place, press the cartridge change button and close the printer door.
Feb 08, 2010 | HP PSC 750 All-In-One InkJet Printer
My HP PSC 1510 will not take refill cartridges, - B/w and Color lights flashing
the cartridges are damage or not the right ones for your printer. first make sure you clean the cartridges before installing cos ink on the cartridge (panel) can stop the printer from detecting it.
Jul 01, 2009 | HP PSC 1510 All-In-One InkJet Printer
F4280 printer and hp 60 cartridge
keep the cartidge in Hot Water for 30 minutes. maybe it works.
May 30, 2009 | HP DeskJet F4280 All In One Printer InkJet
Printer ink cartridge not recognized by printer hp psc 1210
some time hp printer does not reconize refill cartridge or cartridge is damage when refilled so change cartridge
Feb 20, 2009 | HP PSC 1210 All-In-One InkJet Printer
Flashing light check print cartridge
You must replace all ink carts with new ones at the same time. Yeah, this how HP makes its money.
Jan 02, 2009 | HP PSC 1315 All-In-One InkJet Printer
HP psc check print cartridge light is flashing
The "E" means a cartridge problem.
Have you recently changed them?
If so, did yo use "refills" or another non-HP cartridges?
Jan 11, 2008 | HP PSC 1350 All-In-One Thermal Printer
All lights are blinking, printer doesn't work. What does this mean?
This problem occurs for two reasons: the front panel cover was not installed or the ink cartridge access door was not closed before plugging in the all-in-one.
The front panel overlay must be correctly installed before the power cord is plugged in. Follow the steps below to correct the problem:
Disconnect the power cord.
Lift the scanner4.gif lid and carefully line up and install the front panel overlay.
Plug the power cord in.
let me know if this solves your problem wendy.
Dec 18, 2007 | HP PSC 1350 All-In-One Thermal Printer
HP PSC 1410 All-In-One InkJet Printer Logo
379 people viewed this question
Ben Johnson
