Noisy fan on acer 3050
I want to open the case on my acer 3050 laptop to get to a noisy fan. What screws do I need to undo to split the case to get to this fan please?
    President:
  • 778 Answers
All of them, as the MoBo is where the cooling fan is drawing air over the Prossesor. Experience is a plus.
Posted on Jul 19, 2008
How do I take apart to clean fan part real black
Hi Sherin,
You have to remove the screw or undo the clip which locks the front half of the fan cage to the back half. Then you can split the cage open, exposing the fan. You should be able to remove the fan impellor itself either by just pulling it off or by undoing a screw. Once cleaned, reverse the order to reassemble.
Jul 26, 2015 | Dryers
How to fix noisy fan?
look for the fan opening, get a can of air and blow it threw the fan vent, while the computer is off, than let it set for a few minutes than start it back up, if fan is still noisy, than you need a new fan installed.
if you want to do the work yourself you can do it your self. now if you dont want to try it than i have a few place to take it for service.
acer authorized dealer, best buy, or if you have a friend that you trust that will fix it for little to nothing except cost of parts, the fan part for the acer should be around 7-10.00 dollars + labor + shop fees.
www.youtube.com/HOW TO FIX LAPTOP CPU FAN
/how disassemble acer aspire laptop
/how to replace CPU fan acer laptop
/how to oil cpu fan for acer laptop
Apr 22, 2015 | Acer Aspire Computers & Internet
How do i split the case
Chrome drip ring off, knock pin out of planetary, remove planetary, back cover off, black wire and white wire off the control board (both on the same side at the bottom) undo 5 screws under planetary, undo 4 screws remaining in housing underside. Split cases.
Jan 18, 2014 | KitchenAid KSM150PS Artisan Series Stand...
Acer fan noisy
its usually dust problem. open Laptop casing and clean it via Air blooring machine hope it will reduce noise.
Dec 10, 2013 | Acer Aspire Computers & Internet
How to open wahl super trimmer model 1591/1592
Push the blade teeth away from the trimmer body, it will just click off. Undo two screws behind blade, undo one screw at rear of trimmer from the bottom. That's it cases will now split apart.
Jan 19, 2013 | Wahl The Peanut Hair Trimmer
Where are all the screws
Here is the service guide, it has the full disassembly in it. Go to page 65 and there are illustratyions of where all the screws go and their purpose.
http://tim.id.au/laptops/acer/aspire%205050%203050.pdf
Sep 23, 2009 | Acer Aspire 3050-1733 Notebook
How do I get the back off My Acer 5620 laptop. The CPU fan does not seem to be spinning and it keeps shutting down. I've pulled about 30 screws out of it and the thing doesn't want to split.
hi im josh in cebu phils.may i help you? friend if the cpu fan stops spinning the air inside and the processor heats up easily thats why it will shut down.you need to replace the fan of the cpu to avoid further problems to occur. in removing the screw it will not be disassembled easily because it has a safety bracket lock.to make it open you need to look frot he weak spots and you split that side until it opens the whole unit. thats all good luck hope i helped you.
Feb 26, 2009 | Acer Aspire 5610 Notebook
How to open case on acer 3050
The method I would use is as follows:
Plugged into a power strip that is turned off but plugged into an outlet ( to keep a good ground to discharge ESD to ground), remove all covers and screws from the bottom (keeping all covers and screws in an order that you'll remember to reverse on reassembly), then if the case doesn't separate look for screws on top and sides (may be hidden by rubber plugs, so look closely). Either use a grounding strap to your wrist (especially in cooler drier climates), and or touching the metal on the case frequently to discharge the static electricity accumulated in your body, Then you may be able to get to the fan from the bottom or may have to continue disassembly to get to the fan on the other side (usually called component and solder sides) of the MoBo?
I couldn't/didn't find any pictorials on your particular laptop, and this is just generic information I go by and just My humble opinion on how to go about it, so please keep that in mind. BTW I have opened dozens of laptops over the years with successfully opening repairing and closing all that were worth the effort/cost.
Good luck, and I hope this post helps you.
Jul 19, 2008 | Acer Computers & Internet
Drivers for acer aspire 3050
There you go... hope it can help you.
http://cr.am/framed.php?url=http%3A%2F%2Fsupport.acer-euro.com%2Fdrivers%2Fnotebook%2Fas_3050.html&ref=driverguide
Jul 09, 2008 | Acer Aspire 3050-1733 Notebook
Noisy fan?
This is normal.. It is keeping your computer cool when it gets too hot.
If you like this answer please rate it as a FIXYA.
Jun 06, 2008 | Acer Aspire 3050 Notebook
Computers & Internet Logo
206 people viewed this question
David Payne
David Payne
