Hot water tank is overheating excessive rumbling of boiling water
  • 41 Answers
Could be a thermostat or grounded element not to serius to fix should consider a prfetional unless you are handy with electicity and water
Posted on Jul 19, 2008
Water boiling in the overflow reservoir
Considering that the vehicle was never intended to reach the extremely high mileage it has, it is possible that pressure loss from the one of the cylinder chambers is occurring and leaking into a coolant channel, causing air bubbles to surface at the coolant reservoir. In this case, it may be a bad head gasket or a cracked head. Have you noticed a significant decrease in engine power of late? Is there any oil sheen appearing at the top of the coolant in the reservoir?
May 23, 2014 | Chrysler 2000 Town & Country Limited
Water wont heat up unless the central heating is on at the same time and the boost button wont work at all
Need to know more about the system... zone valves ot pumps....indirect hot water tank or internal coil??
Here is a tip that I wrote that may shed some light on things for you...
In most cases problems with the circulator pump boil down to two problems.
The most common is air in the lines causing an air lock.
The next problem is that the pump gets stuck and is not running even though it may be hot and seem to be running. In this cause the pump can sometimes be taken apart, cleaned and it will work, but usually it needs to be replaced.
Here is a tip that I wrote that will explain circulator pump problems in more detail.
Heating Circulating Water Pump Problems
heatman101
Apr 22, 2011 | Heating & Cooling
I am having problems with the connections of my hot water heater. The connection of the cold water to the water tank leaks around the connection. When I tighten it the pipe twisted and it started...
Remember, that COLD water might cause condensation as it nears the Hot Water tank--
However, you seem pretty sure it was leaking-- so-- What type of piping are we working with: Copper, Plastic, or what?
Copper is the best-- but requires soldering fittings-- are you equipped to do that?
Plastic has shrink and expand problems around a Hot Water tank, and might be why you have the leak?
Tell us more, -- how far do you want to get into this?
Mack B
Jan 19, 2011 | Heating & Cooling
Hot water leaking from what i think to be the pop off valve. i tried to tighten it a little and it started leaking more. The unit is 16 years old. The excess water is draining into the catch pan and then...
Hello
16 yrs old? Im guesing this is a hot water heater.Not a air conditioner.
If its still making hot water you may not need to replace the whole unit.
The valve that is leaking is a high pressur relief valve and they do go bad the sprigs become weak over time and some corrosion may not allow the valve to seat properly.
1st step is to shut off all incoming and out going water to the tank.
2nd Shut off fuel or gas to the unit, and annonce to everyone your are working on the hot water heater.
3rd at the very bottom should be a drain valve much like a hose spicket,open this slowly and drain the tank,remember the water will be hot.You may not need to drain it all the way,while draining pop open the relief valve,when you stop getting water from it,you are below it and can turn the drain valve off.
4th remove old relief valve and replace with a new one,i think they are rated at 15 psi or 30 psi blowoff pressure,hopefully there is a tag on it with that info.
When you go to install your new one use some pipe thread compound or teflon tape around the threads before you reinstall valve.
Once done slowly refill tank with water, check for leaks.When full open up hot water valve to house and relight buner.open a faucet in kitchen to hot to bleed off any air.
Jan 14, 2011 | Heating & Cooling
Explain why there is spluttering sound when water is sprinkled on hot oil
Hello. When water is sprinkled on hot oil will sputter because the oil is at a temperature near or over 100 degrees C or 212 degrees F. This is the temperature where water boils. The sputtering that you hear is the water being boiled and creating steam. When the water boils and becomes steam, it expands extremely fast. This creates a "bubble" in the oil and the bubble "popping" makes the sputtering sound.
Dec 29, 2010 | Heating & Cooling
Hot water heater is natural gas type gas is staying on all the time burning even when water is hot it continues to burn. Not hot water tank is over 10 years old should I try to repair or just replace???
The thermostat is what is out of calibration...this is built into the gas valve. Unfortunately the part cost almost what a new tank does. My opinion is to replace.....today gas valve....another 8 years the tank...
May 09, 2010 | Heating & Cooling
We seem to have developed a problem with our boiler, worcester 20/25 heatsave. Every time we turn on a hot water tap, when we turn the tap off, there apears to be a loud noise from the boiler or pipes for...
it seams the valve that senses water flow is not operating properly,causing the boiler to keep heating the water when it has nowhere to go,i,e the taps turned off,thus boiling the water.
Jan 12, 2009 | Heating & Cooling
Central heating system boiling
more information required but if the boiler supplies the domestic hot water cylinder then the stat on the cylinder may be bringing on the boiler also the boiler stat may be up too high try turning it down.
Jan 05, 2009 | Heating & Cooling
Hi, I have hot water coming through the cold water taps in the house, there is a check valve on the cold water return side of the water heater. could this be the problem? The cold water line feeding the...
i have seen a faucet that has a valve on the end (like your pull up on the shower)back feed the hot water or yes you could have a bad ck valve dan
Jul 23, 2008 | Heating & Cooling
Heating & Cooling Logo
56 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Cris Sparks
Cris Sparks
