Question about HP Photosmart C6180 All-In-One InkJet Printer
Error message #Oxc19a0013----Ink system has failed
  • cavehilljim Sep 27, 2008
    oxc19a9913
  • zarigueya Feb 01, 2009
    After replacing the cartridge with the correct HP cartridge, rec'd message "Ink system has failed.... Error 0xc18a0001
    I have turned off, unplugged, removed all cartridges, let sit two minutes, replugged, turned on, replaced all cartidges again, same error message.
    The cartridge came in a two pack; I went through the first in a week; when I shake this one slightly, I can hear liquid ink.
    What the.....
  • 679 Answers
IssueAn 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel. The printer cannot copy, receive faxes, or print.
Solution
Press the On button to turn the printer off.
Unplug the power cord from the back of the printer.
Remove all the ink cartridges.
Wait two minutes.
Plug the power cord into the back of the printer.
Press the On button to turn the printer on.
Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved.
If the 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel, service the printer.
Posted on Feb 03, 2009
  • kratzmeister
    kratzmeister Mar 16, 2013
    One question. How do you remove ink cartridges when the printer is turned off?
3 Suggested Answers
  • 103 Answers
SOURCE: I have a system failed error code Oxc19a0013
A semi-full reset will do the following:
The user settings to the factory defaults, Language and country settings on some models, Fax logs, Fax headers, Fax speed dial information.
Reset the All-in-One to the factory default settings by using these instructions:
1. Unplug the power cable from printer when the printer is powered on.
2. Press and hold Plus (#) and 6 while plugging in the power cord
Posted on Jul 12, 2010
  • 5218 Answers
SOURCE: I am getting ink error
Is the phrase "Ink System Failure" in the message?
First check the cartridges. Remove all of the cartridges. Replace any that are low or empty. Check for damage or a blocked vent. Clear the blockage with a pin. If it is clogged with tape or the orange tab (that was in place during shipping), then remove the tape. Replace any that are damaged. Reinsert the cartridges and make sure that they are fully seated (clicked into place). Check if the error persists when you close the cartridge access door.
Try running the printhead cleaning utility from your computer. (HP Solutions Center under Setting, Print Settings, Printer Toolbox and follow the on-screen directions).
Remove the printhead and clean it. Then reinsert it and make sure it is fully seated. Remove the cartridges, lift the latch handle on the right and lift the print head straight up. This is done with cotton swabs or lint free clothes (coffee filters will work) and distilled or bottled water. During the cleaning do not touch the nozzles; also do not touch the contacts with your fingers. Wet the swab or cloth and wring out the excess water. Wipe the contacts on the printhead with the damp cloth first by wiping up towards the nozzles. Then with another damp cloth wipe the edge between the contacts and the nozzles (work in a right to left motion). Finally wipe down the ramps going away from the nozzles with another cloth. (Wipe each part until there is no ink left.) Dry each area with a fresh cloth.
Next take another damp cloth and wipe the contacts inside the printer. (work from top to bottom.) Dry the area.
Reinstall the printhead and lower the latch handle. Then reinsert the ink cartridges until they snap in. Close the cartridge access cover and check for the error message.
If the error persists, reset the printer. With the printer on, disconnect the power cord from the back of the printer. Disconnect the other end of the cord from the wall outlet. Wait at least 15 seconds and then plug in the cord (first to the wall outlet and then the printer). Turn on the unit.
If the error persists, then either the printhead needs to be replaced or the unit needs service. Unfortunately a new printhead is not returnable if you put it in and find the error persists.
For details and pictures: see http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01458034&tmp_task=solveCategory&lc=en&dlc=en&cc=us&product=3737195#N65 .
I hope this helps.
Posted on Dec 12, 2010
I have an HP and it says ink system failure Oxc19a0013 what does that mean.
remove the catridges and then unhook the print head. wipe with soft cloth. otherwise you need to replace print head
Aug 01, 2016 | HP PHOTOSMART PLUS B209A All-In-One...
Hp photsmart 8250 system failed error code Oxc19a0013
According to the HP website, this error code means the ink system has failed, and the unit will need to be serviced by an authorized HP repair technician - An Ink System Failure or 0x Error Message Displays on the HP Printer...
However, you can try resetting the printer first -
Reset the product
  1. Without turning off the printer, disconnect the USB cable from the rear of the product.
  2. Remove the cartridges from the product.
  3. Wait for the 'Insert Cartridges ' message to display on the control panel.
  4. Disconnect the power cord from the back of the product.
  5. Wait 60 seconds.
  6. Reconnect the power cord. If the product does not automatically turn on, press the Power button.
  7. Reinsert the cartridges, and then close any open doors on the product.
  8. If you receive a prompt to print a calibration page, do so.
  9. Reconnect the USB cable to the rear of the printer, and then try printing again
  10. If the reset fails it will require a service.
  11. NOTE: if you are using refilled or remanufactured cartridges try the reset with genuine hp cartridges as they will be recognized as original authentic HP cartridges by the printer
Apr 13, 2015 | HP Office Equipment & Supplies
Ink system failure Oxc19a0013 HP Photosmart B110
Check all of your cartridges to ensure that all of the protective tape has been removed. If you still receive the message after the check then power down your printer and remove the power cord from the back of the printer. Remove all of the ink cartridges from the printer. Wait 2 minutes, then plug the AC cord back into the printer. Turn the printer back on. Once the printer goes through it's power on self test it will ask you to insert the print cartridges. Go ahead and do so. If the error message does not display itself then you are okay to go ahead and use the printer. However, if you still receive the error display then you will have to have the printer serviced. Unless you have the tools, experience, and a copy of the service manual for your printer, it is best to have your local HP repair center take a look at the printer. The code signifies an ink system error, but there are a number of reason that can cause the error to display.
Mar 13, 2011 | Office Equipment & Supplies
Jul 10, 2010 | HP Photosmart 3310 Printer
Ink system has failed. Unable to print. Refer to printer documentation Error: 0xc18a0201
I have a HP photosmart C5180 all in one. It has an error message that says....Ink system failed unable to print refer to printer documentation error OXCa0501. By chance would you know what to do to fix it? Thanks
May 25, 2010 | HP Photosmart C5180 All-In-One InkJet...
HP Photosmart C6180 All-In-One InkJet Printer Logo
3,794 people viewed this question
Seeker5211
Seeker5211
