Question about JVC Audio Players & Recorders
Jvc xl-m505 6-cd player has been working fine, but now only buzzes when play is pushed; individual and six-cd trays will eject when button is pushed,but will not play or accept any other commands.
  • freydad Jan 27, 2009
    Ended up taking the player to a repair shop, and for $50 learned that it needed a new plastic collar on a spindle; cost of the replacement part: $2. Hopefully this 18-year-old system will last another 10 years....
MrLard
  • 94 Answers
SOURCE: cd will not play and keeps ejecting
source http://www.kenwood.nl/support/veelgestelde_vragen/ Changer Error Codes ? E-00: Poor Cable connection. ? E-01: Magazine not properly set in changer. ? E-02: No Disc in magazine. ? E-03: CD does not have selected track number. ? E-04: Disc is dirty, upside down or unreadable. ? E-10: No data is recorded on the MD. The player plays the next disc automatically. ? E-99: Changer malfunction, disc may be caught in machine or changer requires service. Sounds like the mech is gummed up, jammed, or a cd is stuck inside. Get a nerd to open it up and check it over. Luck
Posted on May 04, 2007
  • 4234 Answers
SOURCE: Sony CDP-397 Problems
The CD tray is driven by a belt below the tray or on the right hand side (I can't remember the exact model). The belt is probably slipping. Replace the belt and you should be fine. I think you should be able to replace the belt without removing the tray.
I'll look up the model tonight and update this if there are significant differences from what I already stated.
Dan
Posted on Mar 31, 2008
robotek
  • 1512 Answers
SOURCE: my cd player (model dx-1800)
Hi djhartness
It will have a faulty load belt to the tray assembly. Not hard to replace if this in an Onkyo DX1800. You need to use a belt the same cross section as the one that has failed. If you need any help sourcing the part, just let me know. cheers
regards
robotek
Posted on Jul 14, 2008
easyq
  • 144 Answers
SOURCE: My Tivoli CD player is
If it is under warranty simpyl return it to get it repaired.
It seems either there is something stuck inside what makes it think there is already a CD inside or your eject button is stuck internally. If not under warranty and you're a bit handy, try to open it and see if there is anything inside the CD area that makes it eject CD's or if one of the small wires connected to your eject button is loose or if there is a shortcut inside.
Posted on Aug 08, 2008
  • 60 Answers
SOURCE: CD Error on Stereo (Not a code issue)
I have seen this a bunch of times always with the same result, take it to a audio repair facility, the sterio has a bad internal circut. No external "quick fix" that i know of
Posted on Nov 22, 2008
Why does my eject button not work?
The drive belt is either slipping or broken, keeping the cd tray from coming out.
May 11, 2014 | JVC XL-V333 Personal CD Player
JVC xl-fz258 won't open to eject cd, won't play
The basic problem is that the drive mechanism has failed. The problem with CD ejection can be caused by binding in the tray or a weakened ejection motor
Dec 02, 2012 | JVC XL-FZ258
Attached cd player worked fine with cd then next time turned unit on it only shows symbols on the display n does not work no buttons work can't turn off and can't eject disc any ideas?
Most CD players will have a very small hole you can fit a paper clip into and push it
in which releases the CD drive mechansim and starts opening the tray.
You may want to press the RESET button behind the faceplate first and see if rebooting
it will make it cooperate. If you dont have the detachable faceplate completely on
some of the symptons you describe could happen.
Mar 26, 2011 | JVC KD-G421 CD Player
The stereo works fine but i cannot eject the cd's
I just had the same problem with the same model. Disc five was saying no disc and would not play any other discs. I opened the radio and found the the CD tray was missing a piece for disc five. You have to put the disc tray back into the holder to fix it. Make sure it locks in place and you should be able to get the rest to work.
Feb 11, 2010 | JVC HX-D77 Shelf System
Dvd will not eject from jvc hr xvc27u dvd player all it will do is display the word read on the screen
elsombro is right. There is a little whitish plastic square on the right side of the player, part of the DVD assembly (after you take off the cover). It's about 1/4 inch square. With the unit turned on, push that square with a pen about 3/4 of an inch in or as far as it will go. There will be a clunking sound but that is the sound of the DVD being released back onto the tray. Now gently push the back of the tray forward, ejecting the disk manually. Take the disk out and then press the close button. If the door doesn't close, it's out too far so manually push it in about an inch or so and then press the close button again. Should be fine after that. I think my problem was a DVD I recorded on my computer and it has the wrong format or something. After I got it out I put a regular DVD back in and everything was fine.
Dec 30, 2009 | JVC HR-XVC27U DVD Player/VCR
Dvd player will not open disc, display lock
Sound like it either has one or two problems, the door is stuck and or the door eject motor has failed. Look in the front to the player for a small paperclip like hole, and use a paper clip to manual eject the and engage the loading mechanism usually located under the door for most cases. Check you manuals troubleshooting section for manually ejecting a CD..
Please leave comment.
Oct 12, 2009 | JVC XV-N312S DVD Player
Cd tray won't open; won't play cd or turn off
No solution - plastic thread driving opening/closing had snapped after 16 years!
May 17, 2009 | JVC XL-M509TN 7-Disc CD Changer
Jvc xlmv33 three tray karaoke cdg player
TRY A LASER LENS CLEANER,,AND TAKE COVER OFF TRY BLOWING IT OUT ,,
May 12, 2009 | JVC KARAOKE, 3-CD CHANGER, 3 MIC INPUT,...
JVC KD-G340 Power Problem
Try rewiring it. Yellow to a full time hot 12v and red to an ignition switched 12v
Feb 18, 2009 | JVC AM FM CD DET FACE CAR STEREO
What buttons do i push for a music cd or anything to play?
I can send you a manual if needed. kb3xy@krbenson.com
Dec 12, 2008 | JVC XL-SV22 CD Player
204 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
