Question about Electronics - Others
Pc not finding it
Pc is enable to find it
  • marksbfg Aug 25, 2008
    When I put my sandisk 2GB microSD memory card into the disk adaptor then into my HP laptop the laptop doesn't show a disk in the system. It does work however in my other computer. How do I get my laptop to read the disk
  • 12,061 Answers
Not finding what? What is "it"??
Posted on Jul 29, 2008
I can't connect to WiFi. Any advice?
Is the wifi enabled, can you see any wifi networks? If not, make sure wifi is enabled, if there is button on laptop to disable/enable wifi connections, swich wifi on.
Check from control panel -> network (network and sharing center in Vista/Win7) -> change adapter settings. If wireless lan adapter disabled (grayed out).
Jun 04, 2014 | Computers & Internet
Need to re-enable wireless to AX1430
Control Panel
Device manager
Network Adapter ->right click ->enable
All depends on your OS!
Mar 09, 2013 | Acer Aspire X1 Ax-1430g-uw30p Slimline...
I just finished installing Win 8 on a Compaq evo ultra slim after restarting I get error code 0x0000005d what can I do , is my motherboard not compatible its a pentium 4
Go to BIOS, find option 'Data Execution Prevention', and enable it. Moreover, enable option called 'Virtualization Technology (VT)' feature, in a case; you are trying to install Windows 8 from virtualization software like oracle or VMWare.
How to enable above option
To enter in BIOS, restart computer and on very first screen find a message like this:
'DEL to enter setup'
'Press Esc to Enter Setup'
'BIOS Configuration: F2'
'F10 to Enter Setup'
Carefully find any message on your screen and press respective key to enter in BIOS.
Once you enter in BIOS setting, go to Advanced Options and select Processor then No Execute Memory Protection, if not, then Security > Options and Select Execute Disable. Change this to 'Enable' or 'On'.
Save changes and Exit Bios Setting if you perform Windows 8 installation in a new PC, otherwise move on to next step
Enable Virtualization Technology (VT) feature
Go to BIOS setting by following above-mentioned steps. Go to Performance options. Change the Virtualization feature to 'Enable' or 'On'. Save changes and Exit BIOS setup. Proceed to next step if your system supports the security feature. This is how you can solve the issue.
Nov 01, 2012 | Compaq Evo D510 Ultra-Slim (470043-542) PC...
How do I find out if my pc is wireless enabled? My desktop is E-Machines EL1200-07w
your desktop in not wireless enabled. to enable it, you need a wireless lan. you have to purchase a wireless lan card.
Apr 11, 2010 | eMachines EL1200 PC Desktop
Trying to download files from my laptopato my cell phone razor v3, but authentication asks me for a pairing number
hi friend follow the below steps
  1. enable Bluetooth on your PC. To enable Bluetooth on your PC visit your control panel. You should see an option for Bluetooth devices. Select this option and make sure the technology is enabled. If you are installing a USB module, you should be able to plug it in and use it right away. If not, it should come with drivers to install (insert the disc, and install the software).
  2. Step 2 Enable bluetooth on your cell phone. Each phone is different, but you should be able to go to a settings menu, and select bluetooth. There should be an option to enable bluetooth on your phone. Enable it, and make sure your phone is visible.
  3. Step 3 Allow the PC to search for devices. It should find your cell phone. If not, you can try searching for your computer with your cell phone. Many times, with the USB modules, they have trouble finding your cell, but your cell can find your computer. The important part is that the devices connect, regardless of which device finds which.
  4. Step 4 Approve the devices to connect. Sometimes, the devices will automatically connect, and you will be ready to go. However, if this is not the case, refer to step 5.
  5. Step 5 Enter any necessary security codes. If you do not know these codes, try the defaults, (1234,) use the same code for PC and for mobile
  6. Step 6 Select the files on your computer that you want, and you should be able to right click and select "send via bluetooth". Click this option, and let the files
please rate the sollution
Mar 31, 2010 | Motorola Mobility RAZR V3c Cellular Phone
IS MY PC WIRELESS ENABLED? I JUST BOUGHT A PACKARD BELL UTOW-SAN, HOW DO I FIND OUT IF ITS WIRELESS ENABLED AS MY ROUTER IS WIRELESS. IF NOT WHAT DO I NEED TO MAKE IT WIRELESS ENABLED?
You can check your pc if its wireless enabled if you have a wireless adapter installed on your system with the necessary drivers, if you dont have the device, then you have to purchase a wireless adapter from the computer shop and install its device driver in order for it to work. If you have a hardware and have the driver installed, you go to control panel and network connections if you have windows xp, you should configure it to get ip from your router in order for you to get connected to your wireless router, and also you make sure that wireless is enabled on your router when you configure it.
Jan 10, 2010 | Packard Bell iMedia SL 9553 (P660401806)...
Usb ports do not work
reboot the PC, and press F2 key during boot (might have to hold it during the boot process). Page or select the advance options/intergrate options. Then find USB ports make sure they are enabled, if not enable then enable them. Exit bios and reboot
Oct 13, 2009 | Dell OptiPlex GX520 PC Desktop
Computer is saying add-ons are disabled, but they are all enabled
In internet explorer click on Tools > Manage Add-ons > Enable or Disable Add-ons.
In the "Show" list, click "Add-ons that have been used by Internet Explorer"
It may take a second to populate.
Click the add-on you want to enable, and then click Enable > OK.
Jun 11, 2009 | ArcMedia JavaScript Source Code 3000 Pro...
How to enable the inbuilt web cam on my asus eee pc
webcam drivers are included by xp from defaulkt, you might have to re-enable it in the bios (f2 whilst starting up)
Apr 12, 2009 | ASUS Eee PC 1000H Laptop
Electronics - Others Logo
74 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
