Question about HP Pavilion dv6000z Notebook
Internet connection timed out
Trying to get on line using a verizon wireless card keep getting a connection timed out message
  • 31 Answers
Make sure your wireless router is connected correct
go into windows device manager and see if your device is working right
if not give your computer maker a call
hope that helps
cheers
Posted on Jul 19, 2008
I have had my Veralink router Westell (Model 327W) sice I hooked up with Verizon DSL in 2005. In the past several weeks it keeps dropping my signal to my other computers that i use a wireless adapter to...
hi, try to connect that particular computers directly to the router using the ethernet cable,monior the internet connection,if l the internet connection is consistent, theres a possiblity that you need to update the driver for your wireless adapter,try to uninstall and reinstall it,but if the internet connection is still dropping off,contact verizon and tel them that you are having an intermittent connection to the internet,have them check the dsl line and if possible,ask for a higher tech support to do a test assist for the connection...
thanks and God Bless
Jun 03, 2010 | Westell Wirespeed VersaLink...
Having trouble faxing on my lexmark 4650 wireless printer. i keep getting connection failed status. i use a verizon mifi220 for my internet connection... can anyone help?
If I'm not mistaken, the fax on your unit still uses the phone line to fax, not the internet, so you'll need to connect an RJ-11 phone cord from the unit to a phone jack in order to send faxes from it.
Feb 03, 2010 | Lexmark X4690 Wireless InkJet Printer
How do u hook up ps3 online usin broadband card and laptop
Hi, The PS3 has a built in wireless card. You need a broadband internet connection& a wireless router for it to work this way.
What hardware do you have? You wont be able to connect the PS3 to the internet if you only have a laptop with a wireless broadband card. this is to be used for one PC/laptop at a time. Sorry
you could query this with Verizon though i am sure they would agree, that it is to be used for one PC/laptop to access the internet.
Thanks
Dec 21, 2009 | Sony Playstation 3 (PS3) Console
I am writinmg from my desk top computer because I'm having trouble contacting you through my laptop computer. I cannot send messages out from my email in outlook - which verizon techs just fixed last week,...
try this, goto control panel and network conections.
on the wireless card conection double click it, then click on properties , is the list you should see one some thing like internet protocol {tcp/ip} click on this one then click properties, make sure automatic is selected in both options, obtain an ip address automaticallly.if so press ok and exit out of all that.
hope this helps
Nov 28, 2009 | Dell Inspiron 1501 Notebook
Lost internet connection,verizon guess was the card was bad
First thing are all the micro-filters installed and in the correct direction? If they are then it sounds like your DSL signal is borderline and when the phone rings it is getting knocked out. If that is the case you will need a tech to come out and test the line.
Sep 10, 2009 | D-Link DFE-530TX+ Fast Ethernet PCI...
I have an older computer that does not have a wireless card, but my internet is through a verizon um175 air card. i have gotten 10 different answers, and none work. 3 different answers from verizon alone...
Yes you can. Make sure that you disable DHCP in the lan settings section in the router. Use the computer without wireless card as the server, the router will be install in this computer. i have an air card with Sprint and I'm using Encore router and my Wii, and 3 more computer can connect without any problem.
Aug 31, 2009 | Toshiba Satellite A135-S2276 Notebook
Can I use AT&T 2WIRE 2701HG-B DSL to ant ISP?
look if u wish to go for verizon service,,they will provide u with a wireless modem as well,,but if u tell them that u hav a modem then they might configure this modem only,,both ATT and verizon are DSL service providers with PPPoE connections.the only thing u need is the username and passwrd from verizon which u have to setup on the first page of the 2wire setup page,,both the connections are dhcp based.so no other connection settings change required.But when u talk with verizon make sure u tell them of the 2wire modem
Moreover verizon has wireless broadband service which is actually a express card tat u have to put into your computer and u can go online anywhere u go within ur country{it works like a mobile phone}
best of luck,,keep me posted
May 14, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
PCMCIA Verizon BroadBand Internet PC Card
You COULD do it, but man.
you are gonna be charged for each MB used, and honestly, it would be a terribly impractical approach.
Just to humor you, you'd do it as such.
Set up your laptop to run all the time. Have the Verizon card plugged in, and always active, and set to never drop connection. You'll now need a crossover cable, and you'll run the rj45 crossover from the ethernet on your laptop to the WAN port on your router. You'll then need to bridge the connections. Some versions of Windows support internet connection sharing; effectively doing the same thing. Now, you should have active internet.
Now, you're going to be charged per MB, you're gonna have a SLOW SLOW SLOW SLOW connection, and you should expect $1000 phone bills monthly.
Mar 31, 2009 | Lenovo Verizon Wireless EV-DO Embedded...
Card is green, wireless router is green , but no internet
r u c'in any message as limited r no connectivity in wireless connection,did u chk if u r able to go online wth the cable connection in ur laptop
Nov 05, 2008 | Dynex 802.11g Wireless-G Laptop Card
HP Pavilion dv6000z Notebook Logo
50 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
