Question about Epson Stylus C66 Photo InkJet Printer
Ink Pad Replacement Warning
I've had this printer for two years -- bought it refurbished, which I assume means that the pads were replaced. The replacement warning has begun to appear, so (thanks to the great directions posted here) I took the unit apart (not easy) and accessed the pads. To my amazement, both pads are as white as snow, with only a few small ink stains on them. When I fished out the drain tube, I found it clogged with dried ink, so I cleaned it out with a coat hanger, pipe cleaners and solvent. I already have the SCC Service Utility, so before I put the unit back together and reset the protection counter, I'd like some feedback on the following:
1. Assuming that the clogged tube caused ink backup resulting in the machine assuming that the pads are full, should I just replace the now-free-running tube and, if so, does it go under the pads? When I first removed the tube end I couldn't tell if had been properly placed or had become dislodged. There is no sign of ink collection on the printer bottom.
2. Or, should I drill a hole in the back and run the tube to an outside ink reservoir so I won't ever have to disassemble the dang thing again? Can I assume that the main precaution with this alternative is that the drain end of the tube should be lower than the other end?
3. How long does it usually take for the pads to become saturated? I use the printer infrequently but run test ink swatches every week to keep the printhead from clogging. Still, it seems strange that there is practically no ink in the pads after two years of usage.
Thanks for any feedback any of you can offer.
    Genius:
  • 2,785 Answers
You can try both the options if it works then well and good.
Posted on Jul 19, 2008
A printer's ink pad is at the end of its service.
The waste ink absorber pad under the ink head parking station is full of ink, or the printer assumes it is. Usually you have to disassemble a substantial portion of the printer to get it out. Often, you can wash out the pad with soap and water, rinse well, let it dry and put it back in. Most printers have some sort of reset procedure you need to follow to cancel the ink pad warning and get back to normal operation.
Nov 30, 2014 | Epson Artisan 837 All-in-one Wifi Inkjet...
Tip
Cleaning the waste ink pad on most printers.
Assuming that you have already removed the Waste ink pad from your printer. Place it in hot running water and i mean lots of water. when you think enough of the ink has been cleaned, start squeezing the waste ink pad in the running water do this until no more ink comes out and the pad is White in color. Replace it your printer and you are good to go.
on Feb 12, 2010 | Office Equipment & Supplies
My printer is epson tx650.the problomis that it say 'the printer's ink pad is at the end of their service life'. please assist me with the solution.says RAKITA
Sadly the other solution is the usual corporate party line regarding "Parts at the end of their service life" and is intended to encourage printer owners to purchase new printers.
The reality is quite different.. Epson printer are generally capable of upwards of 3 to 10 years or service with minimal care unless the printer is being hammered 24/7 with almost constant printing, which is very unlikely.
Waste pads however are an achilles heel that do need some form of action to either replace or work-around to resolve.
The options available are either:
1. Go to a service centre where it is indeed prohibitively expensive to have the printer disassembled to replace the pads and have the waste counter reset.
OR..
2. Get an external waste ink kit to redirect any waste ink to an external tank (it doesn't remove the current pad contents) and obtain the relevant tool (either a compatible AdjProg service program) or WICReset tool with a key (one needed per reset) so you can reset the printers internal waste ink counter.
The cost of the latter option is around 20-25(GPB) total (including shipping) so compared to the tooth sucking Epson Customer "Care" option it's not exactly rocket science as to which is more cost effective.
Please ignore the rubbish about other parts being near the end of their service life... About the only other thing to note is that the printer gears might need a little grease but beyond that and flimsy plastic paper guides the printer can easily last 5 years with a little care.
Mar 05, 2011 | Epson Stylus Photo RX700 All-In-One InkJet...
I switch my CX6600 on but all I get is the exclamation mark light up. |The displau says that par6ts are at the end of their service life. No warning! Anyone help please
That message indicates that the porous waste ink pads inside your product are near the end of their service life. Epson recommends replacing the printer, but if you want to continue using it, I'd suggest having the printer serviced at an Epson Customer Care Center. You may also be able to have the ink pads replaced by an independent service provider and use the Ink Pad Reset Utility to reset the Ink Pad Counter to continue using the printer. However, replacement of ink pads is relatively expensive and may not be a good investment for lower cost printers because the printers' other components also may be near the end of usable life. Hope that helps!
Mar 03, 2011 | Epson Stylus CX6600 All-In-One InkJet...
Locate waste ink absorber pad
canon pixma ip1000 printer, how do you access and clean waste ink absorber pad
Apr 13, 2010 | Office Equipment & Supplies
Error CX6400 Parts inside your printer are at the end of their service life. See your printer documentation. What does this mean and how do I fix it? If I have to buy another printer because of this you...
EPSON rulez, don't make any judgements before you read this :)
SOME THEORY
The printer has a waste ink pad, which basically isaplastic container with felt in it. When the printer cleans theheads,either as commanded by you, or initially before printing, itspits outsome ink into this pad. The printer remembers an approximatecount ofink that has gone into the pad in a "protection counter", andsignalswhen the counter reaches a predefined limit.
Of course,this padhas a limited capacity. Theoretically, you should take yourprinter toa service workshop for waste pad replacement and resetting ofthecounter - the printer is designed not to let the waste ink overflowandleak under the printer.
Of course the limit is set with asafetymargin, for a worst-case scenario, when you "pour" ink constantlyandit has no time to dry.
SOLUTION
If you want tobecompletely inline with manufacturer's specifications, and especiallyifthe printer is still under warranty, you should contact EPSONserviceto do the right thing.
If however you want to live on theedge,you can download a special utility to reset the protectioncounter,replacing the felt or cleaning it yourself, or - if you areeven moreadventurous - without replacing the pad altogether, countingon thefact, that the waste ink dries out all the time and in practicethe padshould accept twice as much as the producer assumed - but don'tplaceyour printer on that antique table or sofa afterwards...
If you want to give it a try, go to this webpage to download the software (TIP: DON'T be tempted to change any other settings, as you may render your printer useless):
http://www.ssclg.com/epsone.shtml
Nov 17, 2009 | Epson Stylus CX6400 All-In-One InkJet...
Its been giving warning messages that internal parts are nearing the end of their useful life. Now it won't print. Is there anything I can do?
SOME THEORY
The printer has a waste ink pad, which basically is a plastic container with felt in it. When the printer cleans the heads, either as commanded by you, or initially before printing, it spits out some ink into this pad. The printer remembers an approximate count of ink that has gone into the pad in a "protection counter", and signals when the counter reaches a predefined limit.
Of course, this pad has a limited capacity. Theoretically, you should take your printer to a service workshop for waste pad replacement and resetting of the counter - the printer is designed not to let the waste ink overflow and leak under the printer.
Of course the limit is set with a safety margin, for a worst-case scenario, when you "pour" ink constantly and it has no time to dry.
SOLUTION
If you want to be completely inline with manufacturer's specifications, and especially if the printer is still under warranty, you should contact EPSON service to do the right thing.
If however you want to live on the edge, you can download a special utility to reset the protection counter, replacing the felt or cleaning it yourself, or - if you are even more adventurous - without replacing the pad altogether, counting on the fact, that the waste ink dries out all the time and in practice the pad should accept twice as much as the producer assumed - but don't place your printer on that antique table or sofa afterwards...
http://inkjetprinterhelp.us/epsonSSC.html
Nov 12, 2009 | Epson Stylus Photo R300 InkJet Printer
Error message saying parts have come to the end of their life. Does this mean the whole printer needs replacing
It mean waste ink pad full. Epson stop to prin to prevent waste ink flow from pad to other (power supply is nearest part). Replace pad, or wash pad. Or just extend outlet pipe to outside of printer. You must reset waste ink counter to make printer work again. Use SSC utility to rset it. Find at indoreset.blogspot.com.
Jun 30, 2009 | Epson Stylus C46 InkJet Printer
I have a warning that my ink pad is saturated and needs replacing contack dealer for assistance (help)
Ink means pad for waste ink nearly full. Epson program read and count all waste ink from head cleaning and ink charge. Next, you need reset waste ink counter, and replace or washing pad. You can extend outlet pipe to outside of printer, so next time you don't need replace pad again.
Jun 27, 2009 | Epson Printer
Canon IP500 printe displaying following error message, 'waste ik absorber almost full'. What does this mean? and how do I fix it?
hello
there is an absorbent pad in the bottom of the printer starting under where the print head rests, this is to absorb the ink that the printer sprays out during a cleaning cycle or a startup cycle.
the manufacturer knows the capacity of the pad and how much ink they spray out during the cycling, they keep track of this because when the pad becomes over full the ink will start to puddle under the printer making a very nasty mess.
sometimes one can order a replacement pad from the manufacturer and replace it yourself, sometimes they wont sell it to an individual because the printer needs to be disisembled to change it.
if they send you the pad it usually comes with directions on replacement and re-setting of message.
norm
Nov 06, 2008 | Office Equipment & Supplies
Epson Stylus C66 Photo InkJet Printer Logo
76 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
