Triton opal 10.5kw shower runs ok apart from leaking cold water from casing not the little overflow pipe
Probably needs a replacement stabiliser valve assembly- about £29 each. look in your user guide
Posted on Jul 17, 2009
Triton jade 3 running cold
Sounds like you have an instant hot water system... (no hot water tank) if true, check that fuse.
Jan 12, 2014 | Home
No water, hot or cold from Triton T90si. Any ideas please?
The Triton t90si is fed from the tank in your attic.This also feeds the cold water in your bathroom.If you still have cold water in the bathroom tap,it means that there is water in the attic tank so the problem is somewhere else.I believe there is a bleed valve on these showers so maybe that is the problem. It may also be that the pipes are clogged up with dirt or limescale.The water filter may need cleaning. Hope this will help with your thinking on the problem.
Dec 19, 2010 | Home
Leaking form shower facet also leaking from
id say your tub spout or shower pipe is leaking and running down behind remove both and replace teflon tape see if it stops
Mar 14, 2010 | Home
Turned on a triton trance electric shower it was working ok then it stopped coming out of the shower head and coming out of the overflow pipe at the bottom of the shower unit
The overflow pipe is a pressure relief device which is a small rubber ball that get's ejected when the water pressure inside the shower is too high. You will need to get a spare part to replace this. These generally operate because the showerhose is in poor condition and has collapsed internally, or the showerhead has become clogged up so check these things first.
Good luck.
Sep 21, 2009 | Kitchen Appliances - Others
No hot water when heating tempreture reached.flow switch is operating, power at flow switch terminals on pcb (three wires),? but when working hot water runns for ever and heating runs ok too untill the...
I have a triton opal shower.
I turn shower on low pressure and cold water. then no low pressure and piping hot water for a very short time then low pressure and cold water.
I've changed the solenoid and the little black plastic ball.
Help !
Aug 21, 2009 | Water Heaters
My shower works. water also poors out of a tube beneath the unit
Are you talking about water still coming through the spout at the same time? What overflow pipe are you talking about? If you are talking about the spout, there is a device in the spout that when you pull up on it, the water is diverted to the shower. They have washers in them and it sounds as though the washer is worn out and not making a good seal anymore. You can buy a new generic spout to stop the water or you can take the old one apart and try to find replacement pieces. I have taken one apart and bought a new one to rob the parts off of it before. I hope this is the answer you were looking for. If not, reply to this for clarification and I will try and answer your question more clearly.
Apr 02, 2009 | Home
Triton opal electric shower overflow pipe
hi rob the problem is due to an activated thermal overheat switch, you cannot reset this unit as once it is activated it will require a new unit, its a nuisance i agree as i come across this regularly, however its condusive of a scaled up unit so you eventually turn up the shower setting higher to get the water hotter, & inturn activates the thermal switch.
According to which model it is the part is not that overly expensive, you can phone triton direct 7 they will post a new spare to you
Kindly
Richie
Nov 19, 2008 | Home
Heating & Cooling Logo
580 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
