Question about Linksys Wireless-G Broadband Router
Linksys Wireless-G BroadBand Router
I am not able to configure the broadband connection of BSNL to two sub networks.
Eg of Problem . I have inserted the Broadband connection into the WLAN port of Linksys Router. after that I dragged out to different cables fromn router's LAN Port. From which one LAN port is connected to athe another switch and another LAN port is connected directly to a seperate Desktop Computer. Now The problem is arising that the internet connection has stopped working in the prevailing scenario..
    Genius:
  • 1,269 Answers
Who is your ISP (Internet Service Provider)?
If you're using a Cable provider, do the ff. steps. (For Linksys router)
1. Launch Internet Explorer and type http://192.168.1.1
2. It will prompt you for username and password. Leave it blank on username and type admin for the password.
3. Under SETUP tab, click the sub-tab MAC Address Clone. The click the button Clone My PC's MAC. Then click on Save Settings.
4. Unplug the power to the modem and the router for 30 secs. After that, power on the modem first, wait for all lights to go solid then power on the router. Check if the internet works.
Hope this helps.
Posted on Jul 24, 2008
Bsnl adsl modem configure with TL-MR3420 router!
make bsnl adsl router as abridge router , then connect tp link router from wan port with any one of lan port of adsl router , then configure tplink router connection depending how you get internet from your ISP
Jan 30, 2014 | TP-LINK TL-MR3420 Wireless Router
How can I get the router IP of my Linksys 2.4GHz broadband router?
The Linksys G router gives you both wired and wireless connections over a broadband Internet connect to create a local area network. The Linksys router is compatible with wireless G and B devices, through the 2.4-GHz wireless band. The wireless speed is at 54 megabytes per second and you can get 100 megabytes per second with a wired connection. You have to set up the wireless configuration on the Linksys before using it on your network.
Plug the router's power cable into an electrical outlet. Attach an Ethernet cable into the Internet port on the back of the router. Connect the other end into your broadband modem. Connect your computer to the Linksys G using another Ethernet cable. This Ethernet cable can go into any of the wired router ports. Open your Internet browser. Type "192.168.1.1" in the address bar and hit "Enter." This is your router's IP address and the home of its Web configuration page. Click "Wireless." Click "Manual." Alter your SSID, also known as your network name. You can change this name to any value that you want. You can also change the wireless channel if you are in an area with many wireless connections that may interfere. Click "Save Changes." Click "Wireless Security." Choose an encryption method to encrypt your wireless transmissions. WPA or WPA2 are common security protocols you can use in wireless networks. Input a network key, also known as the network password. Click "Save Changes."
Setting Up WPA Wireless Security on a Linksys Wireless Router http://www6.nohold.net/Cisco2/ukp.aspx?pid=80&vw=1&articleid=3696 Wireless G-Broadband Router support http://homesupport.cisco.com/en-us/wireless/lbc/WRT54G b> b> Changing the Wireless Network's Name (SSID) on a Linksys Router http://www6.nohold.net/Cisco2/ukp.aspx?pid=80&vw=1&articleid=4037
Mar 27, 2013 | Linksys Wireless-G Broadband Router
WIFI not working with Linksys wireless-g broadband router/Comcast
Unplugging the wireless router and connecting it again should not have altered the wireless connection/configuration. You have connected the cables correctly because the Internet works when you connect a LAN cable to the router.
The Linksys wireless configuration or the wireless card configuration in the computer was changed it to lose the wireless connection. The wireless card configuration needs to be changed to match the wireless router's settings or change the Linksys with new configuration settings and configure the wireless card accordingly.
To secure your router with a login password and wireless security, please follow my instructions - click on this link :-
http://www.fixya.com/support/r3559128-wireless_router_security
Should you need further assistance, please leave me a comment.
Dec 25, 2009 | Linksys Wireless-G Broadband Router
How can i get Linksys Wireless-G Broadband Router go wireless?
The Linksys Wireless-G is ALREADY wireless. Do you have any computers with 802.11g network cards? Laptops usually have these. Make sure you have properly configured the router, because if it is NOT correctly done then things may not work too well.
Nov 02, 2009 | Linksys Wireless-G Broadband Router
Router and pc configuration to connect broadband via dsl modem
Sorry i tried to open 192.168.0.50 and it could not display. what is the new IP
Aug 06, 2009 | D-Link AirPlus DI-524 Wireless Router
We have 16 Computers 1 broadband connection of bsnl and one
There is a pretty good writeup here:
http://www.team-bhp.com/forum/gadgets-computers-software/36499-bsnl-broadband-wireless-configuration-2.html
But if you have already configured the modem and it does work.
All you need to do is plug an ether net cable from that to the 'Uplink' port on the back of the WRT router.
After that it should serve that conection out to the machines that are cabled to it. The other machines that you will connect wirelessly can be done through the web interface to the WRT. Which will appear at 192.168.1.1
Apr 18, 2009 | Linksys Wireless-G WRT54G Router
Connection
Hi Susie
With related to your particular issue it seems like that your broadband modem is not configured for the router. There are basically 2 types of connection. DSL and Cable modem. Verizon, ATT are DSL and comcast other providers give you a normal cable broadband connection. If its comcast make sure the cable from the comcast modem is going to the internet port in the linksys router and also make sure that there is a system connection the linksys router and the cable from the system goes to any of LAN 1, 2, 3 and 4 ports. Then reset your cable modem by using a pin and inserting to the reset hole in the modem. You could use the same step to reset your linksys router as well .If its a verizon or dsl connection you need to put normally your username and password in the router page. here is the link to how to configure linksys for your internet modem.
Here is a video as well on it?
http://in.youtube.com/watch?v=vSAXMO7aNzg
http://tinyurl.com/5tqqhl
Also post the linksys router model. your ISP modem model number and also information on how many systems are wired to the router and wireless and let me know if you need more help.
Thank you
Rakesh
Dell Laptop Expert
Jan 09, 2009 | Linksys Wireless-G Broadband Router
Network
  • BSNL walo ne username and password diya hoga ...
  • Router ko modem ke saath connect karo...router ko computer ke saath connect karo ...
  • Go for PPPoE and enter ur username and password ...keep alive should be checked in ...
  • Uske baad switch off kar dena sab kuch ((modem and router )) 10 sec ke liye...
  • uske baad it will run like a horse...
Oct 24, 2008 | Linksys Wireless-G Broadband Router
Laptop setup
just connect the linksys router to wireless router and just install the setup cd given with wireless router ..after configuring your laptop just insert the cd in another laptop and copy WEP key in it and get connected through wireless network
Jun 19, 2008 | Linksys Wireless-G Broadband Router
WRT54GX4 Wireless Router Setup Problems
Hi Randy
Reset the router
Use regular way to configure the Router.
In computer side
Go to Start>Connect To>Show all connections
a new window (Network Connections) will open,
Right click on the "Wireless Network Connection"
Click on "View Available Wireless Networks" You will see "linksys" with the highest signal level. Connect it
after connection go to web browser; type 192.168.1.1 and hit enter. It will take you to Linksys setup page which is integrated in the router. after that you can do any settings you want.
Please post here if you need further assistance
Good Luck
Jan 12, 2008 | Linksys WRT54GX4 WIRELESS 802.11G...
Linksys Wireless-G Broadband Router Logo
149 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
