Question about Logitech Webcam
Microphone wont work
I plugged in my Microphone and installed the driver successfully.
I have a Windows Vista, if I go to: Control Panel > Sound > Recording
Here is what it looks like:
I am thinking my microphone is the top (first one). Here is what it looks like if I click on it:
Now if I talk in my mic it doesnt record any sound. The bars stay the same in the second picture. They don't go up, just stay the same. What is the problem?
I go on AIM and can see/hear the person I am talking to but they can't hear me. They can see me but not hear me. What am I doing wrong?
Posted on Jan 22, 2009
ConnectLand cl-me 606 goose neckdesktop microphone to desktop
Look for a 3.5 mm microphone port on the computer. Usually the port on the back of the desktop will have a pink surround. (There will be other ports there; the usual minimum are the green port for speakers and blue one for line-in.) Put the 3.5 mm jack on the end of the cord on the microphone into the port. If you have an add-in sound card, use the microphone port on the sound card.
Some machines will also have a front panel microphone port. This will have a small mike icon next to the port.
Next you need to ensure that the audio device is set to Microphone. For Windows systems (Vista/7/8), enter the Control Panel and go to the Hardware and Sound panel. Click on Manage Audio Devices under Sound. Then click on the Recording tab. Check if the microphone listed as plugged in. Make this the default recording device. (XP has a slightly different name for the panel.) For XP through Windows 7, click on the start button and then find the Control Panel listed on the right. For Windows 8, from the desktop, press the Ctrl and X keys at the same time. Then find the Control Panel in the list. (Alternatively, activate the Charms menu, Ctrl+C or hover on the upper right of the screen. Move down and click on the gear (Settings). Then select the Control Panel.)
If the computer doesn't indicate that the microphone is plugged in, make sure that the 3.5 mm plug is in the correct port. Next try the microphone on another computer. The audio card port could be damaged or the microphone cable could be faulty. If the microphone works on another computer, you can try a USB audio adapter (StarTech ICUSBAUDIO or similar) or a new sound card. (Note: some older sound cards do not work properly on newer versions of Windows. If you have a sound card installed and the motherboard has an on-board audio device, remove the sound card. Enable the on-board audio in the computer's BIOS. Install the appropriate audio drivers. Try that audio device. Accessing the BIOS will depend on computer. Often you can press Esc, F1, F2, F10 or Delete repeatedly after you turn on the computer. If Windows starts to boot, turn off the system and try again.) If another computer doesn't recognize the microphone, I'd recommend a new microphone. Fixing the cable isn't worth the effort.
I hope this helps.
Sep 20, 2013 | Computers & Internet
I am unablem to use the mic for the internet chat!!!!
First of all find the latest version of the audio driver which is compatible to vista, as most of the drivers that are shipped with sound-card or motherboard cd contain drivers which have support for only until windows Xp.
So it is strongly recommended to download the latest audio driver from the internet for your sound-card or on board audio chipset. Install the vista compatible audio driver (sound driver) for your sound-card or motherboard audio. After this re-start your computer. Half of the work is done.
Now plug in the microphone in your sound-card / motherboard audio pin (generally pink in color for microphone).
After this go to control panel > sound and audio device settings. Check whether the microphone is detected by Vista or not. If not, check whether you have selected the frontal microphone or rear, as vista recognizes them separately unlike windows Xp. Correct the configuration of front/rear mic if needed.
Nov 16, 2010 | Computers & Internet
Mic wont work of course
which operating system do you use? and check the sound driver from { if windows,right click my computer then click manage then device manager, see there is sound driver is installed or not.} if not then install sound driver.
Apr 29, 2010 | Cyber Acoustics CVL-1064 Consumer...
HP pavilion dv9005us. When using built in mic receivers say volume is very low. When I move the lid I get a crackling sound in the speakers like the mic wires a lose ..
To fix the low volume problem in mic receiver follow the steps below:
  1. Click Start , Control Panel .
  2. In the left panel, select Classic View .
  3. Select Sound , and then select the Recording tab.
  4. Right-click on Microphone and select Properties .
  5. On the Custom tab, select Microphone Boost .
  6. On the Levels tab, increase the microphone recording volume to the maximum level.
Then please check if it works fine otherwise you need to install the latest sound driver.
Windows VISTA 64bit and 32 bitsound driver:
Windows XP sound driver:
Install the sound driver as per your operating system.
Apr 04, 2010 | HP Computers & Internet
HELP! My new compaq presario cq60 built in microphone wont work. I need help fast, major school project due in two days. My mic worked before, I disabled it because i was trying to so some streaming...
Do you have two mics or not,well if you have one you may have to delete one of them or both.Reboot the computer windows will install the drivers and this should fix this If not un-install the sound card drivers.Windows should reinstall once you reboot.However before you do make sure you have a copy of the sound drivers to reinstall.
Good luck
Sep 12, 2009 | Compaq Computers & Internet
I brought a microphone thats vista compatable and it wont work
Perhaps you need new drivers on either your mic, Or sound card. Is this mic your using USB or have a normal 3.5mm plug?
Try updating some drivers. Hope this helps!
Jan 03, 2009 | Microsoft Windows Vista Ultimate Edition
Vista Ultimate -Microphone on Cyber Acoustics Headset not working
Here you go go
their its the dell drivers page for Vista, download the drivers their for the microphone and you can
also download things you might need for the computer
Hoped this really Helped,
Dec 24, 2008 | Microsoft Windows Vista Ultimate Edition
Dell Inspirion 1521 Laptop Microphone Wont Work
1. sound driver 2. microphone settings in volume control applet 3. tap test (tap the area around the microphone and see if eg Sound Recorder picks it up) 4. external microphone
If you get to step 4 before you get anything then your problem is one of missing or damaged microphone.
Dec 15, 2008 | Dell Inspiron 1521 Notebook
Microphone not working Need help please
Make sure it's plugged into the Pink Jack on the computer. You probably already know that, but if not hope this helps. Bud
Jul 19, 2008 | Computers & Internet
Microphone is not working windows vista
My microphone has always worked on vista for, I use it everyday on skype, but today it will not work, I can hear the caller but they cannot hear me. I thought my headset was broken and i bought a new one. but its still doing the same thing with the new headset. It says the microphone settings are enabled and working, but when i do the mic test, it says that it cannot hear me.
what can i do?? help!
Dec 27, 2007 | ASUS M2N-E SLi Motherboard
Logitech Webcam Logo
51 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
