Question about E-Machines Computers & Internet
My internet connection Internet Protocol(TCP/IP) only shows (Unavailable) and I can't get on the internet through my modem. I entered my IP address, etc. but it wouldn't take it.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 95 Answers
Hi
There is no need to assign ip address for you computer to enter into internet you system will be getting the ip through DHCP.so remove the ip address and check the internet connection.Check wether the telephone line is ok .check wether there is dailtone in your telephone line and check the username and password is correct.
Jyothish
Posted on Jul 19, 2008
No network coverage
Set IP Address Configuration
Click the "Start" button and select the "Control Panel" from the right column to open it.
Select the "Network and Internet" section of the Control Panel.
Click "Network Connections" if using Windows XP to view the available network icons.
Or, click "Network and Sharing Center" if using Windows 7 or Vista and select "Change adapter settings."
Right-click your network connection icon which displays either the yellow triangle or red "x" indicating limited or no connectivity.
Select "Properties."
Click on "TCP/IP" to select and highlight it. Click "Properties."
Select both the "Obtain IP address automatically" and "Obtain DNS server address automatically" radio buttons.
Click "OK" and then "Close" in the Network Connection Properties box. Close the Control Panel.
Manually Renew IP Address
Click the "Start" button and choose "Run" from the list.
Type "cmd" in the "Run" box and press "Enter" to open the Windows Command Prompt.
Type "ipconfig /release" in the Windows Command Prompt and press "Enter."
This releases the current IP address of your computer.
Type "ipconfig /renew" and press "Enter" to obtain a fresh IP address.
When renewing your IP address, Windows automatically attempts to connect to the network.
Powercycle Router and Modem
Turn off your computer.
Unplug both the Internet modem and wireless router's power adapter from the electrical outlet. Wait for two minutes.
Plug the Internet modem into the electrical outlet first. Wait for connectivity lights to appear.
Plug the wireless router's power adapter back into the electrical outlet.
Confirm that lights appear on the router indicating that it has established a connection to the modem.
Turn on your computer.
Open "Network Connections" if your computer does not connect automatically to the network.
Select a network from the list, input the network password if one exists and click "Connect."
Open your Internet browser to test the connection.
Update Network Interface Card (NIC) Drivers
Click the "Start" button. Right-click "My Computer" or "Computer" from the Start Menu. Select "Manage." Click "Yes" if a user account control message appears.
Click on "Device Manager" from the list of System Tools.
Find the "Network adapters" listing and click the "arrow" or "plus" symbol to expand it.
Right-click your computer's network adapter from the list and select "Properties."
Click the "Driver" tab and select "Update Driver."
Follow the on-screen prompts to allow Windows to find and install the drivers automatically. Restart the computer when the process is finished and attempt to re-connect to the network.
Reset Internet Protocol (TCP/IP)
Click the "Start" button and select "Run."
Type "cmd" and press "Enter" to open the Command Prompt.
Type the following line into the Command Prompt and press "Enter":
netsh int ip reset resetlog.txt
Close the Command Prompt. Issuing this command tells Windows to remove and then re-install the two registry keys used by the Internet Protocol (TCP/IP) component of Windows.
Restart the computer.
Attempt to connect to the network if a connection is not established automatically.
Sep 06, 2013 | Computers & Internet
There is an error in connect...........
If the error in connecting to the internet or to a LAN is prevalent with all network adapters, reset the TCP/IP Protocol stack byrunning the following command from the command prompt window:
1. Go to start menu and click on run.
2.Type in cmd.exe and press enter.
3.In the command prompt window,type in the command:
netsh int ip reset C:\connlogreset.log
The command will reset the TCP/IP protocol stack to it's defaults, and the reset data will be logged in the text document connlogreset.log.
If the above fails, disable any protocols that are not needed in the connection, e.g. SLIP(Serial Line Internet Protocol for Linux) as it's only used to connect to Linux servers in a LAN.
If using a broadband modem, disable NDIS driver wrapper from the GSM broadband client software provided with the modem, and update the software if possible.
Jan 01, 2011 | Computers & Internet
Network key for ot 800
How do I configure my NIC with a static IP for use with a SpeedTouch Home?If you are using an Alcatel SpeedTouch Home (without a router), a PPPoE client such as NTS, WinPoet, or RASPPPoE, and are experiencing stalls and freezes while surfing or connected, it may be that your NIC is not configured correctly. You must set a Static IP on your NIC. If you have it incorrectly set for "Obtain IP automatically" it will be looking for a DHCP server that does not exist. During the time the NIC is searching for the DHCP server you will experience stalls and freezes. An incorrect NIC settings will also cause the PC to take a longer time to boot up.
This FAQ has two sections:
Section 1 - NIC Properties for Windows95/98/ME
Section 2 - NIC Properties for Windows2000/XP
bred.gifStep 1
Click on Start ->Settings ->Control Panel ->Network
bred.gifStep 2
Once at the Network Window scroll down and look for the first entry in the box marked Internet Protocol (TCP/IP) that is associated with your hardware ethernet card (ignore dialup, AOL, and VPN type bindings). Select the correct Internet Protocol (TCP/IP) entry and click PROPERTIES.
Actual screen shots may vary
bred.gifStep 3
Select the IP ADDRESS tab. Select Use the following IP address and enter 10.0.0.1 and 255.255.255.0 into IP address and subnet mask fields respectively. Do not click on OK yet.
bred.gifStep 4
Select the GATEWAY tab. Enter 10.0.0.138 into New Gateway field and click on Add. Click OK.
bred.gifStep 5
Close all windows and restart the PC.
Section 2 - NIC Properties for Winows2000/XP
bred.gifStep 1
Click on START -> SETTINGS -> CONTROL PANEL -> NETWORK CONNECTIONS. Right click on Local Area Connection and select Properties
bred.gifStep 2
On the General tab highlight Internet Protocol (TCP/IP) and click PROPERTIES.
bred.gifStep 3
Select the GENERAL tab. Select Use the following IP address and enter 10.0.0.1, 255.255.255.0, and 10.0.0.138 into IP address, Subnet mask, and Default gateway fields respectively. Click OK.
bred.gifStep 4
Nov 11, 2010 | Alcatel Speed Touch Home Modem
I have WG11v3, adapter and have all lights ready except. It tells me about the ip address is needed. How can I put that in. I provider is verizon and they tell me I will have to get that answer from...
Click on Start and then Control Panel. Select Network Connections. Right click on the local network adaptor you are setting the IP address for. Select properties. If you do not see Internet Protocol (TCP/IP) click the install select protocol and add then Internet Protocol TCP/IP and ok. Click on Internet Protocol (TCP/IP) and properties. If you do not know the IP Address select obtain IP address automatically and OK. Click OK to close and save Local Area Network Properties. See if this works otherwise you will need to find the IP Address for your modem.
Jul 27, 2010 | Computers & Internet
I get laptop connection with N router, but desktop use is unavailable - saying "cannot find server, page unavailable, not connected to internet,etc"
if you your using your dektop with LAN then u have to configer you r LAn steup
go to folowing steps
1 my Networking place
2 write ckick on that icon , Properties
3 see the local area contection
4 agani properties
5 you will see the one big list select from that
6 internet protocol (TCP/IP)
7 just give the IP in usr the following IP addres
e.c. (192.168.1.22)
then try you dektop will work
May 04, 2010 | Belkin N Wireless Modem-Router F5D8633au4A
Dial up connection ends in error code 720, can't connect to the internet. Using a back-up pc that is terribly slow. would like to fix pc.
Error 720 - the connection attempt failed because your computer and the remote computer could not agree on PPP control protocol.
To resolve this issue, uninstall the TCP/IP protocol, remove the second WAN Miniport IP device, and then reinstall the TCP/IP protocol. To do so, follow these steps:
  1. Uninstall the TCP/IP protocol. To do so:
    1. In Control Panel, double-click Network and Dial-up Connections, right-click Local Area Connection, and then click Properties.
    2. Under Components checked are used by this connection, click Internet Protocol (TCP/IP), and then click Uninstall.
    3. Follow the on-screen instructions to uninstall TCP/IP.
    4. Restart the computer when prompted, but click No if you are prompted to allow Windows to enable a protocol.
  2. Right-click My Computer, and then click Properties.
  3. Click the Hardware tab, and then click Device Manager.
  4. On the View menu, click Show hidden devices.
  5. Under Network adapters, there should be no WAN Miniport IP devices. If a WAN Miniport IP device is listed, continue to the following step. If no WAN Miniport IP device is listed, go directly to step 16.
  6. Click Start, click Run, type regedit in the Open box, and then click OK.
  1. Locate the following registry subkey: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E972-E325-11CE-BFC1-08002BE10318}
  2. On the Registry menu, click Export Registry File, type backup-key in the File name box, and then click Save.
    Note You can restore the changes that you make to this registry key. To do so, double-click the backup-key.reg file that you saved.
  3. Click each of the registry subkeys under this key, and then view the Data column of the DriverDesc value to determine which of the subkeys corresponds to WAN Miniport (IP). For example, the 0005 subkey.
  4. Right-click the subkey whose DriverDesc value data is WAN Miniport (IP) (for example, right-click 0005), and then click Delete. Click Yes to confirm that you want to delete the key.
  5. Quit Registry Editor.
  6. Right-click My Computer, and then click Properties.
  7. Click the Hardware tab, and then click Device Manager.
  8. On the View menu, click Show hidden devices.
  9. Under Network adapters, right-click WAN Miniport (IP) and then click Uninstall. Click OK to confirm that you want to remove this device.
  10. Reinstall the TCP/IP protocol. To do so:
    2. Click Install.
    3. In the Select Network Component Type dialog box, click Protocol, and then click Add.
    4. Under Network Protocol, click Internet Protocol (TCP/IP), and then click OK.
    5. When the protocol is installed, click Close.
  11. Reset the modem by turning the power off and then on, or for an internal modem, restart the computer.
  12. Test your Internet connectivity.
May 02, 2010 | Acer Aspire T650 PC Desktop
2 wire gateway..trying to go wireless....shows excellent signal but limited or no connectivity.
1. Try to determine whether you can connect to the Internet
Start -> Control Panel -> Network and Internet Connection
-> Network Connections -> Right Click Local Area Connection
-> Properties -> Internet Protocol (TCP/IP) ->
Use the following IP Address,
IP Address: 192.168.0.2,
Subnet Mask:255.255.255.0,
Gateway: 192.168.0.1
2. Reset modem and rebooted the computer
3. Check cables if they are properly installed unplug and replug
4. If issue where not resolve contact your ISP service to check if it's the connection or hardware issue " ISP service has a tool that can run a line test determining where the broken connection is."
Nov 15, 2009 | 2wire (1000-000057-000) Modem
D-link di514
Try the DSL modem directly connected to the PC.No D-Link Router(powered off and disconnected). Verify that the PCcould surf/browse/connect to the Internet. Go to Start, Control Panel,Network Connections, right click Local Area Connection, Properties,scroll down to/highlight Internet Protocol (TCP/IP), Properties button.Get the IP Add, Subnet Mask, Default Gateway and DNS assigned to the PC(write this down. This will be your WAN/Internet IP settings). Then Disable DHCP of your modem if it has one. OK, close, save or whatever is applicable.
Disconnect the DSL modem from the PC. Connect D-Link Router to PC (wired/LAN) without the modem connected to the router.Go again to Start, Control Panel, Network Connections, right clickLocal Area Connection, Properties, scroll down to/highlight InternetProtocol(TCP/IP), Properties button. Tick "Use the following IPaddress". Enter this IP Add 192.168.0.10, Subnet Mask255.255.255.0,Default Gateway 192.168.0.1 and the DNS from what youhave written down earlier). This will be your LAN IP settings. OK,close, save or whatever is applicable.
Open a browser and log into the D-Link router (192.168.0.1, using "admin" as a username and no password). Do not run Wireless Network Setup Wizard. In WAN/Internet/Modem setting of router enable/check Static IP Add.Usethe IP numbers previously assigned to PC that you have written down asthe router's WAN/Internet/Modem IP settings. OK, close, save orwhatever is applicable. Reboot router. Connect DSL modem to router.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Aug 04, 2008 | D-Link DI 514 Wireless Router (DI-514)
DI 524 Connection Problem
Try the DSL modem directly connected to the PC.No D-Link Router (powered off and disconnected). Verify that the PC couldsurf/browse/connect to the Internet. Go to Start, Control Panel, Network Connections, right click Local Area Connection, Properties, scroll down to/highlight Internet Protocol (TCP/IP), Properties button. Get the IP Add, Subnet Mask,Default Gateway and DNS assigned to the PC (write this down. This will be your WAN/Internet IP settings). Then Disable DHCP of your modem if it has one. OK, close, save or whatever is applicable.
Disconnect the DSL modem from the PC. Connect D-Link Router to PC (wired/LAN) without the modem connected to the router. Go again to Start, Control Panel, Network Connections, right click Local AreaConnection, Properties, scroll down to/highlight Internet Protocol(TCP/IP), Properties button. Tick "Use the following IP address". Enter this IP Add 192.168.0.10, Subnet Mask 255.255.255.0,Default Gateway 192.168.0.1 and the DNS from what you have written down earlier). This willbe your LAN IP settings. OK, close, save or whatever is applicable.
Open a browser and log into the D-Link router (192.168.0.1, using "admin" as a username and no password). Do not run Wireless Network Setup Wizard. In WAN/Internet/Modem setting of router enable/check Static IP Add.Use the IP numbers previously assigned to PC that you have writtendown as the router's WAN/Internet/Modem IP settings. OK, close, save or whatever is applicable. Rebootrouter. Connect DSL modem to router.
Aug 02, 2008 | D-Link AirPlus DI-524 Wireless Router
Computers & Internet Logo
57 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
