Question about Alpine Car Audio & Video
I have a mrd-1005 amp and the cooling fans are not turning on
  • 505 Answers
Maby the cooling fans need replacing
or its not hot enough for the fans to cool the AMP down
Posted on Jul 19, 2008
How hot does the alpine Mrd-m1005 amp get before the fans start cooling it ??
Fixya has no idea , suggest you check with the manufacturer ALPINE
Nov 28, 2017 | Alpine Car Audio & Video
My alpine Mrd-1005 has been best amp ever. But the other day it all of a sudden started blowing fuses on the amp and the current protecter mode kicks on.. as long as I keep volume down in works but as soon...
make sure there is equal amps on the fuse under the hood and at the amp...also make sure to never mount your amp to anything metal....wood only! hope this helps, mine did the same thing
Sep 04, 2011 | Alpine MRD-M1005 1000 Watt Mono Amplifier...
So I have two alp mrd 501 amps one in each car both amps shut down ( clips ) while driving I have rolled back the setting still happons ?
Well it sounds like the safety switch is turning on. Which means it turns off. If you could clarify that would be awesome and i'm sure i or someone else could answer you better
Mar 01, 2010 | Alpine MRD-M501 Car Audio Amplifier
CUR on alpine MRD M 605
check your ground and make sure you battery power is connect properly
Apr 14, 2009 | Alpine MRD-M605 - V12 MONO AMP 600WX1 RMS...
How to get amp status to come up on the screen of alpine d 310
you have to have an alpine kce-510m amp link module. You must also have a compatible amp, such as mrd-m300, mrd-m500, or the mrd-m1000. The amp link module plugs into the (ext) plug on the iva-d310 and the other end of the cable into an alpine kce-060m y-cable. The shorter of the y-cable plugs into the amp with the lowest id #.
Feb 11, 2009 | Alpine IVA-D310 Car DVD Player
Mrd-m1005 amp fans not never turned on?
the fanns will come on around 75c they are preset 60 is not that hot for an amp but the cooler you can keep it the better it sounds
Nov 27, 2008 | Alpine MRD-M1005 Car Audio Amplifier
Alpine mrd-m500
Could not find exact, but close manual.  It is the MRP-M450 mono block amp from alpine.
Go to this url and view in Adobe. Print it if you need to
Oct 19, 2007 | Alpine MRD-M1005 500W x 1 mono subwoofer...
No sound from the amp
Make sure that your amp turn on wire is connected from behind the radio to your amplifier. Usually the turn on wire is a blue wire but it can be any. This blue wire connects from the blue/white wire behind the radio to your small connection turn on connector on the amps power connections. You have 3 ( 12V , Ground, Switch or the smallest connector)
Also check the amplifiers fuses, and the main powerline fuse as well. If this doesnt work then write back to me.
Oct 10, 2007 | Alpine MRD-M1005 Car Audio Amplifier
Over heating
you trouble shoot the problem by opening unit and force-powering fans to test for overheating during "being used loud for a few minutes". Read the fans' label for proper voltage to apply and proper polarity. I am guessing the fans will run on car battery voltage of 12 volts. Also, attempt to close up the unit to simulate real conditions. There should not be fuses for the fans. If unit is now cooling, then look for faulty thermistor, which turns the fan on during rising temperature. Once thermistor is located, a fast test is to "jumper" its two wires to simulate turn on.
Jun 16, 2007 | Alpine MRV-F345 Car Audio Amplifier
Car Audio & Video Logo
44 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
