Question about Westinghouse Refrigerators
Westinghouse 502 fridge frost free
Where is the drain line in the fridge as i have water leaking into the bottom half of the fridge
thank you
  • 108 Answers
SOURCE: Westinghouse Aurora Frost free fridge
You need to remove the clog in the drain line from the freezer to the condenser, Look under the fridge for the plastic drain line and blow it out or otherwise clear it, Then insure that the unit is level. Sooner or later you need to clean the freezer drain pan. After using up your frozen food, remove the back panels of the freezer and clean the area well.
Ray
Posted on Oct 29, 2008
SOURCE: westinghouse silhouette frost free 522 fridge is
The heating element, located behind the back plate of the freezer, is probably not working. A failed heating element leads to a build up of ice around the evaporator coils in the rear of the freezer. If the back plate of the freezer is removed (ONLY DO THIS WITH THE APPLIANCE UNPLUGGED FROM THE POWER SUPPLY) and there is a large build up of ice around the evaporator coils then it's a fairly good indication that the heating element is not working. The heating element comes on periodically to defrost/de-ice the evaporator coils. Heating element is often activated by a small timer switch which turns the heater on for a set time every 24 hrs or so. Heating element may be open circuit or timer switch may not be operating. Most likely to be open circuit heating element.
Posted on Jan 01, 2010
  • 323 Answers
SOURCE: Frost free refrigerator water not draining out
check that the drain is clear, water should drain to pan under fridge, where the water will evaporate
Posted on Jan 18, 2010
ricsindy
  • 53 Answers
SOURCE: my Westinghouse side by side frost free fridge
Can be anything from a damper / cold control issue to a to cold freezer. As for the frost on the food items in the frzr. Most of the time it is normal, especially when the items are in bags or loosely wrapped. Air is the culpert,
air is a gas...at room temp you can't see it. As it cools it condenses to a liquid, as it gets colder it frosts to ice crystals. Vacuum pak or rap tight in plastic and then zip lock removing as much air as possible.
Posted on Mar 08, 2010
BMT60
  • 126 Answers
SOURCE: Westinghouse Silhouette Frige 522 frost free is
UNPLUGGED FOR 24 HOURS AND LET IT TOTALLY DEFROST.
Posted on Apr 24, 2010
Westinghouse fridge model number RP 432V-R it is leaking water out of the door appears to be coming from behind the salad crisper drawer where there is a vent
Freezer /fridge water/ice in fridge and or freezer, or leaks on floor
Usually due to CONDENSATION due to bad door seals or a plugged evaporator drain line? Can use a soft flexable tubing and very hot water to clean it out. Bad door seals usually need replacement, but u can use a blow dryer and something to pry it closer to the door wall while blowing hot air on to it. To create a seal, to test for bad door seals place a dollar bill in between the door and wall of fridge where it closes. Then slide out the dollar bill with door closed. It should offer some resistance and not be easy to pull out.
Fix any gaps in the door seal.Pack out the seal underneath the areas where the door seal has the gaps. This can be done with a small strip of weather stripping, as shown here, or a bit of tightly rolled up paper under the door seal. Alternatively, you can heat the door seal up with a hair dryer to fix the gaps. This softens the door seal and allows you to stretch it.
Most all fridges have a drain. Look inside your fridge for a "V" shaped channel with a small hole. This hole leads to a tube and a small pan which sits on top of your refrigerator's compressor. The defrost cycle causes water to run into the channel, down the tube, and then it generally evaporates with the heat of the hot condenser/compressor.
However, if that tube is clogged with food crumbs, particles , debris etc, you will have to clear it to get back to a normal mode of operation. A toothpick, pipecleaner, straw or a cotton bud can often do the trick. Another trick one can use is to connect a copper tube wire with one end going into the drain hole then attach the other end to the heater wrap it around heater a few times. That will take care of the drain problem when it comes to ice build up but not food build up.
Even a frost free freezer will still ice up at times in the areas away from the heated defrost area and the drain line can freeze. This icing causes the pipe work to the compressor to ice over or sweat and cause a puddle. Or if the drainage has frozen over, it will need to be de-iced. ( usually the line is under the freezer bottom plate covering. Towards the back of the unit) And there is another inside the fridge area also.
Give the freezer a good overnight defrost until it's totally clear of ice in addition to making sure the drain is clear to the pan at the back and then restart the freezer.
God is so good: so this is why I give free advice so please thank him not me.
Dec 26, 2016 | Westinghouse Refrigerators
Why does thick ice form regularly on bottom of my samsung frost free upside down fridge .
The drain line in the bottom of the freezer is frozen over. Remove the back cover boil some water and slowly pour it down the drain to clear it.
Mar 02, 2014 | Refrigerators
Water leaks inside
It's due to wrong temp setting and malfunction of defrost cycling. Keep thermostat setting at 5 degree or little less. And don't keep it in minus,as defrost cycle will take longer time. And also you will get less cooling in fridge compartment and also water leaks.Check drain line hose may freezed. And also freezer tray get blocked due to over frosting around freezer. Defrost manually by unplug your fridge and after defrost all ices, plug again and keep correct temp setting. Thanks.
Feb 01, 2011 | Whirlpool 21.0 Cu. Ft. Frost-Free...
Water is leaking into my fridge from defrost.
Most times this is a plugged defrost drain system. The defrost heater in the freezer section melts the frost and changes it to water, this water is suppose to flow down a drain system. If this drain system is restricted or plugged the water will leak inside the refrigerator. The drain system starts in the freezer section with a tray built under the evaporator coil. The water is funneled through a small hose into a cup in the top middle of the fresh food section ( not on all models, but this is the most common way ), from there, the water is directed out the back wall to a drain hose that runs down the back of the refrigerator into a condensing tray. The heat created under the fridge makes the water evaporate and disappear. Some of the cups ( in the top back of the fresh food section ) can be removed for cleaning. A turkey baster can be used to help clean out the drain system. Fill the baster with hot water and "blast" it into the drain hose to help flush it out. A piece of wire or pipe cleaner can also be pushed into the drain hoses to help clean then out. On a S x S style of fridge the drain system is in the bottom back of the freezer section and often you will have to remove the evaporator cover to access the drain hole. You can clean this out in the same manner as previously mentioned, but because of the water leaking into the freezer instead of the fresh food section you will have to remove the ice build up to clean out the drain system.
If in case the water is leaking on the floor then:--
There are several things to check for. The condensing defrost tray under the fridge can crack or develop a hole and leak onto the floor. A door gasket not closing properly may cause sweating and leak onto the floor. If your fridge has developed a frost free failure problem, often the frost will travel down the suction line at the back of the fridge and drip water on the floor. The heat exchanger tubing can separate and also sweat and drip on the floor. Ice maker and chilled water fill lines can crack and leak as well, this is fairly common with the plastic lines as they can dry out and crack.
Unplug the unit from main power outlet and empty whole unit and keep both the doors open and then connect the power after 24 hours and recheck.This procedure is called manual defrost reset.If this helps then its OK,but if this procedure not helping then its the faulty defrost unit and it needs to be replaced.
You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Aug 30, 2010 | GE Refrigerators
Apr 24, 2010 | Refrigerators
Water is leaking under the refrigerator. This is
If everything else on the refrigerator seems fine (freezing and refrigerating are fine), then you probably have a problem with the drain hose under the evaporator coil. On frost free freezers, there is a heater that comes on periodically to melt off all the frost on the evaporator coil, and that defrosted frost (water) goes out a drain hose and collects in a pan at the back of the unit where it can evaporate.
Either the drain is clogged with ice inside the freezer, (in which case you might notice ice building up on the bottom of the freezer, or perhaps water collecting on the bottom of the refrigerator if your freezer is on top) OR there is something wrong with the pan at the back of the refrigerator, like a crack, or it somehow got tilted so that the water pours out. It is located behind the panel on the back.
Or perhaps, and this would really ****, the water line that supplies your ice maker is leaking, if you have one. If you do have one, I would recommend turning the water line to the fridge off before pulling the fridge out.
Sep 14, 2009 | Kenmore Refrigerators
Water leaking from freezer into fridge
there are several things to check for. The condensing defrost tray under the fridge can crack or develop a hole and leak onto the floor. A door gasket not closing properly may cause sweating and leak onto the floor. Some fridge's have a humidity switch inside the fridge that should be turned on to prevent sweating on the center bar between the fridge and freezer section. If your fridge has developed a frost free failure problem, often the frost will travel down the suction line at the back of the fridge and drip water on the floor. The heat exchangertubing can separate and also sweat and drip on the floor. A kit to repair a separated heat exchanger line, comes with instructions as well. Ice maker and chilled water fill lines can crack and leak as well, this is fairly common with the plastic lines as they can dry out and crack.
click this link for more help  http://www.applianceaid.com/refrigerator.html
Mar 31, 2009 | Kenmore Refrigerators
Water/condensation in both dairy tray and bottom of fridge
My guess is you have a blocked defrost drain. The water instead of going down its drain goes down the backside of the frig and pools up under the crispers. Blow out the defrost drain. The only other thing to look for is bad door gaskets.
Dec 16, 2008 | Refrigerators
Ray
Oct 29, 2008 | Refrigerators
Refrigerators Logo
300 people viewed this question
Top Westinghouse Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Westinghouse Refrigerator Expert? Answer questions, earn points and help others
