Question about Samsung HL-R5677W 56" HDTV
Color wheel We just replaced our color wheel. TV turns on but screen is blank. Lamp turns on and color wheel spin but now there is no picture
  • 927 Answers
Good day, dkimberly428;
Sorry you are having a problem with your SNG TV.
Let me ask you why did you replace the color wheel? Was it making noise, but had pic prior to changing it?
Okay, if that was it, try this: the color wheel ***'y has one cable and "ribbon type" cable, correct? Okay, make sure both cables are secured. Secondly, the "ribbon type cable" was more then likely put in backwards. If I remember correctly the shiny side (end) of ribbon cable should be facing the rear of TV.
Good Luck, big IRISH. PS always double check ALL cables in TV to make sure they are properly seated.
Posted on Jul 19, 2008
There is a humming in back of tv.the sound always good but picture doesnt come thru and i get a green screen someetimes blurry with distortion.color wheel or dmd chip or lamp starting to go out
as my experience, the most possible reason should be the color wheel or its photo sensor board.
firstly try to clean its photo sensor board, or have to replace a new wheel.
i just have this wheel, when you need to replace it, contact me freely
May 02, 2016 | Televison & Video
Hi I have a samsung hlr4667 and the set will not come on at all.. It makes a buzzing sound kinda like it makes when powering on..And the lamp light flashes but no picture just a loud humming sound...The...
This DLP tv have a colors wheel.The tv colors wheel,it dead.Have loud humming sound,motor noises and pictures flashes black&white within a picture.The colors wheel is dead and is spinning off of it axis and hitting of it sides motor walls.Tv must require a replacement of a colors wheel.Hire a tv tech. to do the job.The tv colors wheel is hard to replace.The tv colors wheel sit behind many manchanical parts,must take out even before u even can replacement the colors wheel itself.
Nov 05, 2010 | Samsung HL-R4667W Rear Projection...
HL-R5667W Picture just went blank, no sound. turn on tv the timer,lamp and stand by/temp light all flash. replaced lamp still same issue heard intermittent whirling fan rubbing sound before it went bad
Sounds that tv got color wheel problem that will be replaced.
If you are handy with electronics stuff repair then replace color wheel in light engine of tv to solve its issue.
Sep 13, 2010 | Samsung HLR5667W 56" Rear Projection HDTV
Samsung hln617w dlp tv won't turn on. Red temp
Had similar problem. Thought it was the lamp. Examined old lamp but it appeared to be good. Ordered a new one anyway. Changed the lamp but the TV screen would not come on. It would make the usual noise as it was going to come on normally but it would cycle 3 times & then turn off. The LED lights in the front panel would indicate a defective lamp. Then read about the ballast. Changed the ballast & still same problem. Tried starting the TV without the lamp installed & noticed that the color wheel did not spin. Removed old color wheel & discovered it was broken. This appears to be the cause of all of my problems. I wish I new earlier of the test-turn on the TV without the lamp being installed & check to see if the color wheel is spinning. Would have save money on the lamp & ballast.
Apr 08, 2010 | Samsung HLN617W 61" Rear Projection HDTV
TV made a big popping sound, and then a crackling
Hi,do you hear any strange noises? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast.Here's the instructions to replace it :http://www.fixyourdlp.com/guides/samsung/bp47-00033a.php That crackling sound could be of the color wheel:The color wheel is a rotating disc that has a gamma of colors it spins at high rpms.The light of the lamp goes through it to create the colors on your tv.When it starts to go bad you will get color distortion ,black and white picture and sometimes you will hear humming noises. But if you don't hear any strange noises,tv is around 6000 hrs,2-4 yrs it could be time to replace the lamp.The lamp you need is BP9601073A you can find original here:http://www.discount-merchant.com/Samsung-BP96-01073A-lamp-p/samsung-bp96-01073a-lamp-oem.htm?Click=48173 .Have a blessed one!
Apr 02, 2010 | Samsung HL-R5668W 56" HDTV
Black screen with sound. we replaced the lamp but screen is still black.
Hi,do you hear any strange noises? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast.Here's the instructions to replace it :http://www.fixyourdlp.com/guides/samsung/bp47-00033a.php Hi,If your tv is a dlp you might be experimenting a color wheel problem.The color wheel is a rotating disc that has a gamma of colors it spins at high rpms.The light of the lamp goes through it to create the colors on your tv.When it starts to go bad you will get color distortion ,black and white picture and sometimes you will hear humming noises. Also make sure everything is properly closed (door cover) if it's not properly shut it won't be able to light the lamp.Have a bless one!
Mar 31, 2010 | Toshiba TheaterWide 52HM84 52" Rear...
Samsung hln617w non power up
Most of the time when these sets won't turn off it's caused by the DMD but check the color wheel connectors first, especially the flat ribbon cable. Make sure it's in the connector in the correct direction, only has contacts on one side and make sure the ribbon is not torn.
Mar 03, 2009 | Samsung HLN617W 61" Rear Projection HDTV
TV will not turn on, Have three blinking lights, lamp won't turn on, color wheel isnt spinning.
the color wheel wil need to be replaced soon if it is doing that. it could be then DMD board as will.
Jun 20, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
T.v. will not turn on. flahes "lamp" then no picture!
This will have to be narrowed down to a specific problem. I would try the easiest things first. First check the lamp. Is it bad or just starting to go bad or does it just need to be reseated with the ballast? If the ballast flickers when turning on your TV, then you will know it is the lamp that is not working or the ballast may need to be replaced. If that is not the problem next check to see if the color wheel is spinning or broken. If broken, it will need to be replaced. If not spinning it is the DMD board that is bad. The color wheel is plugged into the DMD board. If the DMD board is good it will spin the color wheel, that is what will start your lamp. When you lamp starts, you have your picture.
Mar 23, 2008 | Samsung HL-R6167W 61" HDTV
Samsung HL-R5677W 56" HDTV Logo
103 people viewed this question
Jerry Greenberg
Jerry Greenberg
